Question about Sony Handycam DCR-TRV33 Mini DV Digital Camcorder
Grey lines across screen during video taping
I changed the tape and the lines are still there
    President:
  • 4,402 Answers
Needs tape path alignment.
Posted on Apr 11, 2008
Grey lines during playback.
Camcorder video head required cleaning because gray lines come in playback when video head got clogged/ dirty.
Put video head cleaning tape and playback it as per instructions.
hope this will help you.
Thanks.
Apr 03, 2010 | Sony DCR-HC38 Mini DV Digital Camcorder
Horizontal grey bars across screen.
This sounds like it is the Tape recording function that is at fault. Unfortunately, it's also one of the most difficult to correct without a scope and test jig.
However,
If it is more than 5 years old, it may be suffering from component failure.
In particular the Electrolytic capacitors in these small cams seem to fail first due to temperature and humidity changes. They can leak, dry up or corrode, so it may be worth looking inside at the control boards to spot any physical signs of deterioration.
This shows typical surface mount capacitors - silver cylinders with black segment denoting negative -
Sep 08, 2009 | Canon ZR200 Mini DV Digital Camcorder
Grey horizontal lines during playback on camcorder
yes change the tape and also use a head cleaning cassette to clean the cam. chaminda from Sri Lanka
Jun 25, 2009 | Canon MV750i Mini DV Digital Camcorder
Grey lines across video display
pls rate me WELL if i have helped u !
Regards
Zohail
May 20, 2009 | Canon ZR200 Mini DV Digital Camcorder
GREY BANNED OUTPUT
It is symptom of dirty / clogged video head.
Please use good quality mini-dv video head cleaning tape to clean head. Problem will be resolved.
Mar 16, 2009 | Canon ZR850 Mini DV Digital Camcorder
Sony dcr-trv120 playback
the problem is with the video head. either it's dirty or broken. if cleaning tape is not solving the problem then i fear you have to get the head changed. an expensive repair.
Jan 18, 2008 | Video Cameras
Grey lines across the screen
Does this happen on all dvs tapes? If so then it is a problem with the head reader of the cam, but if only one tape, then that tape is either has quite an old recording on it or the tape is damaged.
Jan 12, 2008 | Canon ZR200 Mini DV Digital Camcorder
5 Grey Horizontal Lines across the screen during play back and distorted sound.
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off. My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Jul 16, 2007 | Canon DV-MV830i Mini DV Digital Camcorder
Lines in tape playback
Someone here recommended taping with the lense cap on in a quiet room for 5-10 minutes. When I played it back, no more skipping or gray lines. This worked for me!!!!
Jul 02, 2006 | Canon ZR85 Mini DV Digital Camcorder
Sony Handycam DCR-TRV33 Mini DV Digital Camcorder Logo
206 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
