TV wont turn back on
MY nec pf68s33 68cm tv stopped after using a universal remote it came up with numbers and switched of at 60 and wont go back on the stand bye light is still on but wont respond at all.It is like i changed the settings for something please help
  • 82 Answers
Have you tried unplugging it and leaving it unplugged for a few hours possibly over night
Posted on Feb 09, 2008
My tv wont turn on by power button or remote. white light keep blinking.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
VW37L 37 in. LCD HDTV input button wont work
Have you find out if the problem is with your remote control? For instance, you are able to control your TV using a Universal remote control. My 32" Vizio TV had a similar problem, initially thought it was related to my remote control but in fact the TV didn't respond either to an universal remote control of my SAT receiver that I eventually use to just turn on and off the TV. I've found out that the problem was with a little board on the TV located at the left down corner viewed from the front side of the TV and that receives the signal from the remote control. I found the board on ebay for about $5, replace it and the TV responded again to both original and universal remotes.
Nov 11, 2013 | Vizio VW37L 37 in. LCD HDTV
I cant manually turn on my tv to progarm universal remote
You have this backwards. The TV does not program the remote, the codes for the TV are generated by the remote. If you cannot turn on your TV by using the power switch on the front, there may be a power supply problem.
Nov 10, 2013 | Televison & Video
NEC PlasmaSync 50MP2 50 in. Television But after looking at the manual I see that I am missing menu options (Option1-4 and Advanced OSM) How do I enable these. This is a hand me down and I've had to get a...
hi mate, did you sort this problem out, i have bought same tv but when u switch it on the rgb2 screen comes up and you cant change it by buttons at the bottom, i dont have a remote either.
what universal remote shall i get and how do i enable the buttons at the bottom
Jul 05, 2010 | NEC PlasmaSync 50MP2 50 in. Television
I digital universal remote RM-810 - need code for
Try 184 for the NEC TV.
Please rate this solution. Thanks.
May 28, 2010 | Universal Remote Control Remote Control
I have an old nec croma vision tv and have lost the remote.I have a spare panasonic remote and want to no the code so i can use the remote with the tv
The remote for Panasonic TV cannot be used to control your NEC TV. For this you need a programmable remote control.
For example visit this site to know more about Universal Remote control. The UniversalRemote can be programmed to control TV, DVD etc. The procedure is givenin the accompanying manual.
If you do not want to invest in a universal remote then visit this site to purchase an NEC replacement remote.
Please try to understand that you cannot simply use any brand of remote to control any other brand of TV; only a universal remote (or a replacement) will help.
Thank you.
Oct 18, 2009 | Panasonic Televison & Video
Nec tv codes for comcast universal temote
You may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Dec 17, 2017 | ViewSonic N3251w 32 in. LCD HDTV
Lost remote need code for universal remote control.
  1. Turn on your TV.
  2. On your Tune In remote, press TV and release.
  3. Press and hold Set until the green light on Tune In blinks once, pauses and then blinks twice. Now release the Set key.
  4. Enter the first three-digit TV code for your NEC from the list which follows:
    030, 056, 019
    These codes are listed in order of popularity, and the green light will blink twice if you perform this procedure correctly.
  5. Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
Now Test Your TVWhy test? Many times more than one code appears to work. Testing is desirable to be sure you have the correct code for your TV or the other devices you are setting up.
  1. Press the Power key to turn on the TV, then press mute, channel scan ("CH") and volume ("VOL") keys. Tune channels 7 and 11 by entering the number followed by the Enter key.
  2. If your TV does not pass the test, return to Step 2 at the top of this page. Enter the next three-digit code and repeat the process.
May 11, 2009 | Televison & Video
Bought a fairly used 2003 HDTV 4 months ago, Didnt come with remote but got a Universal I used that worked, my friend took the batteries out for a while for something else, we put the batteries back in...
Hard to say what the code is without knowing the model number of the remote and the brand of TV.
RCA's website has a remote code finder you can use.
Dec 17, 2008 | RCA Universal Remote 3 Device Remote...
Televison & Video Logo
Top Televison & Video Experts
