Question about RCA RT2500 System
RT2580 I have a RT2580. I turn it on and after a few seconds I hear a pop and it's off. It has been plugged into a surge protector. thks
  • Trev4
    Trev4 Feb 28, 2008
    I have the same problem. It turns on, there is a *click* and the display says "chk spkr" and then it shuts off.
The speaker wires are crossed!! That means the negative part of the speaker wire is somehow touching the positive side. Check all wires from the reciever to all speakers. Good luck.
Posted on Mar 06, 2008
Hpscanjet 2400 is not powering on,what maybe the problem?
• Ensure that the power cable is securely connected between the
scanner and a live electrical outlet or surge protector.
• If the power cable is connected to a surge protector, ensure that
the surge protector is plugged into an outlet and turned on.
• Disconnect the power cable from the scanner and turn off the
computer. After 30 seconds, reconnect the power cable to the
scanner and then turn on the computer, in that order.
Jul 07, 2011 | HP ScanJet 2400 Flatbed Scanner
Their was a blackout in my neighborhood. The next day in the morning i tried to turn on my 50inch HP Plasma and it made a loud popping sound. The volume on the tv still works.
Hello.
You probably did not have that tv plugged into a surge protector. When the power was restored, a surge came through the line. A power surge is a spike in voltage above the maximum a tv, appliance etc. can handle of 169 volts. They are very brief, usually lasting millinths of a second. Power surges can vary in duration and magnitude, varying from a few hundred volts to several thousand volts.
That said, now what do you do. If the tv is under 3 years old I recommend that you take it into a local TV repair shop for a free estimate of repair. If it is older than that, I would not repair, just replace. J.
Sep 12, 2010 | HP Televison & Video
Have an insignia tv that won't power on...was off..made popping noise...won't power on. checked power in both the surge protector it was in & wall. all other items plugged into surge protector work....
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 27, 2010 | Insignia NS-LTDVD19-09 LCD TV
My tv made a popping noise and then shut off wont
Power Supply Board is dead.Replaced the power supply board will solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 19, 2010 | Televison & Video
Power surge hit my surge protector with my 'sony tv hooked to it.
Well, the power supply may be still damaged by the surge, what may happen is that when first surge happens the surge protector protect your TV by sacrifing itself but then the second surge comes along, since the protector already blown up then the surge will just come right through to the TV on the second surge. That is bad problem for the surge protector that sacrify itself but can only do it for ONE time.
Oct 31, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I plugged both my Axis 9's into a surge protector that was (unknown to me) 220 V while the decks were set for 110. Now neither of them will turn on. My mixer is fine, and i didnt hear any pop and there was...
good day. well both of them may had just blow a fuse. The reason you did not hear a pop sound and no smoke, its because the current required by the units are small (low wattages), So you may need to locate the fuses. replace then and test again.
Aug 11, 2009 | Audio Players & Recorders
Does not turn on
If you have a friend with a wii try using his power supply to see if that fixes the problem.
You could also try removing the screw that holds the battery and leaving it unplugged for a few minutes.
Here's a pic of where the battery is.
You just need to unscrew that screw and it pops right out.
Jun 19, 2009 | Nintendo Wii Console
Surge causing power outage
A laser printer when warming up draws far more power than your battery backup is equipped to support. Plug it into the surge protector side if you have one, or bypass the battery backup entirely.
Feb 02, 2009 | Samsung CLP 300 Laser Printer
CyberPower 325SL won't work...
NEVER mix surge protectors and UPS!!!. Doing so overloads whoever of the two gets connected to the wall. This equipment is built to be plugged DIRECTLY to the wall. Your unit just crossed it's inner battery. Take it to a recycling center, then stop on your favorite electronis shop and buy a new one.
Sep 14, 2007 | CyberPower 325SL (CPS325SL) UPS System
Hitachi 46ex3bc
I have the same problem with mine. i,m pretty sure that it is the built in surge protector is bad. Try unplugging the tv for 30 seconds then plug it back in and turn it on. If your surge protector has not completely gone bad this might work a few times. mine won't turn on at all anymore.
Nov 24, 2006 | Hitachi 46BX01B 46" Rear Projection...
RCA RT2500 System Logo
162 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
