Question about HP OfficeJet 6110 All-In-One InkJet Printer
Error 1517 still thriving--cartridges have been removed and reinserted, now what?
My office jet 6110 all-in-one started to print, jammed, and now is repeatedly saying "remove and check cartridge." On the computer I got error 1517 for every maintenance utility I tried. I also uninstalled and reinstalled the software. I've tried removing and reinserting both cartridges. I also tried turning the printer off and on, as well as removing the cartridge, turning it off, then turning it on, and reinserting the cartridge. I've tried hitting the menu key on the printer but it's not letting me go anywhere... Cartridge or printer? Thank you...
    Master:
  • 619 Answers
Hi , does your cartridge ink hp original? If generic ink try to change genuine ink.
Posted on Feb 09, 2008
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
I changed my ink cartlidge on a 6110 office jet printer but it still keeps saying Remove and check cartlidge
Have you checked that you've removed any tags fully. Sometimes if you remove a tag and there is some left that you haven't spotted they will cause problems.
Failing that, you may have a faulty cartridge. Do you have another cartridge to try?
Feb 02, 2010 | HP OfficeJet 6210 All-In-One InkJet...
After installing new ink cartridge. my multi purpose offic jet 6110 keeps saying "failed to align cartridges" though the cartridges seem to be installed properly. any ideas?
HI
try removing all the cartridges and restart the printer ,it will ask to install the cartridges,install them one by one and then see if it prints an alignment sheet,if it doesnt print it this way there is an option to align print cartridges in the printer drivers, goto the control panel--->printers and faxes--->rt click the printer icon and goto properties,under properties there should be an option for either maintenance or service this device button,when you click it ,it gives an option fro aligning the cartrdiges,
Jul 14, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Where is the ink cartridge located on the HP office jet 6110 prin
if you are to lift the top part of your printer you will see the cartridges inside as shown below:
Lifting the scanner bed exposes the entire paper path and gives your hands plenty of space to replace ink or clear paper jams.
Apr 11, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Always saying remove cartridge
please take a look in the following link "hp office jet 6110 users' manual" page 42-46.
it is too long for me to post the information here.
make sure to follow the procedures outlined in the manual.
Feb 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Cartridge error
Please first check whether there is paper jam in the printer roller or else please check the cartridges is fixed properly
Sep 24, 2008 | HP Officejet 4355 All-In-One InkJet...
Error code 1517--remove and check cartridge
Solution Follow the steps below until the above issue is resolved. All of the following steps may not be necessary to resolve the issue. Step one: Clear any paper or carriage path obstructions Right-click the link below to open a new browser window with specific instructions about how to clear paper jams. When you have completed paper jam removal instructions, return to this point in these instructions to continue resolving a carriage stall. Click here for information on resolving paper jams (c00107909). (in English). Moving the carriage
  1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
  2. Without turning off the product, unplug the power cord from the back of the all-in-one. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
  3. Looking in through either the print cartridge access door or the output paper tray, verify that the print cartridges are locked into the carriage and have not come loose. Also verify that there are no obstructions under or around the carriage to block it from moving.
  4. Verify that the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You may have to reach through the output paper tray to access the print carriage.
  5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
  6. Press the On button to turn on the product.
  7. Try the print job again to see if this step resolved the issue.
    • If the issue is resolved , you do not need to continue with the rest of the instructions on this page.
    • If the issue is not resolved , continue to the next step.
Step two: Ensure correct installation of the front panel overlay If the front panel overlay, or bezel, is incorrectly installed, the product may indicate a false carriage stall error condition. If the product has not been set up before, ensure correct installation of the front panel overlay by following the instructions below. If the front panel overlay is already installed, and your printer has been working for some time, do not attempt to re-install the overlay. Press firmly on the overlay to ensure proper installation of the overlay adhesive or pins.
NOTE: 12If the front panel overlay is already installed, proceed to the next step.
  1. Insert the two tabs of the bezel into the top slots on the unit. Figure 1: Inserting the tabs c00303994.gif
  2. Tilt the bezel down and press firmly. Verify that the tabs lock into position and that the cover is even with the edges of the unit. Figure 2: Locking the tabs c00303995.gif
  3. Try the print job again to see if this step resolved the issue.
Step three: Plug the product directly into a wall outlet Verify that the product is properly connected to a suitable power source by following the instructions below.
  1. Verify that the computer and the all-in-one product have a three-prong power plug.
  2. Unplug the power cable from the back of the all-in-one.
  3. Unplug the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
  4. Plug the power cable into the back of the all-in-one.
  5. Try the print job again to see if this step resolved the issue.
      NOTE: If the product prints when plugged directly into a wall outlet while unplugged from any power strips or surge suppressors, the power strip or surge suppressor may not be allowing sufficient voltage to reach the product.
Feb 09, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
188 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
