Question about Gaggia Titanium Espresso Machine
Coffee not strong enough
I have just bought a new gaggia and the coffee does not seem strong enough ( very weak taste). I have tried different coffees and adjusted the dial in the grinder as far as it will go. Any ideas ?
  • clare1-2008 Feb 10, 2008
    Thank you Pierre. I have tried anjusting quanitity of coffee. Still the same. There is lots of brownish cream on top but taste is not strong at all. Whan i make cappucino it tastes like water. Will try and send back to company to have a look.
  • MartynF Jun 01, 2008
    I have the same problem.  I took the back off the machine and saw that the cog on the grind setting was not meshing with the spokes on the grinder itself. I remedied this but it made no difference to the strength of the coffee.  I have put the bre-brewing on high, cleaned the metal filters but still to no avail.  So its off to the repair shop unless anyone has an online solution.
  • 2,039 Answers
Our waste coffee is it consistant like stay in 1 round piece or loose lock at it if it lock like it was fine grind i suspect that our machine dont grind fine enough our coffee should have that lovely brownish cream on top maybe grinder need ajustment it wasnt done properly at the compagny and you said you adjusted the dial in the grinder but what about the quatity of coffee look in our manuel fine grounded coffee good quatity of coffee our suppose to get that perfect expresso i think ajust our dial for quatity of coffee thanks for using fixya pierre
Posted on Feb 09, 2008
  • pierre laplante Feb 10, 2008
    when you make and expresso owe mush coffee does it give you me to make a desent cappuccino i use 2 expresso our water level is too high if you have that brownish cream that mean good pressure good coffee level use a little expresso cup make ourself 1 when it get almost to the rim it suppose to stop try that let me know pierre
Coffee tastes bad in old and new coffee makers
Have you tried first just running distilled water through it, then again with spring water and then test with enough coffee for 1 cup to see how the cofee taste then. Also you may want to use distilled or spring water when making that one cup of cofee to test.
Dec 17, 2013 | Mr. Coffee Coffee Makers & Espresso...
Weak coffee is the result of brew
Since it is "brand new out of the box" check for plastic burs (pieces of plastic improperly hanging around
openings along flow of water) throughout unit, and use more coffee than recommended for your taste of
what a good cup of coffee should taste like, since that varies from individual to individual. If you are using
packets, try using TWO. Experiment, Experiment...........
Apr 17, 2009 | Regal Ware 15-0264 Polished Aluminum...
Coffee out of the machine seems too watery
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Feb 22, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia Evolution Filtering Weak Coffee
Jan 03, 2009 | Gaggia Evolution Espresso Machine
Gaggia cubika, weak coffee.
Nov 08, 2008 | Gevalia 35411 / 50433 Coffee Maker
No cream on the espresso when dispensed
I was having this trouble with Lavazza beans and Morrisons (horrible) beans. I switched to Formula 6 from James' Gourmet Coffee on the internet and every cup has a great crema layer and good taste.
With the old beans I could get an occasional good cup, it seemed this was more of a problem if the machine had been switched on for a long time before making the cup. I use a Gaggia machine with a Gaggia MDF grinder on 8 or 9 setting, with the new beans I now get a great cup all the time so I'm going to try more the James' range!
Nov 05, 2008 | Gaggia Tebe Espresso Machine
Inconsistent quality of crema and coffee
Sep 19, 2008 | Gaggia Titanium Espresso Machine
Weak coffee and pale crema.
If you get weak coffee from espresso machines:
Jul 16, 2008 | Gaggia Titanium Espresso Machine
My coffee tastes weak
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with a bad burnt taste.
Dec 28, 2007 | Starbucks Barista Utopia
Weak Coffee
Yep, it's the one inherent flaw in the single serve machines - someone else decides what 'the perfect cup of coffee' tastes like.  Quite presumptuous, actually.
Solution I found to be acceptable:  Buy only the extra bold flavors (there's about 5 or 6 varieties) and brew using the small cup size button.  Yes, you only fill your mug about 3/4 of the way, but at least you get a decent cup of coffee.
The ONLY flavor I found to be strong enough when brewing with the large cup control button is DOUBLE BLACK DIAMOND...the rest is crap.
Dec 27, 2007 | Keurig B50 Coffee Maker
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
655 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
