Question about Bunn BT10B Coffee Maker
Taste My bunn has aquired a strange taste to the coffee.
    Problem Solver:
  • 5 Answers
Check your water supply lines if your unit is hooked directly into a water supply. Your unit either has to be cleaned (de-limed) or your water source is bad. You could try using filtered water, but if you have residue inside the unit it must be flushed with a professional delimer if white vinegar doesn't do the trick.
Posted on Feb 09, 2008
Try really cleaning the basket that the water and coffee or cocao goes into. If you don't really clean it well, it will have the taste of the last thing brewed mixed in with the new brew. Coffee followed by coffee should not be a problem, but coffee followed by cocao will give the cocao a coffee taste, and visa versa.
Nov 21, 2013 | Bunn My Cafe MCU Universal 4-in-1 Single...
Unless I use two filters, the coffee is weak. Are the Bunn filters thicker than others?
I have seen so many complaining about this. It is kind of taste. Some people like, some not. I have to buy some other brands filters to get a little bit stronger coffee. Try other brands of filters.
Mar 01, 2011 | Bunn 10 Cup Home Coffee Brewer
I had a stick of butter laying on top of my bunn coffee pot and some butter leaked through the vents. the coffee tasted terrible so i cleaned it with vinegar and ran about 10 pots of clear water through...
Believe it or not I had a customer once that left 6 pounds of butter on top of one of our brewers. They had it cleaned up on the outside so it took me a while to figure out what had happened but I could taste the rancid oils.
We ran about 20 pots of just water through it... make sure you let it heat back up before each one. I think the only thing vinegar might help with would be lime/calcium build up so I wouldn't think it helps this particular situation.
Dec 21, 2010 | Bunn BT10B Coffee Maker
How many ounces or cups of ground coffee is standard for a Bunn dual dbc to make a 1/2 gallon of brewed coffee?
For a half gallon of brewed coffee you should start with a "volume" measure of 10 oz. The reason I recommend a volume measure is because the weight could be completely different using light roast or dark roast coffees. Brewing by volume you can have consistency throughout. The main object is to have the same surface area of grounds for your brewing. The 10 oz. volume should equal between 3.75 and 4.25 ounces by weight. Adjust by taste to your palette but don't sway too low in amount of grounds, otherwise you will stand to "over-extract" and your coffee will taste bitter and will have no body or mouth-feel.
Oct 12, 2010 | Bunn Dual SH DBC
What can I clean my Bunn proffessional coffee maker with ?
mcdevito75 here, Contact Bunn for their recommended cleaning material for your coffee maker, or see any large store that carries coffee makers for their cleaning kits.
Jul 11, 2010 | Bunn VPR Coffee Maker
My Bunn is taking forever to brew and the coffee
It sounds like the thermostat might be allowing the water to boil and cause the grounds to be scorched and making your coffee bitter. It also could be caused by the machine needing to be cleaned and delimed. I would recommend you do this first-and if you don't have the use and care manual, you may call Customer Service to have one sent out or access one at @ home, then products.
Apr 09, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
My brand new Bunn BX... despite following exact measuring for the perfect cup of coffee, and trying various stronger measurements, my coffee comes out tasting like water. When I look at the grounds after...
It sounds like you might be missing your sprayhead. If you remove the filter basket and look up above it, there should be a dome piece with 5 holes in it. If not, please call customer service with the model and date code and we can provide you with a new sprayhead.
Dec 25, 2009 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Coffee has a greasy taste
You will need to pull you coffee maker out and take the top off and clean inside the water tank. Someone has put coffee from pot of old cold pot of coffee back threw. or something loke this. just clean inside and out. clean coffee maker and pots. hope this helps
Have a cup on old saw
Aug 09, 2009 | Bunn VPR Coffee Maker
Bad tasting coffee
you can always clean a coffeemaker with vinegar, but always pour in cold, so you can do it twice or more, but dont re-use the stuff you just used, wait till it's cold or just use some other.after use clean by let water through 2 or 3 times, (also only cold water)
Jan 28, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Bunn BT10B Coffee Maker Logo
153 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
