Question about Canon PIXMA MP510 All-In-One InkJet Printer
Ink cartridge not in place - now it's stuck
I had an ink cartridge recognition error, so I replaced the blue ink cartridge but I pressed the on screen cancel printing button before I had engaged the cartridge all the way down. Off course the whole cartridge assembly moved into it's ready position but now it's jammed and makes a horrible noise instead of coming out into the replacement position.
Any idea on how to get it out?
Thanks
  • Grumpy08 Feb 09, 2008
    Thanks a billion, we are good to go!!
  • 82 Answers
Turn it off and pull it over manually
Posted on Feb 09, 2008
  • James wood
    James wood Feb 09, 2008
    no problem glad i could help
Do I have to replace the color ink cartrigdes in my epson xp-610 printer
Q:
How do I change the ink cartridges?
A:
Do the following:
Removing and Installing Ink Cartridges
Make sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Leave your old cartridges in the printer until you are ready to replace them to prevent the print head nozzles from drying out. Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability.
  1. Make sure that the CD/DVD tray is not inserted for printing.
  2. Turn on your product.
    • If an ink cartridge is expended, you see a message on the LCD screen. Note which cartridges need to be replaced and press OK . Then select Yes, replace now and press OK .
    • If you are replacing a cartridge before you see a message on the LCD screen, press the left or right arrow buttons, select Setup > OK > Maintenance > OK > Ink Cartridge Replacement > OK . Then press the start_black_icon.jpg start button.
  3. Lift up the scanner unit.
    Caution:
    Do not move the print head by hand; otherwise, you may damage your product. Do not touch the flat white cable inside the printer.
  4. Push in the blue tab to unlock the ink cartridge you are replacing. Then lift the bottom of the ink cartridge to remove it.
    Warning: If ink gets on your skin, wash it thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. If ink gets into your mouth, spit it out and see a doctor right away. Keep ink cartridges out of the reach of children.
  5. Recap the used ink cartridge using the cap that came with it.
    Note: Dispose of used cartridges carefully. Do not take the used cartridge apart or try to refill it.
  6. If you are replacing the Black (BK) ink cartridge, it is recommended that you shake the new cartridge gently four or five times before unwrapping it. You do not need to shake the Photo Black (PBK) cartridge or any of the other color ink cartridges.
    Caution:
    Do not shake the cartridges after opening the packages, or ink may leak.
  7. Remove the cartridge from the package.
    Caution:
    Do not touch the areas shown above. Doing so may prevent normal operation and printing.
  8. Remove the cap from the cartridge and store it in the bag that came with your product for later use.
    Note: Save the cap so you can recap ink cartridges before storing or disposing of them.
    Caution:
    Do not remove any other labels or seals, or ink will leak.
  9. Insert the ink cartridge head first into the ink cartridge holder. Then press the bottom of the ink cartridge down until it clicks into place.
  10. Once you replace all the cartridges that need replacing, close the scanner unit.
    The product starts priming the ink. This takes a few minutes. When you see a completion message on the LCD screen, ink replacement is complete. Note: If you see an error screen telling you an ink cartridge is installed incorrectly, lift up the scanner unit and press the ink cartridge down until it clicks into place. When you\'re finished, close the scanner unit.
If you remove a low or expended ink cartridge, you cannot re-install and use the cartridge.
Caution:
If you remove an ink cartridge for later use, recap the ink cartridge using the cap that came with it to prevent the ink from drying out and to protect the surrounding area from getting smeared by ink. Store the ink cartridge in the same environment as the product. Do not leave the product with the ink cartridges removed for an extended period of time. Otherwise, ink remaining in the print head nozzles may dry out and you may not be able to print.
http://youtu.be/xJsDu52txEA
Nov 17, 2014 | Epson Expression Premium XP-610...
