Question about Canon PIXMA iP1600 Printer
Ink replacements I just changed my ink in my computer but i dont know how to realign my printer how can i do this
  • 82 Answers
What brand and model # is it
Posted on Feb 09, 2008
Why after installing new ink cartridges, the system says to realign scanner. never saw this before.
Realignment procedure is typical when replacing ink cartridges. It is a pretty straight-forward process and takes only a few moments. Most printers provided detailed instructions on the alignment page it prints - otherwise Google your printer for instructions. Alignment ensures that there are no gaps or white lines in text or images.
Jul 14, 2015 | Epson Artisan 810 AllInOne InkJet Printer
Replacing ink on an epsom wf7010 with generic ink
Try Genuine Epson cartridges and if the white strips disappear then you know it's the generic carts. If not then clean the printer heads, if that doesn't do it then get a new printer.
Feb 10, 2014 | Epson Office Equipment & Supplies
I cannot print
i dont know if you have an empty ink in your cartrage if so, realign your printer and your ink try to level it in not more than one inch.
Feb 02, 2013 | HP Black Pavilion 23-B010 All-In-One...
Changed black cartridge and now only colour printer will print in is blue/green
The black print head most likely is blocked with dried ink.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Nov 19, 2012 | HP Photosmart 3210 Printer
Toner cartiridges are full but pages are printing blank
Turn your printer off. Disconnect from your computer by disconnection of cable, from the back of the printer. Unplug your printer from the wall.
Remove your print cartridges and gently wipe off the connections (copper or brass colored) with a dry lint-free cloth. Check to see if the bottom of the ink gates (holes where ink comes out) are clogged. Wipe gently with an almost dry but damp cloth, once or twice. Ink will continually come out, so only do this once or twice.
Plug printer back into the wall, connect power cable to printer. Turn printer on.
HP Photosmart will run through a series of checklists. First, it will ask if you would like to "realign" the printer heads. Press "enter" or "yes" and allow heads to realign. If you always have your printer and computer on, this realignment never happens, therefore the heads where the ink is dispersed from the modules will get clogged, and ink will never come out.
Nov 15, 2010 | HP Photosmart C6280 Printer
HPofficejetpro L7580 doesnt recognize cartridges have been replac
hELLO THERE
there should be a section there for the maintenance of the cartridges and change cartridges make sure that you use this whenever you change out a cartridge cause if you use this when you change out the cartridge the printer will always show low on ink also you can reger to your users guide for further instructions on how to do this ok? hopethat this has been very helpfull dont forget to rate my solution
best regards mike
(USN) retired
Aug 05, 2009 | HP Deskjet 6940 InkJet Printer
Epson Photo RX620
I use a bulk ink system which is not Epson so printer did not recognise the ink supply.
I 1) Turned printer off
2) Removerd bulk ink suppy tanks
3) Fitted Epson ink tanks [ dont matter empty or full ]
4) Turn on printer and let it go through it's start up prcedure
5) Do not turn printer off but do ink change procedure and refit bulk ink tanks
6) Do Nozle Check/Clean/Realignment
Bingo sorted
Jul 20, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
Canon i560s printer - color problems
I changed the black ink in my printer, now it will not print everything in black!, I changed it back to the old ink, but still not printing black ink, what do I do?
Mar 23, 2008 | Canon BubbleJet i560 InkJet Printer
Overiding Empty Cartridge error for Dell A10 962
I would take out both cartridges and put them in again. Realign the printer and the error codes should remove themselves. Try turning the printer off and on before puting the cartridges in again. That may make a difference. You can let your computer know not to tell you when the ink is low too. Let me know how this work for you.
Cynthia Charczenko
Dec 26, 2007 | Dell A940 All-In-One InkJet Printer
Printer will not print
Ren, Does the printer show the cartridges have been changed? If the printer doesn't recognize the new cartridges, turn off the computer and unhook the printer, unplug the printer from the computer and electric. Turn on the computer so it boots without the printer hooked up,(2x) then shut down again. Rehook the printer and plug it in then reboot the system. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=41661&prodoid=46048263&infoType=Downloads&platform=All You can also find updated drivers from epson from here. Good Luck, Tim
Mar 06, 2007 | Epson Stylus C86 InkJet Printer
Canon PIXMA iP1600 Printer Logo
23 people viewed this question
old marine
old marine
