Question about Maytag MDBH945AWW / MDBH945AWQ / MDBH945AWB Built-in Dishwasher
Dishwasher won't start
I have a Maytag MDBH945AWW dishwasher and when I try to start it, I hit cycle and hit start and the cycle light comes on, but the dishwasher won't start. I tried resetting the switch and still no luck. Any suggestions?
Thanks,
Pete
  • 63 more comments
  • Schoms Feb 09, 2008
    The cycle select button lets me cycle thru heavy,normal and light. I shut the circuit breaker off for 1 minute and also turned the switch underneath the dishwasher off. The switch underneath is in a box, similar to a light switch. Is there another reset button I should be pushing? Could the control pad be locked somehow and how do you unlock it? I know there is a lock symbol by the "heated dry" button. I hold this down for 3 seconds and nothing happens.
    Also, The cycle select button lets me cycle thru heavy,normal and light with the light coming on, so I know there is power. I shut the circuit breaker off for 1 minute and also turned the switch underneath the dishwasher off. The switch underneath is in a junction box, and is similar to a light switch. Is there another reset button I should be pushing? Could the control pad be locked somehow and how do you unlock it? I know there is a lock symbol by the "heated dry" button. I hold this down for 3 seconds and nothing happens. I have had this problem once before and the dishwasher finally started working after numerous resets and tries. I have also tried to pour water into the tub and to prime the pump seal, but this did not work either. Please advise.
    Thanks, Schoms
    Dishwasher will not start. See all other comments below.
  • Anonymous Mar 11, 2014
    Oxygen sonsor
    water pressure loss kb9030
    msi pm8m3-v audio driver
    Turn tv on and after a few seconds it turns off
    laptop thinkpad disable on r61
    it starts working then stops abruptly when there is a bleeping noise and i have to get it off the mains as it does not go off even if i press the off button.once on the socket it starts again then after a min starts bleeping and then goes off
    jura ena 4
    Check ink U051 ?
    bmw e46 misfiers eml on
    no signal from sky decoder. How to connect my sky decoder to flat panel television samsung
    when in heavy traffic for a long time an then start moving again the won't shift into 4th gear
    How do I get a confirmation page to print for my Canon Laser Classs 710 Super G3 fax machine?
    my email address become invalid, what to do ?
    After hitting print sign I get open in chrome, open in safari etc then when I hit one of these a page comes up completely different from the statement. Then I hit print sign and this page prints. Is my statements locked somehow?
    The camera wouldn't turn off so I charged the battery. Now the green light won't turn off and the camera does not respond to anything.
    nortel networks phone change display
    aor conditioner blows hot air
    THE SUN ROOF COVER ON INSIDE WILL NOT CLOSE OR OPEN EXCEPT WITH THE SUN ROOF
    Bobbin case doesn't go into the shuttle, shuttle of timing
    the air bag light flashes how to fix it
    i HAVE HAD POOR GAS MILEAGE FOR
    Where is tray 2 and how do I print the name badge?
    How to adjust chain on 1991trailboss 350
    Keep getting a "wrong disc" message whatever type of dvd or cd we try to play in the recorder. Any idea what is causing this?
    when we play a dvd there are no voice sounds but music can be heard can see the pictures
    Won't sew totally straight - small zig zag!!
    where is the shift solenoid on fait stilo
    PS3 60GB went to a black screen during a game and stayed that way
    WILL NOT SYNC
    I installed micro sd card, now my Camera won't work.
    Should the glass plate go round when just using it has an oven
    How to thread a bobbin singer 5050c
    where is defrost timer 2010 frigidaire side by side
    Washer does not agitate or wash a load The spin cycle works
    Alcatel fierce keeps restarting
    how do i replace the kit on the clutch master cylinder
    2003 cadillac escalade problem leefft rear door ajar, no interior lights no horn no self looking problem wiht larm
    need a manual
    crusie control went out while driving my 06 accord
    won't work
    Bulb not working and clock not showing the time
    As there is no illumination in the clock, no other signs of anything not working
    engine keeps racing then slowing down when ticking over
    We are not getting any cold water at all. The cold is mains connected with the hot connected to a pump. When you turn the dial to cold it starts to trickle with hot water and no cold at all
    Will I be able to download maps for Europe to my PMD-B100 GPS and if so, what website would I go to.
    code p0050 2010 gmc acadia
    high beams on one side nothing on theother side
    door open dash light on when all doors are closed
    sc546
    rear seat bolt stripped 2001 v-star 1100
    I have a 2005 Chevrolet Silverado from Canada, how do I change from Kilometers to miles on instruments?
