Question about HP Deskjet F340 All-In-One InkJet Printer
Shows it's offline
HP Deskjet F340 All-in-one shows it's off line
    Guru:
  • 731 Answers
Hi,I was working for HP as Sr. tech support for 18 months in All in One printer Department, newly joined at Fixya to test my technical skills.
Step 1.Unplug the USb and reconnect it.
Step 2.If that doesnt works, right click on the printer ICOn in the control panel ->Printer and faxes.Check whether do u see "use printer Online".If u see it click on it and then check the printer,If it doesnt works or If u dont see the option "Use printer ONLINE".Go to Step 3.
Step 3:
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP DESKJET F300)
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Thank you.
Posted on Feb 09, 2008
2 Suggested Answers
My printer status show offline eventhoungh i'm online.It can copy(photostat) the document but it cannot print.I alrerady change the printer port but it still offline.My printer is HP Deskjet...
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
Dec 26, 2010 | HP Deskjet F340 All-In-One Printer
How to clear a error message on my f340 deskjet
When I try to print something it shows a Error----Offine
Dec 06, 2010 | HP Deskjet F340 All-In-One Printer
Hpdeskjetf340....showing status offline.....
make sure all the cables are conected correctly.
go to printers properties and select hpdeskjetf340 , like default printer.
May 12, 2010 | HP Deskjet F340 All-In-One Printer
My printer shows offline, how do I fix this
Hi
If it says printer offline then it can only be that your leads are not in the printer right. or it switched off, if it keep on saying this then I would reinstall the printer driver CD software.
All the Best Pineworks
Feb 09, 2010 | HP Deskjet F340 All-In-One Printer
Hp deskjet f340 series keep showing offline
hi,
follow the steps:
>unplug the usb cable from the back of the printer
> go to the printers folder inside the control panel
> right click on the printer icon and then click on delete.
> if the printer icon is deleted and if there are no more printer icons related to your printer, plug the usb cable back to the printer and wait for few minutes while it automatically installs the driver.
NB: if you are unable to delete the printer icon. then right click and click on "pause printing" and then again right click and clear the documents in queue. if it is done then delete it.
if you are unable to clean the documents in queue, then
click on Start-->Run, type "services.msc" and click ok.
Double click on print spoolers and then click on "Stop" and then click on "Start". Restart the computer. then try to delete the printer icon.
Thanks and regards,
Agnel
Feb 29, 2008 | HP Deskjet F340 All-In-One Printer
Useless printer f340
HP gear is troublesome all right. Sounds like the drivers and software necessary to catch the button push on the scanner is not installed or working correctly (this is separate usually from the other drivers and so forth). Try reinstalling all of the HP drivers and utilities from the latest versions on their web site.
Good luck...
Nov 13, 2007 | HP Deskjet F340 All-In-One Printer
Another Offline error problem
Go to your printer in control panel and right click on it and de-select off line.
Feb 23, 2007 | HP Deskjet F340 All-In-One Printer
HP Deskjet F340 All-In-One InkJet Printer Logo
317 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
