Question about Mercury P4VM800M7 Motherboard
NO display P4VM800M7
When I on my system no display on moniter. One thing i notice there is no beep sounds on my cpu.
  • 33 Answers
This type of problem is so common nowadays. What I did is open up the casing, pulled out the RAM and by using pencil eraser, rubbed the contact pattern. Put it back and turn on your computer. Always work for me and hope it might work for you too.
Posted on Feb 09, 2008
CPU fan & PSU fan working but No display coming to the screen
There should be some sort of beeps then. No beeps is an indication the CPU or RAM is not seated properly. You need to refer to board manual if there are beeps.
There is also the matter of... Never mind I just noticed the CPU is an 8 core CPU, but the board supports quad core.
Board specs
http://www.gigabyte.com/products/product-page.aspx?pid=3833#sp
CPU Specs
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103960
Double check my findings and go from there. Good Luck
Dec 11, 2012 | Gigabyte Technology gigabyte Ga-78lmt-USB3...
My Viewsonic monitor flashs but noscreen display. Is this the power supply
If the light (yellow or pink) is flashing, your monitor is well. It's your CPU that is not giving a video signal to your monitor. Try to reset and notice if your CPU beeps. If it doesn't beep, then there is something wrong with the CPU... or the CPU's speaker.
Regards!
Jul 09, 2009 | ViewSonic (A-AD-0114-0011) Power Supply
It does not start, gives one long beep (about 2-3 seconds) silence and beep again
Switching DDR cards solved the problem. I was getting long beeps every 2 seconds. No short beeps. Just one long beep every 2 seconds. Thanks Josh Whitehead.
Apr 23, 2009 | Computers & Internet
5 beeps and no display
5 beeps is processor(cpu) failure
are they long? short?
Try another processor on the computer and see if it works.
do you get the same beeps if you place the old card back in?
Whats the brand and model of the motherboard?
its reads between the cpu and memory and also between the expansion slots, and possibly on top of a heatsink
let me know
Thanks,
Ekse
Feb 17, 2009 | ATI RADEON 9800 PRO (256 MB) Graphic Card
When cpu switch on processor & power supply fan runs, no display
if you have swolen capacitors you are on the road the failure
buy a new mb and save yourself some time.
hope this helps
Dec 30, 2008 | EliteGroup P4IBMS Motherboard
When I boot my PC up I get a blank screen and a message saying no signal then the screen goes into standby mode
OK, it's gonna be one of these 3 things :
1. The cable linking your CPU to your monitor might not be properly plugged or has been damaged. You should hence ensure that the connection between the two devices has been properly done and that the cable’s state is fine.
2. You might be facing a problem with your monitor if the CPU makes a single beep error sound when you switch on the system. You can check whether the problem comes from your monitor by testing it on another CPU. If you still have “No Signal” error displayed including the error beep, I would strongly suggest you to try to get your monitor fixed by a competent technician or to get a new monitor.
3. If you receive several error beeps when starting the computer, this might be linked to a graphic card dysfunction. You can refer to the motherboard notice or check that the connection has been properly set
Dec 12, 2008 | Computers & Internet
3 beep sound coming
Open your chassis (cabinet) and look for the bios jumper on the motherboard. It is located near the SATA ports next to the Front Auxiliary Fan connector. Put the jumper in 2-3 to enable maintenance mode. This will allow you to enter bios settings. Then redo any changes that you had made, i.e. reset the memory configuration to auto and save the changes and exit.
Now replace the jumper in 1-2 position. Reboot. And your system will work fine.
Apr 16, 2008 | Intel D945GNT Motherboard
No display on moniter but cpu is running
change the RAM(RANDOM ACCESS MEMORY) of your pc.
Dec 12, 2007 | Intel Motherboard
300gl
start system then hit the F8 key and then select "Safe Mode"...if you can successfully get to safe mode, then there is a problem with the screen resolution being too large (video memory or monitor limits)...then restart in standard mode..any change?
Jun 02, 2007 | IBM PC 300GL PC Desktop
Mercury P4VM800M7 Motherboard Logo
61 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
