MDP 1070 When the unit is turned on the loading icon turns on and stays there. The disk starts rotating,the disk starts to rotate and increases in speed for about 2 seconds, slows down and then starts to ramp again. This is an endless pattern. What's wrong? here can I get it repaired in the San Francisco Bay Area?
    Brigadier General:
  • 6,966 Answers
Your posted description is indicative that the laser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak burned-out laser eye/lens;
3. defective slider shafting (where the laser eye's carriage moves.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded.
Should this not be corrective, your post for Service Center might be your best bet. Unfortunately to my knowledge, your product was manufactured in China and the US carrying company is out of business, hence no official service center. It was Mintek Digital Inc. of Anaheim, Calif.
Should you still want old info:
Website: http://www.mintekdigital.com
Address: 4915 E. Hunter Ave.
Anaheim, California 92807
Phone: 714-777-3090
E-mail: techsupport@mintekdigital.com
Fax: 714-777-5933
Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Posted on Feb 09, 2008
    Genius:
  • 3,422 Answers
can u tell me whats the brand??
  • 1 more comment
  • Priya darshan Feb 09, 2008
    Actually the problem is with the player itself as it is not able to read the disc.The lens has spoilt i suggest you to get it repaired so that you don't face any problems in future.
    This is the main support no. of Mintek- 727-734-7774/2
    Can you tell me the zipcode of your area so that i can find a service center.
    Here are few tips which are given from your manual:
    • Ensure the disc label is upwards.
    • Clean the disc.
    • Check if the disc is defective by trying another disc.
    If you need anyother help please ask me..
    Goodluck and i hope your problem gets solved soon..
    You can get your DVD repaired By Iritek solutions..
    Contact Number-(408)768-3031
    You can visit there website athttp://www.itritek.com
    They wont charge you much for the repair.
    Goodluck once again..
    Please don't forget to rate me as fixya..
Error message bad disk or no disk
I dont know ,why it gives me a message no disk? what should i do ?
Feb 16, 2012 | Mintek MDP-1070
We get sound but no picture. player. We have the Mintek MDP-1070
try to check the region code setting of the player found in your users manual
May 24, 2011 | Mintek MDP-1070
I need a manual for my MDP 1070. Where can I find one?
Hello
Visit these sites:
www.manualsonline.com/ex/thread/view/idThread/2222007
deltamanual.com/result/mintek-mdp-1070-problems.html
Mar 26, 2011 | Mintek MDP-1070
The unit turns on and the initialization screen appears and a clock like icon appears with the hand rotating and just continues to rotate and never initializes. I tried resetting the unit but it just goes...
If you leave it long enough it should initialise. I had to plug it into mains power so the battery doesn't go flat while it's trying to ido so. But then again, your battery might last longer than mine as mine was a factory repair, so there's a laundry list of issues I've had with it.
Dec 29, 2009 | iRiver H10 MP3 Player
Screen comes on, disk turns, loading starts, and doesnt stop
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
MDP-1030 Problem - Flashing Green LED Power Light
Ihave a Mdp 1070 and from what I have learned is that the Co. has gone out of business for obvious reasons. Fortunately I brought mine at Costco so its going back. But youmight want to try and play a music cd all way through to recalibrate the heads. Dunno if this makes sense but i tried it and it worked for a day then went back to its blank self. The batteries have been recalled due to over heating and exploding so might want to exchange it with whom you brought it from.
Feb 03, 2008 | Mintek MDP-1070
Mintek MDP-1070 dvd player
Ebay! But the MDP 1030 batteries were recalled so might want to think twice. Im returning my whole unit as it continues to not read dvds.
Jan 24, 2008 | Mintek MDP-1070
Mintek MDP-1070
A component lead comprises of 5 phono plugs 3 for pic red and white for sound. If your TV has progressive scan it must have an HDMI connection if so and the MDP also has one that is a better way to connect it.
Jan 17, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
