Picture went out on flat screen tv
Mitsubishi 52 inch flat screen LD was working fine and in a second the picture went out and a red "lamp" indicator came on on the front lower left panel. There is sound but no picture.
  • 1 more comment
  • Anonymous Feb 09, 2008
    needs a new lamp.
  • Anonymous Feb 20, 2008
    dvd player caused 1 of my dvd's to burnout; ie heat left bubble on the dvd and got stuck in the player. i unscrewed the panel and removed the dvd but when i put in a different dvd to play i had sound but no picture
  • shunter29 Jul 24, 2008
    I have the same problem with my flat screen. When you turn it on, the picture comes on for a split second, then the screen goes black. The sound is still there, but no picture
SOURCE: lamp going out on jvc flat screen tv 52 inch,how do you change
Versed, you have to open the back panel (cover) to access the lamp. replacing is easy as soon as you can see it. loosen the mounting bolt and pull to unplug the lamp from the SMPS Lamp power supply. Thats it.
Posted on Dec 29, 2007
milmar
  • 50 Answers
SOURCE: Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Posted on Aug 11, 2008
fixityrsel is wrong.
1 The "Airflow message"is just a bad connection and very easily solved.Mitsubishi has a service bulletin out and will cover the repair for free. Your set may not even have the defective connectors.
Your set was manufactured in 2004..Call any authorized Mitsubishi
servicer.
Capacitors are very easy to find! Any (105 degree) PC mount 3300uf@ 16VDC will work fine..and not bulge again..Higher Working voltage than the stock 10 VDC is what caused the problem with the caps.
Mouser electronic is one of hundreds of suppliers for those caps
Order online if you know for sure they are bad in your set.
Dan
Posted on Aug 14, 2008
  • 3 Answers
SOURCE: hello and thank you in
have you connected the optical cable. as the only way to get sound from the tv to the surround is via that link. the hdmi cable only send video and audio to the tv not both ways for some reason.
Posted on Jan 21, 2009
SOURCE: hooking samsung htz310 into insignia 52 inch flat screen
From what i learnt you learnt to connect tv to system with hdmi and a  optical lead..
Posted on Jan 22, 2009
Picture went out - red light now on. Do I need a
Do ur LED light indication on the front screen panel "LAMP"Flashing?Yes,the lamp require changing.
Jun 06, 2010 | Mitsubishi WD-52627 52" Television
Mitsubishi 52'' TV Model WD52525
U restart the tv,u hear alots of clicking?That mean the Ballast is dead or have problems,that why ur picture lamp not sustaning the picture.Replacing the Ballast might or will sustance the picture.
May 18, 2010 | Mitsubishi WD-52525 52" Rear Projection...
LG 52 Inch Rear Projector TV - switches itself off
LAMP pull it out and see if it looks busted on the inside.
Dec 21, 2009 | LG RU-52SZ51D 52" Rear Projection...
Mitsubishi wd-52825. red lamp indicator, new lamp installed
Failed caps on the power supply will cause that. The V26 Power pwb repair kit will usually correct that issue. Its available from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Oct 30, 2009 | Mitsubishi WD-52825 52" Rear Projection...
Lamp Indicator is Red
a 41 error code for a short is usually caused by the power PWB. The power board will need to be replaced
May 30, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No picture and no sound after replace lamp for Mitsubishi WD-51525
did you use an original mitsbishi lamp. did it slide in easily? one of the most common problems with a lamp replaement is pushing the connector away from the lamp if it doesn't slide in easily. unplug the set, take out the lamp and look with a flashlight to see if the connector is in place. if so put the old lamp in and see if it works. if it does then your new one is bad. if it doesn't then email me
ima_rm2000@yahoo.com with your number and we can talk more.
ken
Nov 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Had blue screen, now no picture and red light
Press the menu and the device/input buttond on the det both in together and hold in for 5 seconds to see if the led will blink a two digit code such as 3 blinks slight pause then 4 blinks. I would almost bet that you have a 34 code come up. But respond to this same post and let me know which two digit blink code came up, and I will assist you with whats wrong with your DLP.
Aug 08, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 57" HDTV - has sound and timer light flashes
I had the same problem and my local repair guy soldered a defective sensor so that it goes around that problem. I also had to buy a new bulb. Now my picture is "cloudy" and the repairman has no idea why. I am waiting for them to call back on it.
Mar 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52725 TV loses picture while playing DVD but not sound
replace DM or try to fix it.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Jan 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
354 people viewed this question
 Grubhead
Grubhead
