Question about Durabrand DUR-1700 Portable DVD Player
Dvd player reading no disc error
I clean already the dvd lens but still reading no disc, what shall i do,is there any posible that the lens is damages or it can be repair or is there something to adjust?, what is your the best solution or recommendation.
please kindly help me...thank you very much in advance..
(ubert) my email add: ubertlegis@yahoo.com
  • mbyrum5 Mar 02, 2008
    My unit will not regonize a cd or dvd disc.
Where can i found a new spin motot because mine is not working because it broke and is it alot of money to fix and if so should i buy a new one
Posted on Apr 22, 2008
Same thing with mine, it will play a cd every so often however, so is the lazer just no good and the dvd recorder junk
Posted on Mar 06, 2008
    Problem Solver:
  • 13 Answers
Where you say u have cleaned the lens have you been in side it, if so does the dvd spin round when you put a disc in, if it does and it doesnt read try a cd in it if it reads that then it will be the lazer, if it doesnt read it it could still be the lazer but could be a few other things like spin motor.
hope this helps
Posted on Feb 10, 2008
Disc error
Your disc error problem has a DIY steps like the following.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust the lens can't read any disc. Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replace the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
Ifyou already cleaned the lens, and confirmed that the ribbon is good as well as the motor then I've advice you to send it to repair shop because the next step should be done with an expert because it is quite technical diagnosing the fault between the pick-up lens and the main board.
Hope it may help you.
Have a nice day!
Feb 11, 2011 | Toshiba SD-3950 DVD Player
DVD player will not recognize any DVDs I put into player. I even took top off and cleaned laser eye and still does not play. Now red light is on in place of green power light. What's up with this thing?...
No disc error can be a DIY like the following steps.
Since you've already done the #1 now proceed to #2.
1.Cleaning the lens. - Sometimes because of dust the lens can't read any disc.
2.Replacing the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser.
3.Checked the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.
Bad motor - reading will drop to low resistance and will not spin.
If you already cleaned the lens, and confirmed that the ribbon is good as well as the motor then I
Jan 24, 2011 | Oritron DVD600 DVD Player
Dvd player wont read any discs cds and i just bought it keeps saying bad disc
If you already cleaned the lens, and confirmed that the ribbon is good as well as the motor then I've advice you to send it to repair shop because the next step should be done with an expert because it is quite technical diagnosing the fault between the pick-up lens and the main board.
Please rate my help.
Jan 18, 2011 | GPX DH109B DVD Player
WON'T PLAY CD'S READS "NO DISC"
  • Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the CD player's ability to function. You can use a CD repair device like the "Disc Doctor" to repair the CD or purchase a new CD.
  • Clean the laser lens with a CD laser lens cleaning disc. CD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  • Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  • Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  • Dec 11, 2010 | Sony CMT-EP505 CD Shelf System
    Why my dvd denon 3930 model not reading disc
    there is the possibility of damage to the optic lens of the DVD is already weakened or damaged. so it can not load the disc. you have to replace them with new ones according to the type of DVD optical lens.
    Jul 26, 2010 | Denon DVD-3930 DVD Player
    The player just reads "disc error"
    If your DVD player keeps reading disc error, it simply means the player is unable to read.
    The reason is that the lens of the player is weak and cannot play the disc.
    The solution for you to completely replace the lens.
    to replace the lens, get a replacement lens from an electronic shop,
    get the appropriate screwdriver and unscrew the player,
    open up the disc tray and carefully replace the lens,
    ensure that you do not tamper with the panel of the player.
    once the replacement is properly done,
    couple back the player and test with a DVD disc.
    take care
    Jun 13, 2010 | Insignia IS-DVD1001 DVD Recorder/VCR
    The dvds are not detected - No Disc or Disc Error
    Hi. These steps should help.
    1. Check the disc you're using for scratches and dirt. If the disc is damaged it won’t play properly, regardless of the DVD player’s ability to function. You can use a DVD repair device like the "Disc Doctor" to repair the DVD or purchase a new DVD.
    2. Make sure the discs you're using fit the correct format specified by your DVD player. For example, if your DVD player doesn’t support home-burned DVD-R's, then you can’t use a DVD that you made at home. You may need to upgrade to a newer model, most of which accept the latest DVD formats.
    3. Clean the laser lens with a DVD laser lens cleaning disc. DVD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
    4. Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
    5. Turn the device off and unplug it. Take off the outer casing by removing the three or four screws and lifting the top piece off. This will allow you to see if anything is simply stuck or jammed. If this is the case, a simple nudge back to the correct position will fix the problem.
    6. Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
    7. Take your DVD player to have it professionally fixed only when none of these other solutions solves the problem. A professional repair technician will be able to tell you if fixing your DVD player is worth the money.
    Nov 22, 2009 | Aiwa HT-DV90 System
    DISC READ ERROR?
    THE LENS IS DAMAGE ALREADY I HAVE THE THE MACHANISIM FOR WE COULD REPAIR IT FOR $150
    Mar 29, 2009 | Kenwood KVT-715DVD Car DVD Player
    Not reading disc
    First Clean the lens:
    http://www.ehow.com/how_2036275_clean-lens-dvd.html
    Feb 26, 2008 | Televison & Video
    Durabrand DUR-1700 Portable DVD Player Logo
    127 people viewed this question
    Top Durabrand Televison & Video Experts
    matt martin
    matt martin
    Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
