Durabrand DVD player
It was working fine and now it keeps aying no valid disc when we try to play or clean a dvd. Any help please?
  • savafritts Aug 06, 2008
    Same thing here - 2 months out of warranty. Won't read most DVD's. Error "no Disc" or "cannot read disc". Sometimes if you clean disk and insert and reinsert a dozen times it may pick it up and play. Plays fine when finally reads disc.
    Called service dept - nice Customer service lady, but couldn't get supervisor to approve me sending back to have fixed as it was out of warranty. At least they called back when they said they would. She felt it was the lens.
    So I'm stuck with an expensive unit, about 15 months old that won't read 99% of DVD's. VHS side works well.
    Back to Sony!
    Problem Solver:
  • 13 Answers
Try a cd in it if it plays the cd and not the dvd it means a faulty lazer and most likely through it away
Posted on Feb 10, 2008
I was just wondering why the dvd player keeps saying no valid disc? It started working fine and then said no valid disc and has ever since. Not sure exactly what model it is, but the serial # is...
Your DVD drive lens may have a problem reading data from the Disc.
The first simplest solution is to find a way to clean the drive lens
(may involve opening the unit). While you're at it, vacuum all the dust
inside the player. I use a Q-Tip with a DVD cleaning solution to clean
the lens. In the worse case, it's time for a new Player.
Jul 16, 2011 | Durabrand Televison & Video
Doesn't play any dvd or cd
you need to see if the disc is spinning inside the unit, if it is then you need to either clean the laser with a clean cotton tip or replace the laser, if the disc doesnt spin, it may be the spindle motor(held within laser assy,which is easier to replace) or it could be the mpeg printed circuit board. Good luck.
Sep 26, 2009 | Durabrand DUR7 Portable DVD Player
Portable durabrand dvd wont read disc
If it is reading a burned movie from the internet make sure you set you brun software for captability mode.
If this is a orginal disk make sure its free of dust and scratches.
1. buy a lens cleaning kit from walmart or any other eletronics store.
2. Make sure the disc is free of scratches.
3. change disc's and see if it works on any others.
if these steps do not help then the laser would need to be replaced. Durabrand is a Wal mart brand i had mine for 2 years and i had to clean the lens 3 times with a cleaning kit.
Thanks
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 17, 2009 | Durabrand DUR7 Portable DVD Player
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
No Valid Disc
Try cleaning the laser lens if this don't repair it ,is the flat cable connector between the laser lens and the main board.Good luck
Jul 25, 2008 | Durabrand Portable DVD
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
No disc
go to genuine repair center adn change lens of yr dvd
Mar 18, 2008 | Durabrand PDV-709
I put the disc in the player ithen tries to play then it says disc not valid .
Same here!!! We've only used it maybe 8 or 9 times. And it's been worthless for the past month because of it. It reads everything "no valid disk" and nothing will work. And I tried e-mailing customer support several times, with no luck.
Nov 21, 2007 | Durabrand DUR7 Portable DVD Player
Not working
i am living in the philippines. my durabrand DVD 1002 wont work. the message on the screen says no disc. how can i make my dvd play?
Aug 31, 2007 | Durabrand DVD-1002 DVD Player
Dvd
well is it a burned dvd???? or a regular dvd??? did you try cleaning it???
Jul 12, 2007 | Durabrand DUR7 Portable DVD Player
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
