Toshiba 43A9UE convergence problem
Hi Experts,
my projection tv problem is can't adjust the color convergence. on the screen picture come out are: on top potion there are many lines stake up. on the bottem part is ok. when the screen is on blue background then i can see many curve line at the middle of the screen. curve line is from the left to right of screen. we go to convergence stage try to adjust the color but fail. we adjust the blue color n it can move up/down only, left/right can not mov. for red color, it can move up/down n left/right. we already replaced the conrgence module, problem still unchange. and what else we need to look at. pls help.
best regards.
tan.
  • 3 more comments
  • AHMAN TAN Feb 12, 2008
    halo mr Terryfic,
    i had replaced the module part no. is MDCC11.can you let me know the convergence ic no?
    to what i understand this MDCC11 is the convergence module accoding to the technician informationed. n i will try to check the resistors first then i will give the comment. thank again for the support.
  • AHMAN TAN Feb 13, 2008
    Terryfic thank for the good responce n helpful. there is no STK part# on my set. there are 12 pcs transistor on the big heatsinks. thier no. are A1049 n C2028., six pcs each. n already comfirmed good.
    thanks n best regards.
    tan
  • outcaged Mar 03, 2009
    can't adjust the blue lines on the convergence. the blue line gets higher as you go from left to right... Grrrr love the TV
  • Vista Electronics May 11, 2010
    What is the STK part # on convergence amps on large heatsinks
    What is the part # of the DCU replaced ?
    Did you replace the convergence amp IC's ?
  • 8,617 Answers
Check the resistors right next to the Convergence ICs often 1 or 2 of them go oen when the ICs fail.
Posted on Feb 10, 2008
I have a Toshiba 57H82 rear projection tv. It has colored wavy lines on the screen and no picture.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 19, 2011 | Toshiba 57H82 57" Rear Projection...
Re: Toshiba 65 in Cinema Series - 12 years old. Color Separation. Green bow at top center of screen, red and blue double images tilting upwards toward sides. Sometimes clears unassisted after set has...
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 20, 2011 | Toshiba 65H82 65" Rear Projection...
Tv showing two pictures. it is blurry and mostly blue, red in colour
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 13, 2011 | Toshiba 42H81 42" Rear Projection...
Words ars doubled and arching, green and purple across parts of the screen, picture blurred
  • Screen looks 3D
69189a5.pngSOLUTION
Dec 26, 2010 | Toshiba 53HX71 53" Rear Projection...
Picture looks like 3d i have ajusted screen but keeps going back to 3d and picture is bowed
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 25, 2010 | RCA P56923BL 56" Rear Projection...
Seeing double with the picture - a lot of shadows with the picture?
•Screen looks 3D
Aug 17, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Picture appears to be 3d
•Screen looks 3D
Jun 25, 2010 | Toshiba 43A10 43" Rear Projection...
Projection lights
You need to take the Toshiba remote that came with the machine and go into a menu area that deals with convergence. Here's what the manual says:
This TV used 3 separate TV tubes, red, green, and blue. The R, G, and B images are pojected onto the screen wheree they converge to form a full-color picture. You can see a clear picture only when the three images converge correctly. Corvergence my drift over time, or if yo move the TV. I you can see clear images on your TV screen skip this procedure.
Make this adjustment only after the TV as been on for at least 30 minutes.
Press the TOUCH FOCUS (auto convergence) button on the front of the TV at the bottom.
The TV will enter into the convergence mode and adjust the converge automatically (that's what it says.)
TO ADJUST IT MANUALLY:
Press MENU, and the press < or > until the PICTURE menu appears.
Then press UP or DOWN to highlight CONVERGENCE.
Press < or > to display the Center Convergence menu
There's a lot more the book says, but, I can say from experience that you just go through the different sub areas of this menu and converge each color separately, and bingo, it's fixed.
Good luck.
Sep 06, 2008 | Toshiba 43H71 43" Rear Projection...
Projection tv toshiba 43A9UE convergence problem
I would advise you to check the low values resistors around the convergency circuitry as well the fuse resistors and micro or pico fuses as well.
Feb 09, 2008 | Televison & Video
Screen all green
Your set is definatly Toshiba 43A9UE has Chassis A9PJ the parts may be hard to find give Toshiba the Chassis number that should be waht they need. Hope this helps. If you need some part in paticular such as a Green CRT let me know I will try to locate one for you, just would need the tube type and number off the tag on the tube.
Jan 25, 2008 | Televison & Video
Televison & Video Logo
547 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
