Question about Optoma H27 DLP Multimedia Projector
Optoma H27 I just bought my projector off ebay and when I received it, I hooked it up to my PS2. The picture was good for about 2 minutes and then the pictures started to flicker and the colors started to bleed and turn hazy and purplish. Do I need a special cable for hookup or is there a solution available. Maybe the guy just sold me a bum projector :( He said it worked great.
  • tbone11 Feb 24, 2009
    I have the same problem with mine.....but it takes about 40 minutes for it to start happening.....at least it does when I watch movies or TV. It just started happening and I've had the projector for about 3 years. I changed the bulb to no avail!
  • Anonymous Apr 15, 2009
    Same thing here!! i've read that it could be a color wheel problem. I have taken mine apart and the color wheel has red, green and yellow? Not sure but i think the yellow is supposed to be blue...
Optoma H27 fan failure
hi Sir,
why you not go to ebay for help?
it has two fans, one is 70*20mm AXIAL Fan, another is 50*20mm blower fan, which one goes bad?
find out and just replace it, it will be ok.
Jul 30, 2014 | Optoma Office Equipment & Supplies
My projector suddenly all the whites went pink
Any solutions yet? mine just did this after 2 months
May 04, 2012 | Optoma PT105 PlayTime Projector
Optoma 72 projector goes black after 2 minutes Projector stays on but no picture
Does the lamp go off, or does the "shutter" block the light out.
Mar 22, 2011 | Optoma HD70 DLP Projector
I have an OPTOMA H27 projector, I am experiencing problems with the quality of the video images displayed. I set the focus by using the internal menu as an image reference. However when I view DVD/Video...
hi,
if u are using the composite video the try component video. composite video will dive u a dull image than component one. also check the distance between the projector an screen.Make sure the projection screen is between the required distance 4.9 to 40.7 feet (1.5 to 12.5 meters) from the projector.
ok
Dec 30, 2010 | Optoma H27 DLP Multimedia Projector
Optoma ep716
Go to the onscreen menu and check lamp settings. Disable auto shut-off.
Nov 09, 2008 | Optoma EP716 Multimedia Projector
Color problems
i don't know if this will work but..... I have an Optoma h27 and we were having problems with the color and ours is mounted on the ceiling in inverted also; and after two years we started having color problems, come to find out that on the menu there is a option for high altitude and that had been turned to the "off" position (probably by our kids resetting all the options and not turning this one back on)..... after taking it to a tech that cleaned it for $97.00 and said there was no problems he could find, we played around with the remote/menu and came across this high altitude option and when we saw it was on the "off" position, we put it to the "on" position and another fan inside the projector came on and that helps to keep the inside of the projector cool at all time and helps from the color becoming weird..... Try this on yours and hopefully that will solve your problem.
Sep 14, 2008 | Optoma HD72 Multimedia Projector
Help needed for Optoma EP 719 DLP PROJECTOR
It's a setting in the menu. A few minutes poking around will fix it.
Jun 12, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma h27 colour issues
Check to be sure that the projector is in the correct mode. If it is expecting an RGB signal and you send it (Y,Pr,Pb), you will see the picture as you describe. The same works for the above reversed. In all likelyhood, you are sending RGB and the projector is expecting the other.
Dan
May 07, 2008 | Panasonic PT-LB10VU Multimedia Projector
Open Questions:
Optoma H27 DLP Multimedia Projector Logo
117 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