My printer is not recognising the replacement ink cartridge although I've used these before many times
If you have just installed a new cartridge and you still see an ink related error, the cartridge may be incorrectly installed. Follow these steps to make sure the cartridges are correctly installed:
  1. Make sure the Epson Stylus is turned on.
  2. Do one of the following:
    • If your printer indicates that an ink cartridge is expended, press OK.
    • If your printer does not indicate that any ink cartridge is expended, press Setup, select Maintenace, and press OK. Then select Change Ink Cartridge and press OK.
  3. Open the scanner.
  4. Open the cartridge cover.
    Caution:
    Never attempt to open the cartridge cover while the print head is moving; wait until the cartridges have moved to the replacement position.
    To avoid damaging the Epson Stylus, never move the print head by hand.
  5. Press down all the ink cartridges until they click into place to make sure they are properly seated.
    Note:
    If a cartridge is properly seated already, you may not hear a click.
  6. Close the cartridge cover and press it until it clicks into place.
  7. Close the scanner.
  8. Press OK to begin charging the ink. This takes about 2 minutes.
    You see a message on the display screen when ink charging is finished.
    Caution:
    Never turn off the Epson Stylus while the ink is charging or you'll waste ink.
If the issue persists, it appears to be an issue with the cartridge(s). Contact Epson for further assistance.
Sep 25, 2014 | Epson Stylus DX8400 All-In-One InkJet...
Colour ink cartridge not reconise. replace colour ink cartridge.cod 3603
To resolve the issue:
  1. Make sure you install the correct type of KODAK Ink Cartridge for your printer. Currently we offer two types of ink cartridges (10 Series and 30 Series). Installing the wrong type of ink cartridge may result in this error. You will need to install a new, correct type of KODAK Ink Cartridge.
    NOTE: For more information, see Which ink cartridges to buy for all-in-one printer.
  2. If you are using the correct type of KODAK Ink Cartridge, reinstall the color ink cartridge.
    1. Open the printer access door.
      NOTE: If the ink cartridges don't move to the center, see Printhead and ink cartridges don't move to center with access door open.
    2. Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
    3. Install the color ink cartridge back into the printer, making sure to press down on the thumb tab until it clicks into place.
    4. Close the printer access door. For printers with LCDs, follow the instructions on the LCD screen.
      For more information on installing ink cartridges, see the Extended User Guide for your printer. Review Maintaining Your Printer - Replacing ink cartridges.
  3. If the error continues, restart your printer:
    1. Turn off the printer by pressing the power button.
    2. Wait five seconds.
    3. Turn on the printer.
  4. If the error continues, and you have extra, new KODAK Ink Cartridges on-hand, try to install a new ink cartridge (or a set of new ink cartridges).
  5. If the error continues, contact us.
When the issue is resolved, we highly recommend that you upgrade the firmware for your printer for optimum performance:
  1. Locate and select the firmware for your printer.
  2. Follow the instructions to install the firmware.
Source: http://support.en.kodak.co.uk/app/answers/detail/a_id/39315/selected/true
Jun 07, 2011 | Office Equipment & Supplies
How do i change my ink cartridges in my epson workforce 520 series 3 in 1 printer?
Replacing Ink Cartridges
Make sure you have a new ink cartridge before you begin.
Caution:
Leave the expended cartridge installed until you have obtained a replacement, or the ink
remaining in the print head nozzles may dry out.
1. Turn on the product.
2. If an ink cartridge is low or expended, you see a
message on the LCD screen indicating which
color to replace. Press OK.
If a cartridge is expended, you must replace it to be able to print or copy. If a
cartridge is low, you can continue printing until a cartridge needs
replacement.
If you're replacing a cartridge before you see a message on the LCD screen,
press xMenu, press u or d to select Maintenance, and press OK. Then
select Ink Cartridge Replacement and press OK.
3. Open the scanner, then open the cartridge cover.
4. Squeeze the tab on the cartridge and lift it up.
Dispose of it carefully. Do not take the used
Warning:
If ink gets on your hands, wash them thoroughly with
immediately with water. Keep ink cartridges out of the
reach of children and don't drink the ink.
