Question about Gateway M305CRV Notebook
I can't get the full capacity of 320 gig drive
I just purchased a new 320 gig SATA drive, but XP -SP2 won't recognize more than 137 gigs. I've partitioned it (with lifeguard tools) to three- 100+ gig partitions, but windows always reverts to 137 gigs. I've used overlays before, starting in the early '90s, and never had this problem.
The chipset is Intel 865 family, I/O controller is 82801EB (ICH5).
How can I FORCE an overlay on there to get my full capacity? Or at the very least, make the partitions stay put?
Ignore the product listed, what I have is a Gateway "profile 500" desktop computer with built in flat panel monitor, 3.4 ghz pentium IV and 1 gig ram.
  • 84 Answers
The hard drive you bought is not compatible with your motherboard. I am pretty sure that your board is only compatible with IDE ATA hard drive. you can still use it as external hard drive though.
Posted on Feb 09, 2008
Acer Aspire 5002WLMi Laptop won't recognize full 320 Gigabytes of new PATA hard drive. It's always been running a 80 Gigabyte 4200 RPM but that drive is old...a 2005 HD. New WD320 only reads 137...
The BIOS in the ACER determines the maximum size of the hard drive it can support.
Check the laptop's specification to see the max size you can install in this model laptop.
It appears that the max size your laptop can support is 140 Gb (unformatted). 137Gb formatted.
I suggest you install a hard drive up to 140 Gb capacity in your laptop and place the 320 Gb hard drive in an USB hard drive adapter case and when you attach this hard drive to the USB port in your ACER laptop then you will be able to get the full 320 Gb capacity after you delete the partition and create a 320 Gb partition and format the hard drive.
Nov 02, 2011 | Acer Aspire 5002WLMi Notebook
Hi there , i have an acer travelmate 6592 laptop , the original 80 gig hard drive crashed , and i dont have the recovery disc , the hidden partition wont re install either , i have bought a new 320 gig...
You cannot get the full 320Gb capacity because the BIOS can only support a maximum of 127Gb.
You only hope is a BIOS firmware upgrade that can support 320Gb. Check out the Acer WEB site to see if a BIOS upgrade will solve your problem.
OTHERWISE
Install a 127Gb hard drive in your Acer and put the 320Gb hard drive in an USB hard drive adapter case and use it as an external USB hard drive because it is not affected by the BIOS limitation.
Jun 13, 2011 | Computers & Internet
Windows xp professional won't complete setup.
Its an hardware error. You have tech support with MS since you bought the new XP try to see if they can tell you what is the hardware its complaining about.
Feb 26, 2010 | Microsoft Windows XP Professional With...
What type of hdd does a HP omnibook 6100 F3260KT support and can it hold more than 30 gig standard factory as current HDD heads are locking up
The type of hard drive you want is a 2.5 inch IDE (ATA) hard drive.
As for the HDD capacity I've worked on an Omnibook 6100 which had a 100GB hard drive so i expect it can possibly take up to 320GB but don't quote me on that.
Regards.
Nov 13, 2009 | HP OmniBook 6100 Notebook
WD Caviar SE16 WD3200AAKS 320GB 7200 not recognized at install
Windows XP does not have built in SATA drivers. You will need to download the XP drivers from Western Digital's website and install before the computer will allow you to format and use your new drive. Hope this helps.
Jul 18, 2009 | Western Digital (WD3200JS) 320 GB Hard...
I just purchased a 320 gig hard drive and when i set a partition it only shows 132 gig
Use the WD data life guard disc to partition the drive. Put the disc in, reboot the computer, and run data life guard. A screen comes up and asks if your system can recognize a partition greater than 137 gb. If your system can read larger than 137, then use the option to format one large partition.
Some OS cannot read larger than 137gb. Also some Bios have the same problem.
May 01, 2009 | Western Digital 320GB Internal Serial ATA...
Additional Hard Drive
The Motherboard will be able to handle it and XP will read the hardrive i have used a 500 gig hard drive in my old computer before it should work just fine
Apr 08, 2009 | Dell Dimension 2400 PC Desktop
New hard drive not reconized, motherboard drivers
I had this problem on a computer recently. This particular motherboard may be needing the driver on the Windows XP SP2 disk. Your motherboard may have been made to use Microsoft SATA drivers. Othewise, there would have been a driver disk that came with the motherboard to let it see that SATA hard drive.
If it's a new hard drive, you have to reinstall the O/S so use a disk new enough to have SP2 included.
Jan 17, 2009 | Biostar K8VGA-M Motherboard
Wrong Hard Drive Capacity
Any hard drive larger than 130GB have to be installed using Windows XP SP2. Windows disks, Pre SP2, will not recognize the large hard drive on 130gb of drive.
Jan 12, 2009 | Compaq (166361-001) Motherboard
Trying to format a 500GB HDD at full capacity
check your bios if the disk is recognized as 500gb first. if it is not recognized, update your motherboard bios. most updates are available in their manufacturers site.
Oct 11, 2007 | Western Digital Caviar SE16 (WD5000AAKS)...
Gateway M305CRV Notebook Logo
98 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
