Question about OKI C7350hdn Led Printer
Oki c5400 I want drum life for oki c5400 drum life black, yellow, magenta and cyan how many???? service_sign@hotmail.com or sign35@gmail.com thank you. (thailand)
  • 32 Answers
Drum life for C5400 is roughly 15000 pages
Posted on Feb 12, 2008
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Aug 12, 2014 | OKI C3200n Led Printer
Colors are not printing the acutal color
It all depends on the meaning of 'not properly'.
Try creating a document with four different squares, or words, of these colours: yellow, magenta, cyan and black. If all of them print (albeit not with the correct shades) it is probably an ICM driver error. But my guess is that only one of those four colors will print badly, due to a defective color cartridge.
The OKI 5150 makes all perceivable colours using cyan, magenta, yellow and black toners, so if one of these malfunctions, the resulting colors will lack the required shade of, say, yellow, and will appear to be "wrong". The yellow colour itself, of course, would simply disappear (the "yellow" you use might actually be 95% yellow and 5% cyan; then the "yellow" square will be printed as a very light shade of cyan, while the other colors - say, 95% magenta and 5% yellow - will turn out almost exact).
Try with the color test and replace any failing cartridge; if all four (almost) pure colours do print incorrectly, it's unlikely to be a cartridge problem, and we'll have to dig deeper.
Sep 09, 2009 | OKI C5150n Led Printer
Oki 5150 color are not print right
You need to replace the magenta drum. Just because there is life left; it's possible it is scratched. Also, take a cotton ball dip in alcohol and wipe the LED's off when the cover is open; those black things that are hanging down from the cover. Also, make sure your drums are installed in the proper spots (magenta in magenta slot). If the toner "rubs off" after it prints... then the fuser is defective.
Jun 25, 2009 | OKI C5150n Led Printer
Oki C5450 error message
The figure after the K drum Life tells you how much life there is left on the BLACK (K) drum. C indicates Cyan, M indicates Magenta and Y indicates Yellow.
Go to the USAGE MENU and look at the K DRUM LIFE setting. This will be a 2 digit percentage value. As you have just seen the message appear this will mean that the drum life remaining is ....whatever the 2 digit value displays.
The life expectancy of a drum is approximately 15,000 pages.
Jun 08, 2009 | OKI C5400 Laser Printer
Okie C5400 giving 162: Fatal Error
Magenta toner sensor error. Reseat drum unit. check toner cart. Take out the key that prevents you from putting drums in wrong slot and swap the whole drum and toner assy with another color, if it follows the magenta unit then that is the problem somehow.
Mar 19, 2009 | OKI C5400 Laser Printer
OKI C5400 - REPLACE DRUM
To replace the drum - leave the toner in place and pull it upwards. This will remove the drum and toner together. Now release the toner from the drum. Fit the new drum - don't forget to remove the orange packing bar and replace the toner. Easy when you know how.
Apr 16, 2008 | OKI C5400 Laser Printer
Oki c5100n printing yellow color offset
What is the stats % of drums if low under 50% change them, soon as you add non Gen you throw a spanner in any attempt to fault find, fix is possible toner more than likely drum/drums, do a print of each colour and change drums as indicated by failure in its colour to print, check transport belt is OK and led heads are clean
Nov 13, 2007 | OKI C5100n Laser Printer
OKI 5600 - Can you do a 'clean'?
Here's the 'secret' sevice manual: http://www.feedroller.com/Store/Service%20Manual/50_53_5600.PDF
I would also (very carefully) check for torn paper around the rollers of the imaging drum that might be rubbing the area.
Nov 09, 2007 | OKI C5200n Laser Printer
OKI C7350hdn Led Printer Logo
271 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
