Question about Samsung S860 Digital Camera
Memory card type for Samsung S860
Does any SD card fit the Samsung S860, it can not take CF or SDHC cards and therefore is limited to a maximum of a 2GB memory card?
  • Ladi Santana Feb 25, 2010
    How do you get the pictures on the camera of the S860 on to a memory card?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
The S860 can use any SD or SDHC card.
Posted on Feb 01, 2013
5 Suggested Answers
SOURCE:
mackcamera
  • 33 Answers
SOURCE: Can a SDHC card be used with a CF card adapter in Nikon D70s?
You would have to get an SDHC to CF adapter which could be pricey and they are hard to come by.
Posted on Dec 31, 2008
t00nz
  • 4738 Answers
SOURCE: Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
Posted on Oct 19, 2009
SOURCE: Can I use a SDHC card in my Panasonic DMC-TZ1
According to the TZ1 manual the maximum size of SD hard is 2gb. You cannot use the new format SDHC card as it is not recognized.
Posted on Dec 05, 2009
  • 102366 Answers
SOURCE: Minolta Z6 SDHC memory limits?
The Z6 works with SD and MMC cards. It does not work with SDHC cards at all, whatever their size. SD cards are limited to 2GB in size.
Posted on Jul 27, 2010
What card in samsung smx-f40bn/xaa
FROM THE OWNERS MANUAL: Using a memory card (not supplied)
• This camcorder has a card slot for access to SD and SDHC (Secure Digital High Capacity).
• You can use SD and SDHC cards on your camcorder.
- Some cards are not compatible depending on a memory card manufacturer and memory
card type.
May 19, 2012 | Sony DCR-SX40 Camcorder
I can not get our memory card to format. it says card error. we are using a microSDHC Ccard with adapter 4gb
Is the camera compatible with SDHC? If it can only handle SD memory cards this card is not readable in the device. It will show on the camera whether it is compatible with SDHC. If it doesn't have the logo, take it as the card won't work and you'll need to get a normal SD card.
There is a theoretical maximum of 2GB for SD memory cards, SDHC start at 4GB and go up to 32GB.
Simply put, if your camera is quite old, it won't support SDHC and therefore is limited to a maximum of 2GB memory card.
Jul 26, 2011 | Cameras
What size memory card do I need for the 735 camera?
The 735 uses MMC and SD cards. Both types are limited to 2GB maximum. Be careful not to use SDHC cards. While they will fit into the slot, they are electronically incompatible and won't work.
Nov 06, 2010 | HP Photosmart 735 Digital Camera
I want to know maximum card (SD and SDHC) that can be used with Canon Power A550 Camera.
The maximum size of SD cards you can use is 2GB since SD cards max out there. SDHC cards max out at 32GB. The camera itself does not impose any limits on those two types. In short, you can use any SD/SDHC card.
Oct 18, 2010 | Cameras
I just bought a new memory card-4 gb SD-K046. It says that the memory card is full but it is not. I have only used this memory card to scan pictures. I uploaded these pictures onto my camera and deleted...
The following information lists the type and maximum storage capacity of the memory card that each type of camera accepts.
EASYSHARE CX-, DX-, LS-Series Cameras accept:
DX3500, DX3600, DX3900: CF memory cards up to 1 GB
LS755: xD memory cards only
All other CX, DX, LS: SD memory cards up to 1 GB
EASYSHARE C-Series Cameras accept:
C300, C310, C315, C330, CD33, CW330, C530, CD40, CD50: SD memory cards up to 1 GB
C340, C360, C433, C503, C533, C603, C633, C643, C663, C703, C743, C875: SD memory cards up to 2 GB
CD43: xD memory cards only
All other C-Series Cameras: SDHC and SDHC UHS-1 memory cards up to 32 GB
EASYSHARE M-Series Cameras accept:
M590, M583, M577 TOUCH, M5370 TOUCH: MicroSD and MicroSDHC memory cards up to 32 GB
All other M-Series Cameras: SD, SDHC, SDHC UHS-1 memory cards up to 32 GB
EASYSHARE P-Series Cameras accept:
P850, P880: SD memory cards up to 2 GB
P712: SD or SDHC memory cards up to 4 GB
EASYSHARE SLICE Digital Camera accepts:
MicroSD and MicroSDHC memory cards up to 32 GB.
