Question about Brother DCP-340CW All-In-One InkJet Printer
Clean unable 46 : what does it mean ?
Brother 130C notice : clean unable 46
i don't understand this notice . Plz help me
UNABLE TO PRINT AT ALL. SCREEN SHOWS ;
UNABLE TO CLEAN 46.
  • 1 more comment
  • The Phantom Feb 16, 2008
    Unable to carry out routine maintanance- Telephoned the service centre and they stated that it had gone thro the max number of cleaning cycles. need to take it to the service centre to get it serviced
    Can I do this myself without taking it to the service centre?
  • Anonymous Mar 26, 2014
    error 46 unable to clean
  • Anonymous Apr 01, 2014
    error 46
  • 832 Answers
...because you have run the cleaning cycles too much, the waist inktank is fed up! needs replacing. contact brother hotline or try to get one from a service partner which can be found on the brother homepage of your country.
Posted on Feb 10, 2008
2 Suggested Answers
SOURCE: clean unable 46 : what does it mean ?
same
Posted on Apr 14, 2008
Error 50 brother dcp 130 d
on my DCP 130C display appear an errore message "imp. stamp 50". This is an error message in italian language that indicate impossible to print, error 50.
Please, have you some suggestion to resolve this problem?
Thansk in advance
Sep 19, 2009 | Brother DCP 130C All-In-One InkJet Printer
How to solve the clean unable 46error of a BRother dcp-130c printer.
Clean unable 46 means you need a new flushing box. It's where the ink goes when it cleans the printhead, and yours is full. You need a shop to replace it.
Jul 18, 2009 | Brother DCP 130C All-In-One InkJet Printer
Clean unable 46
You need a new ink absorber box which can be purchased from a brother service partner near your home.
www.brother.com
If you have got the spare part (ink absorber box) you have to open the printer:
Do NOT clean the old one! It cant be cleaned: The felt wont take up ink anymore and will stain the machine from inside and the furniture beneath the printer.
After replacing the eeprom of the printer needs reset:
(dcp: use arrow-up and set key to choose the digits. e.g. arrow-up til 8 then set arrow up til 0 then set
mfc: use the fax-number keys.
Stop-button will always go back to maintenance, if you have done wrong)
press menu then start bk-copy then fourtimes arrow up quickly after another.
machine will switch to maintenance mode and light(s) will flash.
press 8 0
press start bk-copy until PURGE 64xx
press 2 7 8 3
Purgecount will be 0000
Press stop
press 9 9 to leave the maintenance mode.
After the mfc/dcp comes up again in normal state the error has disappeared
May 14, 2009 | Brother DCP 130C All-In-One InkJet Printer
Clean unable 46
Hi, check to see if there is any foreign object jamming the print mechanism, check all drive belts. If this doesn't show nup any problems, I'm afraid that you have a failure that will require dis-assembly and repair by a company who deals in these printers.
Apr 12, 2009 | Brother DCP 130C All-In-One InkJet Printer
Unable to clean 46
posted fix in another prob same section
Aug 23, 2008 | Brother DCP 130C All-In-One InkJet Printer
Unable to print code 50
put the right print cartridges in from Brother...brother
Aug 20, 2008 | Brother DCP 130C All-In-One InkJet Printer
Clean unable 46
have cleaned tanks , need to reset counter? any help as to how?
Jun 22, 2008 | Brother DCP 130C All-In-One InkJet Printer
DCP-130C Clean Unable
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
- ready to print
Jan 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
IT means you  need to reset the purge counter in order to that .
For MFC - 240c
1.Enter mainatanace mode by pressing menu button at time of switch on. and leve the menu button when fax/scan/copy/photocapture button start blinking
2.press *, 8 & 0 and drag the this submenu by pressing mono button to get "purge" eg (purge:9624)
3.Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
4.Press the Stop/Exit . OFF the printer .and turn it on.
Jan 13, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP-340CW All-In-One InkJet Printer Logo
1,331 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
