Question about Sew Smart Compact Cordless 17390B Sewing Machine
I need a copy of the instruction manual for the Sew Smart Compact Cordless 17390B.
I can't figure out how to get the thread in the bobbin. Please help. Thanks :)
  • Anonymous Mar 29, 2014
    Need to know how to thread the sew smart cordless sewing machine
Hi, for the top thread look on a picture on the box.
That is easy. For the bottom:
* Be sure thread is wound clockwize on the bobbin.
Take the thread double like "U" and pull the U-thread
on the slim hook in the bobbin case.
   I have the instruction - but it does not have
clear explanations.
Posted on Apr 23, 2008
  • 1,388 Answers
If pictures are helpful, take a look here
This is for a front loading bobbin
You have not mentioned the machine or model, so if this is not like yours, it will be a top loading or drop-in bobbin.
In either event, the idea is to pass the thread thru a small slot and thereby between a tensioning spring......your Instruction manual will have details for your model, tho' with a little thought, any manual for a similar machine (top or front loading) should give you the basic idea.
If you still have troubles, let us know the make & model.
Posted on Feb 10, 2008
Need manual instructions for Riccar 2910 need help with bobbin, threding machined and tension setting and bobbin holder.
You may be better off going to google and search "riccar 2910 manual" That way you can follow their detail dorections rather then someone elses and it confuse you. Usually the PDF versions have pictures with it :-)
Apr 07, 2016 | Riccar Sewing Machines
Need manual & instructions plus parts
I have sew smart MINIGUHI cordless sewing machine.Its one gear connecting top shaft is broken. Iwant to replace it. From where I can get the Part
Dec 09, 2013 | Sew Smart Compact Cordless 17390B Sewing...
Bobbin thread tangles
check with these sites about a manual, call or email them
sewvacdoctor.com
a1sewingmachines.com
Oct 19, 2012 | Necchi Sewing Machines
When i thread the sewing machine and sew, the stitches do not stay
Possible
you need to change the needle, if it is a little broken at the head, it's not grabbing the underthread.
goog Luck
Jun 23, 2011 | Sew Smart Compact Cordless 17390B Sewing...
I need a new needle
It is tempting to say something about a haystack in reply, could you be a little more specific ?
Can you go to the place where you bought it, or call them ?
If you are in an urban community, find a sewing machine dealer and ask for a replacement to suit the machine you own........if it is less than 20 years old, it will almost certainly take a "flat back" type.
If you are in a remote community, find somewhere on the internet in your own country that will sell you some....just be sure to give details of the Make and Model
Apr 28, 2008 | Sew Smart Compact Cordless 17390B Sewing...
Bobbin
this is some ******* ****!
Mar 22, 2008 | Sew Smart Compact Cordless 17390B Sewing...
How to properly thread the bobbin
From the Simplicity Sew Precious Model SWSP2 manual:
Inserting a new bobbin:
  1. Place wound bobbin into the bobbin case.
  2. Pull about 6 inches of thread out from the bobbin. NOTE: Be sure that the bobbin rotates COUNTER-CLOCKWISE when thread is pulled.
  3. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  4. Slide bobbin cover back into position.
You can obtain a copy in pdf format for free at:
http://www.simplicityhomecare.com/ftp/whitepapers/SWSP2-english.pdf
Sep 21, 2007 | Simplicity Sew Precious SWSP2 Mechanical...
Sew Smart Bottom Threading Problem
There seem to be a number of folks with the same machine - same problem - stitches won't form. Unfortunately, this many of the same machine with the same problem would tell us to return it and look for a different brand/model. We can only suggest the same - but have posted the following for you all to try (posted individually for another reader earlier this morning - just discovered the multiple same issues):
A few things to try:
  1. Loosen the needle screw, make sure the needle is fully up in the needle hole and re-tighten the screw. Vibration can sometimes cause the needle to slip...and the needle not fully inserted can cause this problem.
  2. Make sure the bobbin is turning the proper direction. If your machine has a standard bobbin case that comes out of the machine, turn the case so the bobbin is facing towards you. Pull the thread tail and make sure the bobbin turns clockwise. If it's turning counter-clockwise, flip it over and try your machine again. If your machine has a drop-in bobbin, double-check your particular machine instructions to make sure it's going the right direction (clockwise or counterclockwise depending on the machine).
  3. Make sure you have tension on the upper thread. Do this by lowering the presser foot (make sure the thread tail is NOT under the foot) and give the thread a tug. You should feel tension on the thread. If not, the thread isn't fully down in the upper tension disks. You should be able to give it a further tug to pull it down into the disks. No tension on the upper thread can cause the stitches to not form.
  4. If none of the above seems to help, you'll need to get your dealer involved (provided you purchased your machine from a sewing machine dealer). They can determine if it's just something happening during threading or if the machine is out of timing. They are there to help you before AND after the sale and should be willing to take care of whatever is happening.
  5. If you did NOT purchase your machine from a dealer, and the store you purchased from does not have a sewing machine technician, we would suggest that you return/exchange it for a new machine and see if the new machine has the same problem (most department/big box stores that carry machines have a very liberal return policy since they do not have personnel dedicated to sewing machines).
  6. If the new/replacement machine has the same issue, we would suggest you return it (no sense frustrating yourself) and perhaps find a local sewing machine dealer to purchase a machine from. Authorized sewing machine dealers are geared towards providing machines and service (before and after sale) and are worth the extra $ for the peace of mind and knowledge that you'll have someone local to call on for help.
Best of luck with your machines - we hope it's something minor and you're up and sewing soon! Don't hesitate to reply to this post if we can offer further help, ideas or suggestions.
Happy sewing,
Kim & Linnette
www.sewingexpressions.com
Nov 17, 2006 | Sew Smart Compact Cordless 17390B Sewing...
Sew Smart Compact Cordless 17390B Sewing Machine Logo
732 people viewed this question
Top Sew Smart Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sew Smart Sewing Machine Expert? Answer questions, earn points and help others
