Question about Frigidaire GLEQ2152ES Electric Dryer
Dryer Won't Start
I have a Frigidaire Gallery Heavy Duty Dryer that I've had for about 4 years. When I turn the start dial it makes a humming noise but will not start. What is likely the cause?
  • 2 more comments
  • cmh09 Mar 11, 2009
    My dryer was purchasesd 3 1/2 years ago. When turned on it will hum but not tumble.
  • jcbaxter Apr 29, 2009
    I have a frigidaire gallery seires commercial heavy duty drier tried to turn it on it only buzzed at me lihgt is on but will not work
  • Anonymous Mar 12, 2014
    vibration when running my frigidaire heavy duty dryer
  • Anonymous Mar 16, 2014
    noise at end of cycle when spinning
I had the same problem. Talked to my applience guru and got it fixed for free. First remove the cover on the back of the dryer at the bottom left corner. You should be able to see the motor. With an air compressor and blow gun attachment blow out the motor very well. The Frigadaire's have a nasty habit of clooecting lint and fine dust in the motor windings and magnets. After you blow it out very well, and be sure to spin the drum around by hand while doing this so the motor turns and you get all the lint and dust out your dryer sould work just fine. PLEASE remember to unplug the dryer while doing this so you don't electrocute yourself. When done plug it back in and give it a try. I will almost guarantee your problem will be sloved. It worked for mine and it's been working every since.
Posted on Oct 02, 2011
  • 58 Answers
Try to turn the drum by hand
Posted on Mar 12, 2008
  • 82 Answers
Unplug it for a few hours then plug it back up and see what that does first
Posted on Feb 09, 2008
Bad motor or something stuck in the blower wheel
Posted on Feb 27, 2008
  • bikerbojo47 Aug 20, 2011
    After a little research and a Good tech, I discovered that my Frigidaire Gallery model # GLER642AS3 has either a problem with the start motor windings or a bad thermal switch.
    Easy test but takes three hands. Make sure unit is plugged in then open the door. Have your helper hold the door safety switch in and then have them hold or turn the start switch while you manually turn the drum. If the drum starts turning after you give it a little help then it is one of those two parts and will require a digital volt ohm meter to determine which part is needed. The parts are relatively cheap so don't just run out and buy a new dryer. I haven't determined which is bad on mine yet as I need to get to bed but have narrowed it down to one of those two parts and would be happy to explain how to repair as soon as I discover which one it is. I'll also point you in the right direction for the best price on the replacement part and how to repair it. Unplugging the machine is not going to cure the problem.
How to fix a Frigidaire Gallery Commercial Heavy Duty
Good Morning Friend,
I understand your Frigidaire dryer, model# GLER642A, is making a thumping noise when running, and you want to know how to fix this. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician. They will be able to diagnose your appliance and determine what is causing the thumping noise. Hope this is helpful.
-Best Regards-
WP
Jul 07, 2014 | Frigidaire GLER642A Electric Dryer
Frigidaire gallery heavy duty dryer
Good Afternoon Friend, thank you for your question!
I understand you are seeking a replacement dryer belt for your Frigidaire laundry center, GLET1031FS. The replacement dryer belt part number that you would need to order is 137292700.Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). Hope this helps! - Z
May 19, 2014 | Washing Machines
When I push the button to turn on its making a a humming noise and won't turn on. Its less than 2 years old
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2011 | Frigidaire Dryers
We have a frigidaire gallery, heavy duty, stackable washer dryer. The dryer has stopped spinning. No grinding or anthing just not moving. Belt?
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 22, 2010 | Dryers
When I turn the start knob on my Frigidaire Gallery Model GLER341A52 the motor makes a humming noise but nothing else, when I let the knob go it stops. The drum never turns or blower doesnt start it sounds...
Wow, different person, different dryer, same problem, same day. I went and got a complete new motor assembly for $170. I hooked it up, and it is still doing the same thing. So obviously that is not the answer. What did you find?
Nov 19, 2009 | Frigidaire GLER341A Electric Dryer
My Frigidaire heavy duty dryer stopped working. It has worked fine for 15 years. Now when I push the START button it makes a noise but does not start as usual.
The loud noise could be a faulty or worn out motor. Or if the motor is good, the drum bearings might be worn and motor cannot turn drum. You will most likely have to remove some access panels to get a closer look at where the sound is coming from. There is excellent videos and information on howstuffworks.com that will explain the workings of a dryer and troubleshooting and more.
But please feel free to ask any other questions you may have.
Oct 14, 2009 | Frigidaire FEX831CS Top Load Stacked...
The clothes get stained with brown burn marks while in the dryer.
The rear drum support needs replacing.
The front glides and felt seal needs replacing.
May 25, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Dec 20, 2008 | Frigidaire GLER642A Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
696 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
