Question about JVC KD-G110 CD Player
Car problem not getting any gas to engine
  • upixiemeto Jun 27, 2008
    we changed the throttle position sensor (tps)
It cranks for a few seconds then shuts off
Posted on Mar 18, 2008
  • 82 Answers
Are you sure this is what it is have you tried someon spraying ether into the breather while cranking it if it cranks or tries to then its not getting fire
Posted on Feb 09, 2008
Engine won't get gas
check the fuel cut off switch in the trunk its on the l/s .look for yellow label
Jan 15, 2013 | 1998 Ford Contour
Tip
How to Get Better Fuel Economy
Time to buy a new car? Do the math to see what it will cost you in gas. If you're like most Americans, and drive about 20,000 miles a year, increasing your car's fuel efficiency by about 15 MPG can save you over a thousand dollars a year - not to mention countless stops at the gas station. Engines are becoming more fuel efficient every year!
Get the smallest, most fuel efficient vehicle that makes sense for your daily driving. There are more hybrids and fuel efficient engines on the market every year.
Carpool
This is a great way to reduce your fuel consumption. Simply find someone that is willing to share their car with you. Even if it's only once a week, this will save you a few gallons of gas every week!
Only use the type of gasoline that your car requires
Make sure you read your owner's manual to see what type of fuel your car requires. If your engine is designed to run on regular gas, there's absolutely no benefit to putting in premium gas.
Don't floor it
For every 10 miles per hour you floor it, you lose as much as 15% more fuel. Simply letting your speed slowly get up to the speed limit will lessen the amount of gas your engine needs to reach the speed limit.
Getting into the highest gear you can, at the lowest possible speed, will increase your fuel economy greatly.
You use less gas when the engine is turning slowly. The slower your engine turns, the fewer the number of explosions in the cylinders. The fewer explosions, the less gas consumed.
If you drive a manual transmission, shift sooner. You'll sacrifice the ability to accelerate quickly but you can always downshift if you need to accelerate.
Have your car maintained
Getting regular oil changes and changing your spark plugs will increase your fuel efficiency also. Wear and tear on your car's engine will decrease it's ability to use gasoline efficiently.
Genuine Factory OEM Parts and Accessories BamWholesaleParts com
on Oct 03, 2017 | Cars & Trucks
Shouldn't a 2.0 liter engine be getting better gas Mileage than a 2.4 liter engine?
The size of the engine alone will not determine gas mileage. There are many other factors including vehicle weight, design of the motor, etc. So in answer to question 1, size isn't going to matter.
For question #2, make sure you change the oil, oil filter, air filter and keep the tires inflated to recommended specs. That might help you out a bit...
If you want to know more about you can visit :
May 09, 2012 | Cars & Trucks
Whats the right thermostat for 1995 lincoln town car
You will get that at the auto repair house. They will get you the one that corresponds to the size of the engine. 180 degrees is common. Buy it here
$17.27
List Price: $20.38
Save: $3.11
  • BESTSELLER
  • Low Price Guarantee
  • In Stock
Quantity
STANT ENGINE COOLANT THERMOSTAT -- 180 degrees Fahrenheit opening temperature; A high quality, direct fit OE replacement engine coolant thermostat; With 90-day Stant limited warranty.
  • Material: Stainless steel
  • Product Fit: OE replacement
  • Quantity Sold: Sold individually
  • Anticipated Ship Out Time: 1-2 business days
  • Opening Temperature Rating: 180 degrees
View more Fits the following 1995 Lincoln Town Car submodels:
  • 1995: Base; 8 Cyl 4.6L; "GAS"
  • 1995: Cartier; 8 Cyl 4.6L; "GAS"
  • 1995: Cypress; 8 Cyl 4.6L; "GAS"
  • 1995: Executive; 8 Cyl 4.6L; "GAS"
  • 1995: Signature; 8 Cyl 4.6L; "GAS
Nov 19, 2011 | 1995 Lincoln Town Car
Why does my engine oil smells like gas, and when i drive there is a lous gas odor in the car
You might have a leaking fuel injector, which is dumping fuel into it's respective engine cylinder, which then leaks down into the crankcase where the engine oil is. Then, as you drive, the gas is evaporating and getting into the car through the vents. It's a very serious, possibly explosive problem anytime you have excessive gas in your engine oil. Have it looked at and repaired immediately.
Dec 30, 2010 | 2001 Hyundai Santa Fe
SC2 car cranks and starts sometimes.put new plugs and wires and noticed oil on the 3 and 4 plug. Car once started with some starting flluid runs fine. and will restart. weather is getting cooler 20 degrees...
A common problem with the 90's engines was the ECTS (electronic coolant temperature sensor) going bad. Seems when attempting to start the car, the computer in the car will only allow enough gas it thinks is needed to start. When a car is cold, the computer gives more gas initially, until the engine warms up, then gives less gas. When starting a warm engine, less gas is needed.
If the sensor goes bad, it always tells the computer that the engine is hot. The computer give less gas to a cold engine, and sometimes it will start, sometimes not. Its a pretty cheap part, and a do it yourself one, just research it a bit on line...good luck
Dec 23, 2010 | 1999 Saturn SC
Engine check light comes on and stays on for awhile then goes off. Dometimes when I fill the gas tank the check engine light comes on. is something to do with the gas cap or the instrument lights.
IF IT COME ON EVERY TIME YOU GET GAS.GAS CAP HAS BAD SEAL IT MORE LIKELY YOUR PROBLEM BUT LET AUTO ZONE SCAN IT FREE TO SEE WHAT TROUBLE CODE YOU ARE GETTING.
May 23, 2010 | 2003 Pontiac Bonneville
Crank no start ,got fuel got spark, when trying to start spark plugs get wet ,changed plug pinched fuel line shut try srarting flud wont start???
You pinched the fuel line????
If you crank for too long to start the car, the engine will "flood", this is why the plug was wet. It had too much gas and wouldn't start.
Pull out ALL plugs and dry them off.
Install them.
HOLD your gas pedal to the floor and crank.
This will stop gas from entering the engine.
you need to get that extra gas out beofre it will start.
If you have so much gas in there you can do damage to your engine!!
Now after a few crnaking attempts with your foot to the floor, take your foot of the gas pedal and try to start it again.
But remember if it doesn't start in 3 tries, you need to do the pedal to the floor once or twice to remove the excess gas.
When you crank the car to start it sprays gas into the engine, even if it won't start. So it very easy to "flood" the engine, and then you'll have a hard time to get it going!
Jan 08, 2010 | 1997 Nissan Sentra
Can't start 1990 nissan maxima. it's like it's not getting gas although I can smell gas
Thats because your engine is flushed with gas and not enough air from cranking the engine so much. If you smell gas, then the car is getting gas. Gas is not your problem. It might be your starter or check your ignition system such as spark plug, etc.....
Jun 25, 2009 | 1990 Nissan Maxima
Check engine light blinks
My suggestion is to get the fault codes stored in the car's ecu read by a VW approved garage. That will tell them what "was" wrong. Once a fault has occurred the check engine light will probably stay on until the warning has been cancelled using VW software.
As for the grade of gas used in the car, the users manual will tell you that - it might also be written inside the filler cap.
I wouldn't recommend further use of "engine cleaner" - it might do more harm than good.
Go get the codes read and then you'll know for sure.
Hope this helps. D
Jul 02, 2008 | 2003 Volkswagen Beetle TDI
JVC KD-G110 CD Player Logo
24 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
