Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
My Kenmore progressive 25513 506 Won't turn off
I have to unplug it to turn it off. please help!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
You need to buy a new pc board which is in side the canister between the motor and the power cord. first remove the lid. just pull it back real quick the it will come off. you might think you broke it but if done right it won't. now lift up but don't pull off the small lid in the back where the power-mate jr and look in the back for 2 screws remove those plus the 2 in front and pull the cover up. make sure to see where the wires are, if you don't the cover won't fit right when your done. between the pwr-cord and the motor is a pc board which needs to be replaced. just keep track of the wiring. if you can't do all this take it to Sears.
good luck
Posted on Feb 10, 2008
Get the belt to turn in Progressive Whisper belt
Make sure the roller is not jamed with carpet threds , remove bottom cover and clean dust balls and obstructions out see if ti resolves problem make sure it's unplugged when checking and install complete before applying power!
Feb 21, 2015 | Kenmore 25614 / 25615 Progressive Bagged...
The vacuun don 't turn off
Please unplug the unit.
2. Check to make sure the button is not stuck in the on position. 3. If the switch is stuck, try to move the button in the off and on position 4. If the problem persists, you may have a defective button stuck in the on position 5. Please do not attempt to disassemble the unit as the risk of electricution is high.
Jan 08, 2011 | Kenmore 25512/ 25513 Progressive Canister...
I have a Kenmore Progressive and it will not turn on can you help?
Is it hot when it shuts down the filters may need to be cleaned often,see if this works for you wait for it to cool it may take a few hours.
Aug 29, 2010 | Kenmore Progressive Bagless Upright with...
Kenmore Progressive Canister Vacuum -Model 116 22812200.
hello... you might want to try checking the elbow or neck of the power nozzle for blockage. Remove the wand from the head and look through it. Also look through the wands . If there is no blockage, maybe there is a problem with you nozzle. Reattach all the parts and turn on the machine, turn on the power nozzle. Can you hear the other motor start? If so, check to see if the belt is turning. If it is not, and you definitely hear the secondary motor, then you need a belt. If it doesn't make any sound then, with the machine still running, press the button on the upper part of the power nozzle, this should reset your motor. I hope these tips helped ya, let me know, by giving feedback when asked. thank you, Rene (The Vacuum Doctor)
Nov 10, 2009 | Kenmore Vacuums
Kenmore progressive 360 will not turn off
I have the same problem. Couldn't turn it off and now it doesn't work for the floor setting (though I can now turn it off). I suspect the switch in the handle is the problem but having trouble opening the handle...
Sep 22, 2009 | Kenmore 23913 Progressive PowerMate Bagged...
Sounds like something is 'stuck' -
unplug, then unwind the shoelace from the roller.
Jun 15, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Vacuum will not shut-off
if it has a foot pedal flick it a few times and see if it goes off.if its a switch unplug the vacuum and move the switch from on to off real fast a few time.if you have any contact cleaner you can try to spray a little into the switch while unplugged and work the switch back and forth a few times .the switch might just be dirty.if you don't hear a click when you turn it ioff and on then the switch is probably bad.please leave feedback.i hope i was some help to you
Mar 30, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore upright model number 86039259990. The
don'thave to smell, the belt just snapped in half.unplug the vacuum and try to turn the brush roller by hand,if it turns real freely the belt is broke.it should be kind of hard to turn by hand if the belt was good
Mar 04, 2009 | Kenmore Progressive Bagless Upright with...
Kenmore Progressive Model # 116 25914507
I had the same problem with my vacuum. I called in for technical service and was told to push the "reset button". It turns out that there is a small red button right next to the dirt indicator light. I pushed the button, plugged the vacuum back in and started it up and it worked like a charm! :) Hope this helps!
Mar 25, 2008 | Kenmore 23913 Progressive PowerMate Bagged...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
122 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