    CHEC ENGINE LIGHT ON JUST GOT GAS AND CAP IT TIGHT
    What does the thermostat light mean on a 2003 new beetle
    Took soap powder out then stopped showin fo2 on screen
    What does "File cannot be created. Please use another prefix?" mean on my my Epson V300 scanner.
    where is the pin to open the nordic track 750 pro
    99 grand cherokee what size socket do i need to take off the front wheel hub
    water is leaking from the front right corner of my samsung front load washer
    fuse is ok
    remove lens filter minolta af 35-80
  • Anonymous Mar 12, 2014
    I have a laserjet 4200 printer on work network. Now network adapter on this printer doesn't work. I dont knopw, what happening, because him correctly work until power button on him has been turned off. After turned on, network adapter does not recognized, so, does not work, but printer is working corectly. Who can say, what is it, also, how to correct this problem? Thanks...
    2009 gmc sierra v6 4.3 1500 hot engine ac off light is on?
    My car can not speed beyond 40 km/hr
    Guru:
  • 1,894 Answers
Your circuit board needs to be serviced fully once..
the controller in the board will have to be reset..
and so dont worry..
just replace the board,
since you have got this problem before you may even get it once again in future..
so go and change the circuit board..
this wil get you fixed..
thank you..
Posted on Feb 09, 2008
    Genius:
  • 1,665 Answers
If your dishwasher doesn't work at all, check these: Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired
  • 770 Answers
Try these:
Control Board
Check incoming voltage to Control Board.
Membrane Switch
Check for proper operation of Membrane Switch. See
membrane readings on the Technical Sheet located
behind toe panel.
NOTE: Make sure the pin connectors are making proper
contact with pins on the Control Board. If the
voltage is correct into the Control Board, and the
board will not activate, replace board.
Water Access Valve
Check to determine if the valve is turned on and water is
available to the Dishwasher. Check water pressure.
Circuit Breaker/Fuse
Check for tripped breaker or blown fuse. Reset or replace
as necessary.
Door Latch
Check door switches for continuity. With door switches
engaged, no continuity, replace switch.
Float
Check float position. If in the up position, check for
obstruction or disengagement from the Float Switch Arm.
Float Switch
If the float is in the down position, check the switch for
continuity. If no continuity, replace the Float Switch.
Water Valve
Check Solenoid for continuity. No continuity, replace
Water Valve. Check Inlet Screen for restrictions. Clean
screen or replace Water Valve as necessary. (See section
5).
Wiring/Electrical Connections
Check for loose or frayed wire terminal connections.
Check for broken wire within harness. Repair or replace
as necessary.
NOTE: Low water pressure can result in failure of the
Water Valve to close properly.
Float
Ensure that the Float isn't stuck in the down position.
Check for sediment buildup. Clean and/or replace as
necessary.
Float Switch Actuator Lever
Check the actuator lever on the bracket. It must be able
to move freely. Repair or replace as necessary. (See
section 5).
Float Switch
Check Float Switch for continuity with the Float in the up
position. If continuity is present and Float moves up and
down freely, replace Float Switch.
! WARNING
To avoid risk of electrical shock, personal injury, or death, disconnect electrical power source to unit and discharge
capacitor through a 10,000 ohm resistor before attempting to service, unless test procedures require power to be
connected. Ensure all ground wires are connected before certifying unit as repaired and/or operational.
  • Gary Davd
    Gary Davd Feb 09, 2008
    To Get inside the front panel Instructions
    Inner Door Panel
    Removal of the Inner Door Panel will allow access to the
    Microprocessor Board, Door Switches, Detergent / Rinse
    Aid Dispenser, and Vent Assembly.
    Removal
    1. Disconnect power to the machine.
    2. Open the Dishwasher door.
    3. Remove the 11 Torx™ screws along the sides and
    top of the Inner Door Panel.
    4. Separate the Inner Door Panel from the Outer Door.
    5. Disconnect wires from the Vent and Dispenser Wax
    Motors before pulling the Inner Door Panel away
    from the Dishwasher.
  • Gary Davd
    Door Latch & Switch Holder Assembly
    Two Door Switches are used in the Latch Assembly. Both
    switches are normally CLOSED and will open only when
    engaged by the Door Latch mechanism. Each switch is
    in series with respect to L1 and neutral line operations.
    Failure of either or both switches will result in rendering
    the Dishwasher inoperative.
    NOTE:
    Door Switches require no field adjustment.
  • 796 Answers
The problems for dishwasher not working are
    Genius:
  • 3,422 Answers
If the unit won't start, but "hums", then the motor itself may need replacing (you need to check for 120V at the motor harness). If the control itself is bad, then you would have to replace the control. You mentioned that the door didn't work right - if that is the case, the door switches may not be making contact properly, thus preventing the motor from starting (the door has to be closed properly for it to start).
If you have any other problems please ask me.
Goodluck,
Please don't forget to rate me as fixya
    Sergeant:
  • 261 Answers
Try resetting the unit by shutting off the circuit breaker first for 1 minute then try the reset button. If nothing happens, then i would recommend having someone take a look at it.
