what does it say in device manager click on mousepad ,click on properties does it s device working ok . in control panel go to input devices /mouse and check if mouse pad is selected to use.
Go to your device Manager , Start computer right click on computer, then click on device manager look on the list of devices for your touch pad and right click and choose disable.
Disabling a touchpad is not required while you are using a USB mouse.
however if you wanted to do it, follow the steps given below depending on your windows
If it is XP follow the following steps
1)Right click on my computer Icon
2)Click on Manage
3)In the left side of this window click on device manager
4)In the right side of the windows you will see the device manager
5) In the device manager screen click on the plus sign adjacent to mice and other pointing devices
6)Now you should be able to see the touchpad listed there.
7) Right click on the touchpad and choose disable.
Note: remember to enable it before you disconnect your mouse, without the mouse enabling it back will be a challenge with your keyboard.
If it is vista / windows 7
Click on start or windows pearl
type device manager and click on the device manager appearing on top of the menu.
and then follow from step 5.
function key is Fn key on keyboard.
these keys might be in orange color
with the help of these keys you can control sound volume. you can adjust screen resolution like brightness .you can also turn off/on wireless features.These keys are like shorcuts keys to perform few functions on your laptop.
To turn off your the finger pad
You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
Open the Control Panel, and then click Mouse. For information about the Control Panel, see Windows Help and Support Center <findinfo.htm>.
In the Mouse Properties window:
Click the Device Select tab to disable the touch pad and track stick.
Click the Touch Pad tab to adjust touch pad and track stick settings.
Click OK to save the settings and close the window.
it's likely that you do not have the drivers for the Broadcom nic loaded. Go into device manager and expand the Network adapter section. If you have no entry for the Broadcom or have a red cross against it (disabled) or there is a question mark agaist an unknown device listed under other then there's your problem.
Drivers can be downloaded from the DELL website.
Otherwise it could be the cable you are using or where it's connecting into.
start menu, right click my computer, manage, device manager, check if the base system device or unknown device has a yellow question mark next to it, if so download the correct driver from dell.coms support/downloads section, yuo will need to select your model and operating system.
I don't believe so, I believe that it's integrated into the system. However, if it does have an enable/disable function, you will find it in either the device manager, or the system bios. If it's not in either of these, then you won't be able to disable it without removing it completely.
