Question about SanDisk Sansa e250 MP3 Player
Charging sansa mp3
When I plug to my computer using usb battery indicator on mp3 is not flushing to be charged what to do frank
  • 54 Answers
Try putting it into recovery mode. you can do this by putting the hold sign to where it shows orange, then holding the record button down while holding the power button down and continue to hold them at the same time. make sure your sansa is plugged into the computer while you put it into recovery mode. for more information here is a link to the forums where they tell you how to put it in recovery mode http://forums.sandisk.com/sansa/board?board.id=e200
Posted on Feb 13, 2008
The mp3 player was defected thank you.
Posted on Feb 18, 2008
My sansa mp3 will not charge on my computer it just drains the battery instead. I have tried rebooting my computer but it still will not charge.....help I miss my music !!
Not all computer USB ports put out enough current to charge the battery. If you're plugging the Sansa into a USB hub, try plugging it in directly. If there's another USB port available, try that.
If that doesn't work, you may have to get a separate USB charger, as used for some cell phones.
Also, bear in mind that when the Sansa is connected to a computer, you can't listen to your music on it.
Oct 21, 2010 | SanDisk Sansa e260 MP3 Player
HI, MY NAME IS ANGELA. I PURCHSED A SANSA MODEL
The Sansa charges via the USB cable. Fully charged, it should be good for 12-15 hours of playing. Be aware that not all computer USB ports put out enough current to charge external devices. If your computer doesn't charge the Sansa, try a different computer. You can also charge the Sansa using other USB charges, such as you'll see for charging cell phones from a wall outlet or a car cigarette lighter.
Jul 23, 2010 | SanDisk Sansa e250 MP3 Player
Will my mp3 player (sandisk sansa m230) charge
Assuming the computer puts out enough juice, yes. Not all USB ports do.
Plug it in, and the Sansa should say "Charging" if it is charging. If it doesn't, try a different USB port if possible. If your computer has ports on the front/side and on the back, the back ones are more likely to put out sufficient power.
Apr 29, 2010 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
I recently bought sansa e270 and i am facing problem that i could not charge when it is connectd to the pc. Its showing just connectd, but no symbol of charging. whats the problem,what should i do to...
Hi
Check the Manual
User’s Guide
Hay Don't worry it will work
Note: Some low-power USB ports may not be able to provide enough
charge power. Also note that rechargeable batteries may
eventually need to be replaced as they have limited charge
cycles (which vary with use and settings).
Li-ion Battery
The Sansa e200 MP3 player comes with a replaceable and rechargeable
lithium ion battery. To use the player for the very first time, remember to
fully charge the Li-ion battery. You can charge your Sansa through the USB
port of your computer, a car adapter (not included) USB port, or AC adapter
(not included) USB port.
Please execute the following instructions for charging the battery using
an USB port.
1) Connect the smaller end of the USB cable into an available USB
port on the computer
2) Connect the larger end of the USB cable into the dock connector of
the player
3) The computer must be on for most USB ports to charge your
battery. Your Sansa will show connected and the yellow charging
indicator will appear. The battery level indicator will blink while
charging. You will not be able to play while connected to the
computer USB.
4) To stop recharging, disconnect the cable.
The battery can also be charged using an AC adapter (not included) or
a car adapter (not included) and you will be able to play your device
while charging with one of the adapters. The battery will reach
approximately 70% charge in 2.5 hours and full charge in about 3.5
hours. It is recommended that you fully charge your Sansa e200
before the first use.
Jan 04, 2010 | SanDisk Audio Players & Recorders
How do i charge my sansa mp3?
  • Step 1:Plug the appropriate end of the USB link cable that came with your SanDisk MP3 player into the MP3 player itself. The port for this cable can be found on the right side of most models of SanDisk MP3 players.
  • Step 2:Plug the other end of the USB link cable into a free USB port on your computer. This will effectively connect your SanDisk MP3 player to your computer.
  • Step 3:Turn your computer on. This will cause your SanDisk MP3 player to automatically begin drawing power from the computer and charging its battery. On the screen, an indicator light will flash yellow while the player is charging.
  • Step 4:Disconnect the cable from both your MP3 player and your computer when the device has finished charging. You will be able to tell when the charge is complete when the indicator light that previously was flashing yellow appears as solid green.
  • Sep 17, 2009 | Audio Players & Recorders
    Will not take a charge. took two charges prior but has now stopped
    I found this online at www.sandisk.com under warranty and manuals link.
    I believe they have an excellent Return Authorization system, that if you truly have trouble with your disk player and it's still under warranty, gather your receipts and get on line to get an RMA. I have successfully returned to disc players that were infact faulty (FAT problems) and received two replacement players. Get on it right away. Look at the manaul online too. IT can be very helpful. I've included the Battery info, and the link for the manual at the end.
    Battery
    The Sansa
    Clip player comes with an internal rechargeable battery. To use the player for
    the very first time, remember to fully charge the battery. You can charge your Sansa
    player through the USB port of your computer, a car adapter (not included) USB port, or AC
    adapter (not included) USB port.
    Charging
    To charge the battery, please follow these steps:
    1. Connect the larger end of the USB cable into an available USB port on the
    computer.
    2. Connect the smaller end of the USB cable into the Sansa
    Clip player.
    3. The computer must be on for most USB ports to charge your battery. Your
    Sansa
    will show connected and the yellow charging indicator will appear.
    The battery level indicator will blink while charging. You will not be able to
    play while connected to the computer USB.
    4. To stop recharging, simply disconnect the cable.
    The battery can also be charged using an AC adapter (not included) or a car adapter
    (not included) and you will be able to play your device while charging with one of the
    adapters.
    NOTE: Some low-power USB ports may not be able to provide enough charge
    power. Also note that the rechargeable batteries are not replaceable.
    http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
    May 12, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
    My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
    This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
    Make sure that the USB cable is properly plugged in and use the original cable.
    Computer in Hibernation mode
    Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
    USB Port 2.0
    Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
    USB Port location
    Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
    Battery
    Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
    Latest firmware
    Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
    I hope this helps, and don't forget to rate the answer.
    Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
    Sansa clip wont power up unless hooked up to usb
    Windows XP SP2
    • Windows Media Player v10
    • Intel Pentium class PC or higher
    • CD-ROM drive
    • USB 2.0 port for hi-speed transfers and charging
    Make sure HOLD button is not on.
    Battery
    The Sansa
    Charging
    computer.
    Clip player.
    Sansa
    adapters.
    Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
    When i connect my sansa clip 2gb it will not charge. it say connected and then goes off. I thought it was charging but when i checked it the battery had died what do you suggest i do to get it working...
    Check for the following:
    USB Cable
    Make sure the computer isn’t entering hibernate or sleep mode while the device is connected.  The computer must be on in order to charge your player.
    USB Port 2.0
    Make sure the player is connected USB 2.0 port (1.1 occasionally causes charging problems).
    USB Port location
    Battery
    Latest firmware
    Jan 23, 2009 | SanDisk Sansa e250 MP3 Player
    SanDisk Sansa e250 MP3 Player Logo
    109 people viewed this question
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Computer Repairing
    Computer Repairing
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
