Everytime i hit the power button on the tv it sqeals for a second but wont turn on and you have to unplug it before it will let you try to turn it on
  • 8,617 Answers
I need the model number in order to assist you with the problem.
Posted on Jan 13, 2010
SOURCE:
I cant seem to power on
Try pressing and holding the button for a second or two. You may also try using a remote control to power on the tv
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Jan 06, 2015 | Televison & Video
Have power but wont turn on
Disconnect the power cable from the TV and then press and hold the power button on the TV for 25 seconds. Now, reconnect the power cable and then try to turn it on.
May 28, 2012 | Computers & Internet
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have a Sharp 32 inch 720p tv, power works, no other buttons do
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
Nov 05, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Timer light blinks on and off and tv wont turn on
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
If ever resetting is no effect then the problem is in the "DM board"
The constant blinking green light means that the TV is not booting up. This is a common problem on this set. Hope it may help you; Regards, VOTIT
Sep 25, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Power lock enable
To get rid of the power button enable you need to either press and hold the power button on the tv ( not on the remote control pad) for approx 15 seconds or if that does not work do the same using the source button
Jun 03, 2008 | ViewSonic N2060w 20 in. LCD Television
50HP66 Plasma TV wont turn on fully. I hit the power button. It goes green for like 3-5 seconds then go back to red off light. It continues this untill I unplug the TV.
did you get your tv fixed? have same problem last night...a loud click and then blank screen and just tries to turn on, can you email at [email protected]
May 18, 2008 | Toshiba Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Ekse