  • Jay Henderson
    Jay Henderson Feb 09, 2008
    Usually to lock buttons or unlock all that is required is a momentary push of the lock button. If you have reset it and also removed power to unit and then tried restarting it and nothing happens, i suspect it is in the control panel somewhere or maybe a bad switch in the unit somewhere. Keep me posted. too bad i wasn't closer. Have a good weekend. Guru Jay
  • Jay Henderson
    Also give these steps a try. I found them online as well.
    How to Start a Stalled Dishwasher
    [Edit]
    You've come home from a vacation and discover your dishwasher will not work. You turn it to start and it just won't work. What to do. Call a serviceman? No. Try this first, before picking up the phone.
    Steps
    1. Initially check to see that the dishwasher has power, by checking both the plug to the washer and circuit breaker controlling the dishwasher.
    2. If the dishwasher has power and still will not operate, pour a fairly large pot of tap water into the inside bottom of the dishwasher.
    3. Close the door and turn it on. In most cases, your dishwasher will start and run normally.
    Tips
    1. The reason this method most always works is because, over time of non-use, your diswaher will lose it's "prime". That is to say that the water in the dishwasher water pump has dried out and requires "priming" for the pump to operate. Adding water to the bottom of the unit restores the "prime" and function of the dishwasher.
    2. Pumps do not require a prime in this application. Gravity provides the priming water by filling the collection chamber. More likely it is that the rubber seal has dried out and is stuck to the metal pump shaft, the water frees it by acting as lubrication. Try adding a little vinegar to the water in the bottom of the machine before leaving, that usually stops this from occurring.
    Warnings
    1. Since this method most always is successful, you won't be needing to call that service man, which of course won't be good for the economy, but very good for your pocket.
    2. On most brands you can also pull the lower front cover of from below the door and with the power off, try to spin the exposed motor by hand, Using a screwdriver, not your fingers.
Maytag mdbh945aww quiet series 200 dishwasher. can't get it to turn on. Any suggestions.
A circuit breaker may have tripped
The wash cycle control may be defective
The fill control valve may be defective
The door interlock may be defective
Sep 08, 2012 | Dishwashers
Disherwasher not rinsing well. Top shelf glasses/cups seem to have food residue. Maytag mdbh945awb
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101;;
May 20, 2011 | Maytag MDBH945AWW / MDBH945AWQ /...
I have a 4 year old Maytag MDBH945AWW and the panel lights come on and I can select cycles... but the dishwasher wont start. I tried holding the start cancel button, tried turning the breaker off for a...
What you need to do is read for continuity and power across the door latch switch. (2 white wires) AND 2 Black wires Both wires must read continuty at the control panel connectors to the power source terminals for the unit to start. Since the control panel lights up I have to assume that the black wire from the door switch has 120VAC on it.
There is also a turbidity sensor that can cause this: http://www.appliancepartspros.com/part_details.aspx?part_id=4114286&image=1
I an not telling you to change parts. You really need to use a meter and follow 120VAC power to find out where it stops when it should be passing through a component.
If you can interpet this diagram....
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=1318099&pkw_=basket&model_id=5177084&NewWindow=1
I do not think at this point you need a control panel. It is possible but... the door switch and the thermistor will prevent the unit from starting.
This is ONE source for replacement parts.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5177084
There are numerous parts sources on line and locally.
Don't give up on your dishwasher too soon. 4 years is about mid life for your dishwasher.
Thanks for choosing FixYa.
Kelly
Sep 23, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
Maytag dishwasher mdbh945aww3 does not start washing. the only button that seems to work is the start/cancel and all it does is turn on all the lights.
you have to get the touch pad replaced. my worked for 11 month, got it replaced (3 weeks to get the part), worked for 1.5 month and broke again out of warranty. time to get a new dishwasher and extended warranty. maytag is total c$%p. Everything is made in Mexico. I think even China makes a better product. WOW did I say that?!?!
Jun 27, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
Drying cycle doen't seem to turn off ....just seems to cook. Had to turn unplug the unit.
if this is electric dryer your heating element had short to ground cause element to stay on even if the dry turn off
Apr 25, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
Maytag Dishwasher-MDBH945AWW
About the only things that move in the cabinet other than the water pump is the spray arms. The lower arm should be screwed down fairly tightly (plastic screw), but the upper arm is held in place with a plastic friction plug--it tends to wobble more. Spin both arms by hand to see if either hits something (have the drawers in). The lower arm has metal clips on the ends which may be coming loose. They are just clipped onto the arm edges. Hope this helps!
Apr 06, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
Will not start
I have the same problem and it turns out that it is the front panel touch pad that cost $185 for the part. I plan to just buy a new washer.
Jan 19, 2009 | Maytag MDBH945AWW / MDBH945AWQ /...
Maytag dishwasher won't start
"unlock" the machine by pressing on '3' and holding for a few seconds. Thats what it says on the back of my dishwasher which is the exact same model.
Oct 05, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Maytag MDBH945AWW / MDBH945AWQ / MDBH945AWB Built-in Dishwasher Logo
641 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