EASYSHARE V-Series Cameras accept:
V1233, V1253, V1073, V1273: SDHC, SDHC UHS-1 memory cards up to 32 GB
All other V-Series Cameras: SD memory cards up to 2 GB
EASYSHARE Z-Series Cameras accept:
Z610, Z650, Z700, Z710, Z730, Z740, Z760, Z7590: SD memory cards up to 2 GB
All other Z-Series Cameras, including MAX: SDHC and SDHC UHS-1 memory cards up to 32 GB
FUNSAVER FD-Series Cameras accept:
SD and SDHC memory cards up to 32 GB
EASYSHARE ONE Camera accepts:
SD and SDHC memory cards up to 1 GB
Notes:
Most KODAK Digital Cameras are compatible with SD, SD/MMC, and/or SDHC memory cards.
Most current KODAK Digital Cameras are compatible with SDHC UHS-1 memory cards.
All KODAK Digital Cameras that are compatible with SDHC and SDHC UHS-1 memory cards use cards with Speed Class up to Class 10.
MicroSD and MicroSDHC cards with SD adapters can also be used in cameras that use SD or SDHC cards if the storage capacity criteria above is followed.
KODAK Digital Cameras are not compatible with SDXC memory cards.
reference: http://www.kodak.com/global/mul/service/index.html?reqURL=http://support.en.kodak.com/app/home/src/gosupport
http://support.en.kodak.com/app/answers/list/p/2/selected/true
Phone Number for Kodak is:
800-235-6325
or try get human below for more info on support:
http://gethuman.com/phone-number/Kodak/
Jun 11, 2010 | Computers & Internet
Memory card saying "full" when its not
Your problem is that you are using an incompatible type of memory card.
Your camera was designed to use SD cards with a maximum capacity of 2GB. It cannot use larger capacity models, and is also incompatible with the later SDHC cards.
SDHC cards are the same shape and will fit your camera, but have differences beneath the skin and so won't work properly in your camera. Without any memory card in place your camera uses internal memory; it's then only by lucky chance that your camera has sufficient SDHC compatibility to allow you to transfer the internal memory image to the SDHC card when you subsequently insert it into your camera.
Your only solutions are to either use an SD card with a maximum capacity of 2GB or to replace the camera with a later model which is fully SDHC compliant.
Apr 29, 2010 | Samsung Digimax D73 Digital Camera
I bought a 4GB Memory Card for my Samsung Digimax D53. I put it the camera and Try to format it, but it says CHECK SD CARD. I tried another 1GB memory card and it worked. I know that the problem is with my...
Your problem is that your camera only takes standard SD cards up to a maximum of 2GB. The card you have bought is likely to be a 4GB SDHC model. SDHC is a later development of SD; SDHC compliant devices can still use older SD cards, but SD-only devices cannot use SDHC. This is a hardware limitation so there is no way at all to use an SDHC card in your camera.
Note that if your 4GB card is definitely an SD and not an SDHC then it's still incompatible with your camera: very few standard SD devices were ever made with the firmware and hardware to handle the different memory addressing architecture used by the larger capacity card. Some cameras did have firmware updates to allow the larger SD card to be used, but yours is not one of them.
Your only fix is to sell your card (or keep it for another device) and to buy a regular SD card no larger than 2GB maximum capacity.
I trust that my reply has answered your question fully, please take a moment to rate my answer.
Mar 23, 2010 | Samsung Digimax D53 Digital Camera
Hi h r u , i just bought s860, but when i insereted 4 gb sdhc card it is giving message that card is block
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 09, 2009 | Samsung S860 Digital Camera
Dec 31, 2008 | Nikon D70s Digital Camera
"Card Not Initialized with 4GB CF memory card"
Steve, S700 and S7000 are different beasts.
S7000 is only rated for 1Gb compact flash cards. It apparently works with 2Gb ones but as I and a lot of others have discovered no matter how you tweak around sectors and clusters it won't read the thing.
This is a Fat16 limitation.
Sep 28, 2008 | Fuji FinePix S7000 Digital Camera
Samsung S860 Digital Camera Logo
347 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