5. Before you open the new cartridge package,
shake it gently four or five times. Then remove
it from the package.
6. Remove the yellow tape from the bottom of
the ink cartridge.
Caution:
leak. Do not touch the green chip on the front of
the cartridge. This can damage the ink cartridge.
7. Insert the new ink cartridge into the holder
and push it down until it clicks into place.
8. Once you replace all the cartridges that need replacing, close the cartridge
cover and push it down until it clicks into place.
9. Close the scanner.
10. Press OK to begin charging the ink. This takes
about 2 1/2 minutes. When you see a
Caution:
Never turn off the product while ink is charging or you'll waste ink. If you see an ink
replacement message on the LCD screen, press OK and press down all the cartridges
securely. Then press OK again. If you remove a low or expended ink cartridge, you
cannot reinstall and use the cartridge.
See Page 47 in manual
Download Manual Here
May 23, 2011 | Office Equipment & Supplies
I've got a epson r320 it's about 5yrs old it does not get used very much. Today I replaced couple ink cartridges, shut it off restarted it and the new cartridges is regestering as half full and even empty....
Q:
I replaced an ink cartridge and my printer still shows that ink is expended. What should I do?
A:
If you have just installed a new cartridge and you are still seeing an ink related error, the cartridge may be incorrectly installed. Follow these steps to reinstall the cartridge.
Make sure the printer is turned on, then open the printer cover.
If the red error light is on, press the Maintenance button.
If the red error light is flashing, press the Maintenance button. You see Ink Cartridge Replacement, highlighted in the Advanced Settings menu. Press OK.
You see a message on the LCD screen telling you that ink cartridge replacement will begin. Press OK to continue. The print head moves to the replacement position.
Press in the tab on the back of the cartridge and lift the cartridge out of the printer.
Lower the cartridge back into the holder, with the green circuit board facing the front. Then gently push the cartridge down until it clicks into place.
Close the ink cartridge cover.
Press OK and close the printer cover.
The printer begins charging the ink delivery system.
When you see a message that charging is complete (after about a minute), press OK.
SRC: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_SessionID=@@@@1006416496.1302793816@@@@&BV_EngineID=ccekadfdfkjgijhcfngcfkmdhjidfmh.0&cookies=no&infoType=FAQ&oid=47541&prodoid=47915738&foid=130809&cat=30942&subcat=30923
Apr 14, 2011 | Epson Office Equipment & Supplies
Tow red signal
  1. Make sure the printer is turned on, then open the printer cover.
    • If the red error light is on, press the Maintenance button.
    • If the red error light is flashing, press the Maintenance button. You see Ink Cartridge Replacement, highlighted in the Advanced Settings menu. Press OK.
  3. You see a message on the LCD screen telling you that ink cartridge replacement will begin. Press OK to continue. The print head moves to the replacement position.
  5. Press in the tab on the back of the cartridge and lift the cartridge out of the printer.
  6. Lower the cartridge back into the holder, with the green circuit board facing the front. Then gently push the cartridge down until it clicks into place.
  7. Close the ink cartridge cover.
  8. Press OK and close the printer cover.
  9. When you see a message that charging is complete (after about a minute), press OK.
Dec 06, 2010 | Epson STYLUS R230 InkJet Photo Printer
My epson stylus cx6000 printer keeps showing -(install the ink cartridges) and I have already put in new ones. The code is E-02.
f you have just installed a new cartridge and you still see an ink related error message, the cartridge may be incorrectly installed. Follow these steps to make sure the cartridges are correctly installed:
  1. Make sure the Stylus CX is turned on.
  2. Check the photo viewer screen to determine which cartridge is incorrectly installed. Then do one of the following:
    • If printer shows the ink cartridge is expended, press the cp_button_6.gif Start button.
