Question about Broderbund PrintMaster Platinum 16
Printmaster and Windows Vista
I have Printmaster Premium 8.0 and LOVE IT. I cannot get my Windows Vista to accept it, even after following Broderbund General Computer Advice Running Programs in Windows Vista Using Compatability Mode. IF I purchase a new PrintMaster program will I have the same problems?
  • Anonymous May 18, 2008
    printmaster platinum 16 will not install on Vista
  • Anonymous Dec 24, 2008
    i have the same problem
Been running printmaster platinum 8.0 for many years on several different computers . have had it installed and running on my HPPavilion slimline for two years now . problem is that i cant get it too print anything new that i create it will print out older stuff that i have created but nothing new . have checked drivers on print they are all up to snuff , and have uninstalled and reinstalled both the printer and the printmaster program but still cant get it too print anything new that i create . it does print everything else in the PM program. and otherwheres on my computer
Posted on Sep 15, 2010
I cant get printmaster gold to work on my computer. i have windows vista
Broderbund PrintMaster Gold 16.0 is not compatible with Vista.
Platform: Windows 98 / 2000 / Me / XP
You can try to use Vista compatibility mode to run older programs in Vista. There is not guarantee that it will work!!! Please take note:- **The installation of an older program to run in a newer OS may also crash your PC too.
Link to How to "Use windows vista compatibility mode" - Use at your own risk!
Good luck.
Dec 07, 2010 | Broderbund PrintMaster Platinum 16
Will Printmaster Platinum 16 run on windows 7 I
Printmaster Platinum 16 is not compatible with Vista or windows 7.
Oct 24, 2010 | Broderbund PrintMaster Platinum 16
Have Windows 7 Home Premium (64-bit)on a new HP laptop computer. Am trying to install PrintMaster Gold 2.0. I get error messages when it is nearly installed. Broderbund told me it is compatible with...
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Feb 11, 2010 | Broderbund PrintMaster Gold 16 for PC
Can I load Printmaster 16 on Windows 7?
Printmaster 16 will work with Vista and Windows 7, you need to run setup.exe as administrator.
Jan 10, 2010 | Broderbund PrintMaster Platinum 16
Printmaster 17 does not save as pdf files under
Here's my solution: Don't waste your time and money on, use a program other than PrintMaster! PDF is universally accepted across formats/browsers/OS ...what kind of program would not export THE most commonly used format????
Dec 15, 2009 | Broderbund PrintMaster® Platinum 17 Full...
Cannot install on new laptop which vista windows
Hi there, i think you have to buy the new version of it, it does not work with vista you can see it here (It writes windows 98-xp):
http://www99.shopping.com/xPF-Broderbund_Broderbund_PrintMaster_Silver_15_Jewel_Case
And
You can buy a new version here, But as far i can see in the system requirements they do not mention windows vista, so I do not know if it will run under vista??
http://cgi.ebay.com/Broderbund-Printmaster-Silver-17-PC-software-NEW-BOXED_W0QQitemZ200389004657QQcmdZViewItemQQimsxZ20090929?IMSfp=TL090929146004r3159
OR
http://www.amazon.com/Encore-PrintMaster-Silver-v17-DVD/dp/B000EGK3KM
Hope that helps
IF Not then return here
Have a nice weekend
Please rate my answer
Oct 03, 2009 | Broderbund PrintMaster Silver 15 for PC
New driver equired
PM 16 is not compatible with Windows Vista. It will crash your System. :)
Jun 27, 2009 | Broderbund PrintMaster Platinum 16
Cant save to pdf in printmaster gold 17
found the fix for printmaster 18 broderbund pdf saving problems...
1-close all open programs and return to desktop.
2-click START and choose CONTROL PANEL
3-click PRINTER
4-right click on BRODERBUND PDF CREATER, then select PROPERTIES (the broderbund PDF creater properties window will open)
5-click the PORTS tab, then select ADD PORT button. (the printer ports window will open)
6-click NEW PORT, then enter PMPDF in the ENTER A PORT NAME window, then click OK
7-click CLOSE at the PRINTER PORTS window. you will now be looking at the broderbund PDF creater properties window
8-a check mark will be located next to the new PMPDF printer port. click APPLY. the broderbund pdf creator will now be located next to the new port. click OK.
9-exit all windows and restart the computer. once the computer restarts, you can save your project as a pdf file.
Jan 28, 2009 | Broderbund PrintMaster Platinum 16
Help
Hi there, the version you have is not compatible with vindows vista :O(
You can buy a new version here :
http://www.broderbund.com/store/broder/en_US/DisplayProductDetailsPage/productID.135272300
Hope that helps
If not then return here
Have a nice time over there
Jul 15, 2008 | Broderbund PrintMaster Silver 15 for PC
Computers & Internet Logo
668 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
