Question about JVC Sirius KD-G300 CD Player
No power press on button have no display lites. insert cd lites come on cd goes in power does not come on lites shut off. tried reset by pressing select & on at same time. no work! display comes on briefly by pressing disp button but then shuts off. have yellow wire to pos side of batt & black wire to neg side of batt??????????????
  • hjrhjrggge Feb 09, 2008
    instruct man said yellow wire was 12v power & red wire was to acc switch. i hooked up both wires to pos side & bingo we have power. the harness was cut off thats the reason. thanks a million
  • 82 Answers
Why didnt you hook it up to your wiring harness and were is the red wire hooked up the yellow is the memory wire make sure you have a good ground
Posted on Feb 09, 2008
Hp officejet 6310 printer has a display green problem. However printer is out of warranty. Kindly help us try to update the firmware.
hi,
simply follow any sets of steps below to solve your problem
partial reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
semi full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
full reset
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
i hope this will help you,
regards,
cseian.
Feb 01, 2011 | HP Officejet 6310 All-In-One InkJet...
I have a brand new PS3 and I did an online update and now when I turn on the console it doesn't do anything. There is no power switch on the back to reset it.
Press and hold the power button until it goes off. If it doesn't work, you will have to pull the plug from the console.
If you get no display when powering the unit back on, try this:
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
If you have a HDMI cable, plug it up, if you have AV plug it in as well. If you have both settings on your TV, be sure to have them both inserted into the system. Also, make sure that you are switching your TV from HDMI to AV and vice versa.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options. Try 1-5
Jan 26, 2011 | Sony Playstation 3 (PS3) Console
I have HP Officejet 5610 All in One printer, When i am switch on the power button the dispaly showing intializing and after a few seconds it shows date & time and then suddenly one noise coming from...
Its time to reset the printer; follow the below steps
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
Semi-Full reset
NVM Reset
Regards
Riztech
Nov 27, 2010 | HP Officejet 5610 All-In-One InkJet...
Printer displays error code 0x838a2200. Unable to reset; help!
Try below resets
Power Drain:
Partial Reset
Semi-Full reset
Oct 24, 2010 | HP PSC 2355 All-In-One InkJet Printer
The off and on button is on but the screen says it is shutting down, but it will not shut down or let me go on to another stage. I have pluggged and unplugged it. It still comes back to shutting down mode
Hi
Try resetting the printer, follow below steps
Power Drain:
Partial Reset
Semi-Full reset
Regards,
Rizwan
Jan 27, 2010 | HP Officejet J5780 All-In-One InkJet...
On startup, printer displayed Ink System has failed. Error )xc18a0001. Have tried the cartridge-out/power off recommendation, fault is still there on power-up.
I searched internet forums and found out how to reset the internal processor, thereby deleting the error message and allowing the printer to operate normally.
Process was:- Press on/off to turn off power. Unplug power cable. Wait 1 minute. Press and hold 'Red Eye Removal' and 'Print Photos' buttons. Insert power cable and printer automatically powers up. Keep holding the two buttons until the display screen goes blank. Press on/off to turn power off. Wait 1 minute. Press on/off to turn power on. Press 'Setup' on touchscreen and go through the procedure, including wireless setup (if used). "Bingo".
Oct 19, 2009 | HP Photosmart C8180 All-in-One InkJet...
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
Sub won't power up
DVD reset procedure for TH-A10
1. Make sure there is no Disc in the tray.
2. Disconnect the power cord.
3. While Pressing "Stop" and "Open/Close" buttons together reconnect the power cord
4. Front display will show "TEST0".
5. Then the display will change to : "TEST1 JC2".
6. Press "Enter" button on the remote, display will show "EEPROM"
7. Press "Power" to shut unit off.
8. Reset is finished
Nov 16, 2008 | JVC TH-A10 System
Xerox Fiery Xp12 - Problem (INVALID LICENCE) apears on the screen
You will need to use what came with your machine.
The note from Xerox states this.
NOTE: You will need the Fiery Restore / Update Server Software CD and the User Documentation v2.0 CD that came with your EX12 v2.0 Software
And here is the loading process
  1. Visually check to make sure the Fiery LCD is at the Idle screen before you proceed. This will make sure the Fiery is not in use.
  2. Insert the Fiery Restore / Update Server Software CD into the Fiery EX12.
  3. Press [Menu] button on the Fiery Server.
  4. Press the [Down arrow] button.
  5. Press the [Shut Down] button.
  6. Press the [Reboot System] button. The message 'Rebooting System' will display and disappear after a few moments. The Fiery Server will reboot and complete internal testing. The Restore / Update CD menu will be displayed.
    NOTE: Ignore the message 'It's now safe to power off the system'.
  7. Press the [Up arrow] or [Down arrow] button to scroll to 'Restore System' so this is highlighted. Press the [OK] button. The 'All data will be Deleted. Continue?' message will be displayed.
  8. Press the [Up arrow] or [Down arrow] button to scroll to 'Yes' so this is highlighted. Press the [OK] button. The 'Restoring System...' message will be displayed.
    NOTE: The System Restore will take approximately 7 minutes, during this time the message 'Restoring System...' will continue to be displayed.
  9. Press the [OK] button when the 'Restore Complete!' message is displayed.
  10. Press the [Up arrow] or [Down arrow] button to scroll to 'Exit' so this is highlighted. Press the [OK] button.
  11. Remove Fiery Restore / Update Server Software CD from the EX12.
  12. Power OFF the Fiery Server. The power switch is located on the rear of the server, above the power cord.
    NOTE: Wait 10 seconds before powering ON.
  13. Power ON the Fiery Server. The Fiery Server will boot and complete a self-test.
  14. The EX12 will prompt you to insert the User Documentation CD. Insert the CD and the Fiery will continue with the process. When the process is complete, the Fiery LCD will display the message 'Please remove CD'.
  15. Remove the User Documentation CD
  16. Power OFF the Fiery Server. The power switch is located on the rear of the server, above the power cord.
  17. Power ON the Fiery Server. The Fiery Server will boot and complete a self-test.
  18. Using the Configuration Report as reference, re-enter the network settings on the EX12.
  19. Install any required patches, as needed. Refer to the Updated Information section on the Configuration Report.
  20. If needed, restore any data that you previously archived. See the Related Items.
Jan 10, 2008 | Xerox DocuColor 12 Printer
JVC Sirius KD-G300 CD Player Logo
157 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
