The most obvious is research for a coder or, biller. Collaboration is another reason. For a biller, how about paperless billing. Job searches for independent contractors. Training is another biggie. What about updates to your hardware and software? Download them across the Internet. The list goes on.
Coder pin? Never heard of that... do you mean Cotter pin? They go through holes in shafts to lock collars to shaft, etc. SOMETIMES they are actually used through a hole in a metal tab sticking through a slot to hold something in place.
p0133 is for the oxygen sensor. It is a slow response. You most likely have a "heated" sensor and it isn't heating up fast enough. This is for the Bank 1, Sensor 1. That means that it is the one in the exhuast BEFORE the catalytic convertor on the back side of the engine ( cylinders 1-3-5)
You can hire a freelance coder to help you with that. All you have to do is post a project and hire a coder from one of these website: vWorker or Scriptlance.
most likely it is a wiring harness problem. maybe rubbing on the steering shaft at some point. May have worn through and broke at the wear spot. The security wiring for the key coder decoder circuit usually is in a harness going to the ignition switch. If it shorts or seperates it will not allow the engine to operate due too no signal to PCM (power control module). The coder/decoder reads the chip in the key and determines if the engine is allowed to be started.
you can get the radio recoded by an independent recoder, look in the yellow pages for radio de-coders they normally come out to you, costs about £20 to £40 some are cheaper.
normally when it says safe mode if you leave the power on the radio for 1 hour safe mode should disable if it is not doing this then it may be faulty.
Regards Dan p.s if you cannot locate a re-coder please send me your postcode or area and I will find you one near by.
1st step; Acquire/buy a cd/dvd rom drive cleaning tool kit from your local pc store.
2nd step; Install a dvd coder/decoder software, try Power DVD player software it has a trial version
3rd step; After installing the DVD coder/decoder from Power DVD player try playing a dvd movie rom disc it should work/play... hope these tips help ;-)
"Media Coder" is a free program you can download that will convert your songs on the shaker to MP3 files. I had the same problem. Make sure the shaker is plugged into computer so that you will be able to choose the songs on it to convert. Very easy to use. Just google "Media Coder" and you should find it.
