Question about Brother MFC 210C All-In-One InkJet Printer
Printer i have had problem with my brother printer it has a little ink in all cartage but the cyan it is all out will that cause my printer not to print fax or copy
  • 832 Answers
You need always enough ink to keep this type of machine alive (printing fax, copy, scan). you have to replace the empty cart.
Posted on Feb 10, 2008
Ink observe full.
open the machine then you will found the box full with cotton near the ink
cartage and remove the cotton and fill new one then close the machine you will able to copy or print
Nov 21, 2013 | Brother DCP-J125
Suspected clogged blue ink tube
most of the time, the print head need to be replaced for your case... but there are cases whereby it's the ink cart that causes the ink clogged.. you can try replacing the cyan ink and do another round of cleaning.. but chances are slim...
May 24, 2010 | Brother DCP-120C All-In-One InkJet Printer
Brother MC420CN- Black ink cartidge 'near empty' message persists
At 1 of the end sides of the cartage you will see a little window, a beam of light hits that window to determine if you need Ink..Place a small piece of Electric tape over that window and.wallah print,fax and copy away. Brother is a ripoff-A cheap printer that auto-cleans(wastes ink) and locks the whole system claiming your out of Ink or low>>>But this is sure to work! ;)
Nov 01, 2009 | Brother MFC 420CN All-In-One InkJet...
My printer will not print jobs from computer , it will make copies and it will fax but when I click on the icon to print nothing happens. I just put a new ink cartage in. I tried the test page and it...
Right click on the printer icon in the Printer and Faxes menu. Make sure in the pop up box it says USE PRINTER OFFLINE. If it says USE PRINTER ONLINE, click on it and then try printing again. You may also want to double click on the printer icon and make sure there is nothing scheduled for printing. If there is, cancel it and try printing again. If that doesn't work, make sure you have the correct driver selected and it is connected to the right port.
Oct 08, 2009 | Brother Multi-Function Center MFC-240C...
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printing when ink is low
The machine requires all color in order to print anything, even just black and white copies. You need to install a new cyan ink before it will print.
Feb 10, 2009 | Brother MultiFunction Center MFC-440CN...
Cyan ink won't print on Brother MFC-665
talked to Brother, cost to much to fix, replaced the printer.
Dec 24, 2008 | Brother MFC 210C All-In-One InkJet Printer
Ink Cartage CYAN for Brother Printer Model MFG 440 CN replaced
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Dec 07, 2008 | Brother MultiFunction Center MFC-440CN...
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 210C All-In-One InkJet Printer Logo
62 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
