Document feeder error message
We are on a small Pacific island with no Toshiba service within 1500 miles. Our e-Studio 280 displays a "Misfeed in document feeder" error message at turn on.There are no documents in the feeder. The document feeder is part number MR-3016. Perhaps a problem with a photo detector?
  • Colin C Feb 13, 2008
    There are no documents in the feeder as stated in the original post.
    The are no documents in the feeder as stated in the original posting.
  • 168 Answers
Also check to see if there is a piece of paper towards the exit side. Something that you can try to narrow it down is, Turn the machine off, raise the doc feeder to the open position, then turn the machine ON.
If the machine warms up without the error message, then you know that there is something in the Feeder. After the machine is warmed up, lower the feeder and you will probably get the Jam message. You can check the exit side by also taking a piece of paper and try to manually feed it through to make sure that nothing is stuck in the turn around exit side.
You can also do this with the paper in side.
Usually the photo detectors are pretty reliable, so I would check to see if there is paper stuck somewhere.
Hope this helps.
Good luck.
Mac =)
Posted on Feb 09, 2008
    Master:
    Sergeant:
  • 440 Answers
Did u guys ever use maginzes to scan documents with they will get jamed in there i would open it up cheak feeders closly ok thx nick
MISFEED INDICATOR BLINKING
DEAR SIR WHERE YOU REMOVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEASE CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Hope this may help;
Regards,
VOTIT
Aug 29, 2008 | Sharp AL 800 Copier
Xerox WorkCentre 7120 error code
Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
Aug 23, 2014 | Xerox Office Equipment & Supplies
How to remove error e712
Clean RADF (document feeder) feed rolls with wet cloth, and open RADF cover and blow air so to clean and dust or small paper.
May 17, 2014 | Toshiba e-Studio 282 Printer
Does toshiba estudio 203 have a memory for past documents
http://www.ebookbay.com/ebook/935/toshiba-e-studio-200l-202l-230-232-280-282-smhh here is the service manual for Toshiba e studio 232/282
Jan 02, 2012 | Toshiba e-Studio 232 Black and White...
I have an error code e741 on my eStudio 450. I know that this is a mis-feed error that pertains to the duplex printing process. I have determined that there is no residual paper in the machine, yet the...
If no paper found in the Feeder Unit and the E741 paper misfeed is sign on, then probably the actuator sensor inside the feeder unit faulty.
In order to temporary bypass the feeder problem, just unplug the feeder connector,
Mar 10, 2011 | Toshiba E-STUDIO 450 Copier
Que significa el error C010 en toshiba est 280 por favor alguien se lo sabe, gracias i.b
C010 indicates main motor is abnormal.
Is the main motor working? (Perform the output check in the test mode: 03-101/151)
If main motor working, check the feeder's clutch, whether it is hard.
Oct 23, 2010 | Toshiba e-Studio 350 Copier
Misfeed detected but no paper jam
Di 251 is legacy Minolta machine, Minolta is now Konica Minolta
for the image unit try this site
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
as for the adf replace!!! the rollers all three try the same site above
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 03, 2009 | Minolta Di251 All-In-One Printer
The copier keeps saying to put doc. feeder down and i it is. I ha
power supply has the fuse open that feed the voltage for the ardf
Mar 20, 2009 | Toshiba E-STUDIO 450 Copier
255 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