    • If the printer shows the cartridge is low on ink, press the Setup/Utilities button. Press the cp_button_41_er.gif or cp_button_42_er.gif button to select Press Start to change cartridges. Then press the cp_button_6.gif Start button.
  3. Press the cp_button_6.gif Start button again.
  4. Lift up the scanner, then open the cartridge cover.
alert_caution.gif Caution:
Never attempt to open the cartridge cover when the print head is moving. Wait until the cartridges have moved to the replacement position.
  • Press down all the ink cartridges until they click into place to make sure they are properly seated.
  • alert_note.gif Note:
  • Close the ink cartridge cover and press it until it clicks into place.
  • Close the scanner.
  • Press the cp_button_6.gif Start button. The Stylus CX charges ink for about one minute and displays Charging Ink on the photo viewer screen until charging is finished.
  • alert_caution.gif Caution:
    Never turn off the Stylus CX while the Charging Ink message is displayed or you'll waste ink.
  • Press the Setup/Utilities button to return to the previous mode, if necessary.
  • Aug 26, 2009 | Epson Stylus CX6000 All-In-One InkJet...
    Error inkcartridge
    Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
    Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
    Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
    Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
    Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
    Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
    Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
    Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
    Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
    Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
    Error Message: Scanner unit open -- > close the scanner unit
    Solution: Carefully close the scanner and press it down until it clicks securely into place.
    Error Message: Scanner error -- > See your documentation and call service if necessary.
    Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
    Error Message: Printer error -- > See your documentation and call service if necessary.
    Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
    Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
    Help Epson CX3200
    I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
    Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
    May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
    My Epsn Stylus PHOTO R300 says I need to replace an ink catridge however it does not tell me which one is out of ink. How do I find out which one to buy?
    If an ink cartridge is empty, the red error light will remain solid. You can check the status of the of the ink cartridges by looking at the icons on the control panel. Press the down arrow button to scroll down to MORE OPTIONS. The level of ink will be shown on the screen and the ink that will be out will have cross on it.
    Please follow the steps below to replace one or more cartridges.
    ***NOTE***
    -You cannot print if any ink cartridge is expended.
    -Leave the empty cartridge installed in the printer until you have obtained a replacement.
    -To ensure good results on your printouts, we recommend using Genuine Epson Ink cartridges. Epson does not recommend the use of refilled inks or 3rd party ink cartridges.
    Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
    1. Make sure the printer is powered on, and not printing.
    2. Open the printer cover.
    3. Do one of the following:
    3a. If the red error light is on (cartridge is empty) press the MAINTENANCE BUTTON.
    3b. If the red error light is flashing (cartridge is low) press the MAINTENANCE BUTTON. You will now see the Cartridge Replacement highlighted in Advanced Settings. Select OK.
    3c. If the error light is off (outdated cartridge), press the DOWN ARROW MENU button to choose MORE OPTIONS. Press OK, then select INK CARTRIDGE REPLACEMENT.
    4. You will now see a message on the display telling you that the ink cartridge replacement will begin. Press OK to continue. The print head will move to the replacement position.
    5. Open the cartridge cover. Press in the tab on the back of the cartridge, and lift the cartridge out of the printer. Dispose of it carefully.
    6. Unwrap the new ink cartridge. DO NOT touch the green circuit boards, or remove ANY labels.
    7. Lower the cartridge into the holder, with the green circuit board facing the front. Gently push the cartridge down until it is firmly seated.
    8. If you need to replace another ink cartridge, repeat steps 5-7 above.
    9. Close the cartridge cover. Press the front corner of the cartridge cover forward to lock the cover into place.
    10. Press OK, and close the printer cover. The printer will begin charging the ink delivery system. Once charging is complete, press OK to finish.
    May 23, 2008 | Epson Stylus Photo R200 InkJet Printer
    Canon PIXMA  MP510 All-In-One InkJet Printer Logo
    428 people viewed this question
    old marine
    old marine
