Question about Asko 24 in. 1585 Built-in Dishwasher
Doesn't clean Ever since the dishwasher was installed it doesn't clean the dishes very well. Seems to work and run normal.
    Sergeant:
  • 351 Answers
Check theres enough water getting into machine are you on tank water or low pressure water.
Posted on Mar 02, 2008
rylee_smith
  • 8619 Answers
SOURCE: dishwasher does not clean the dishes properly
Hi
First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks
Low water fills are a very common trouble maker with today's dishwasher.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jul 10, 2009
Icebassman 5
  • 57 Answers
SOURCE: Dishes are not getting clean
Hi there.
In the bottom of the dishwashers is normally a filter with a handle on it for easy removal. pull it up, gently, you might have to turn it slightly from side to side to loosen it if it is very dirty. When this filter is out you will see another filter that is just lifted straight up and on that one you might find a lot of dirt.Put both filters in a 10 liter bucket with on cup of chlorine(diluted to 5%) to 5 liters of water. Pour some chlorine( 2 cups) into the bottom of the machine, and close the door and let the machine run on its hottest cycle until finished. When the machine is finished, rinse out the filters in the bucket with warm water. Brush the rest of the dirt off and replace them where they were. Run the machine once again, now on a normal cycle with the dishes in it and I believe they will be clean.
Iceman.
Posted on Nov 04, 2009
  • 457 Answers
SOURCE: I have gritty debris on the dishes, it appears the
1. it can be water backing upfrom maybe a garbage disposer like a clog ,or fill jet dry compartment completely.add nad fill then open and close the door 3 times then you will be able to add more what you are doing is taking out the air in the dispenser.once it is filled completely last thing is to make sure the water ghoing into machine is hot,then start the machine for best results. let me know if i have been of some help
Posted on Feb 27, 2010
  • 1075 Answers
SOURCE: dishwasher is not cleaning dishes
i would suspect spraying arms or water temp not working.adrian,,,
Posted on Jul 14, 2010
jnchahn
  • 252 Answers
SOURCE: I bought a new bosch
Try cleaning the latch that holds the door. After a year the detergent will build up on the spring causing it not to open. If that doesn't do it call the people who you bought it off of. It should have a extended warranty for a year.
Posted on May 14, 2011
Testimonial: "Thank you for your prompt response!"
Filter doesn't self-clean
hello diane,
i would think that unless your model says it is self cleaning then yes it is normal to have to clean the filters on a dish washer. the amount of time between cleans would depend on how dirty your dishes are.
Apr 20, 2013 | Kenmore 24 in. 15932 Built-in Dishwasher
Whirlpool dishwasher model series 980 doesn't clean dishes as good as it used to
Phosphate was outlawed as an ingredient in dishwasher detergent. If you live in a region with hard water, detergents don't work very well anymore. See the US map of water hardness.
http://www.citriclean.net/why-citriclean/
Mar 19, 2013 | Whirlpool Dishwashers
The lg dishwasher doesn't use all of the detergent and the dishes are not 100% clean
first check the water supply if good water pressure.then check the pump under the bottom dish tray remove parts check for debree.
Jan 25, 2013 | Dishwashers
How to clean the strainer of a Kenmore 665.1348 dishwasher
Try following this YouTube video titled: Dishwasher DIY maintenance Kenmore dish washer.
https://youtu.be/BRGee1nRjO4
Please let me know if I was able to point you in the right direction.
Dec 14, 2017 | Kenmore Dishwashers
Soap dispenser on my Miele G646 Sci Plus doesn't open every time. Have cleaned the washer, run a full hot cycle with the washer empty; I always ensure the dish and surrounding is dry before inserting...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 12, 2011 | Dishwashers
I have a GE quiet/power2 MOD D5560LOOSS It doesn't release the soap from the dish. It wasn't cleaning dishes well and then it completly stopped. I have tried different settings. It sounds as if...
heatman101
Aug 13, 2011 | GE Dishwashers
Bosch SHU3305 keeps running and doesn't clean dishes. Soap doesn't release.
you may need to replace the soap dispeser assembly which includes the solenoid that operates the lid.
See this diagram part 13. You may be lucky and it could only be the lid spring that is faulty. In which case you do not have to replace the whole assembly.
Good luck..
May 13, 2011 | Bosch SHU3305 Dishwasher
My dishwasher doesn't work. It won't clean the
It can be your timer, motor, or water value. I need more detail information.
May 13, 2011 | Hotpoint HDA3520ZBB Dishwasher
Dishwashers Logo
91 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Jose Pino
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
