Removal
1. Support the vehicle on jack stands.
2. Disconnect the negative battery cable.
3. Drain the cooling system.
4. Remove water pump drive belt.
5. Disconnect the coolant hoses at the water pump.
6. Remove the water pump pulley bolts (long bolt removed through the access hole provided in
the body side rail), then remove the pulley.
7. Remove the torque axis mount. See TORQUE AXIS ENGINE MOUNT .
8. Remove the water pump attaching bolts and pump.
9. Clean all gasket mating surfaces.
Installation
1. Using a new gasket, install the water pump on the engine. Tighten the bolts to
specifications. See TORQUE SPECIFICATIONS .
2. Install the torque axis mount. See TORQUE AXIS ENGINE MOUNT .
3. Install the water pump pulley, then tighten the bolts to specifications. See TORQUE
SPECIFICATIONS .
4. Connect the coolant hoses onto the pump.
5. Install the water pump drive belt.
6. Fill the cooling system.
7. Add coolant supplement tablets.
8. Connect the battery cable, then start the engine.
9. Inspect for coolant leaks.
SOURCE: how do you change the fuel pump?
You will have to drop the fuel tank. It is nn the tank. dran fueal use jack stands to surport auto. I use a floor jack ti lower the tank. Take car to un hook the hoses to the tank and the fuel level wires.
SOURCE: try to locate body control module on a 94 buick park ave
BCM --The Body Control Module is located on the right side of the vehicle and positioned under the instrument panel. In order to gain access to the module, it will be necessary to first remove the trim panel.
SOURCE: replace 2000 buick park ave serpentine belt
Firt - study & write down (draw) the belt path,,
and be sure about it..
Then - put a wrench on the nut in the center of the tension pully.. Move the tension pully to loosen the belt.. Pull belt off..
Repeat to put new one on..
Should be pretty easy..
SOURCE: 93 buick park ave Ultra. replacing water pump
Yes. Put a jack under the motor and remove 3 bolts from side of engine and the long center pivot bolt in mount and the 2 bolts that go top down into the frame and loosen the 2 bolts below mount. Jack up the motor until you can separate the mount, leaving the engine side in and removing the frame side. The engine side can be moved out of the way without completely removing.
Testimonial: "answered the question completely and thoroughly!"
SOURCE: 1994 buick park ave, wont crank over,
Pass key is the security system which disables the car if it is stolen. You need the remote or a key with a chip to start the car. go to a dealer, prove ownership with registration and they will be able to help you out
