Question about Epson Stylus C82 InkJet Printer
Epson C82, Cartridge carrier won't move
When I turn the power on, the carrier that holds the ink cartridges won't move.
  • Pmart15 Apr 18, 2008
    I have the exact same problem. The belt that's supposed to move the ink carrier moves fine but the carrier goes nowhere. Its like it came disconnected from the carrier and its too tight back there for me to see what's going on.
Hi, I'm having other belt problems but it sounds like the belt has separted from the carriage. The belt is held in place by looping through a place on the back of the carriage. It is just pressed into the plastic structure so if the plastic has broken or the belt worked out, your problem would occur.
It is a bit tricky in getting the carriage released. I found it necessary to completely remove the inner workings from the casing. A few screws and plastic clips to release but not too bad.
The trick comes in when you have to release the slide bar that runs through the carriage. It is held in place by small clips on either end. Both must be removed. They appear to be fiber so don't be too rough on them. There is a white plastic mounting on both ends which allows the print head to adjust for envelopes or paper. The one on the left (while looking at the printer from the front) must be removed. Be sure and mark the position of the bracket before removing. Take the screw out and rotate the piece so that the lugs will pass through the housing. Once removed, the bar can be slid through the opening and out of the carriage. You can then ease the belt off the motor gear (on the left) and inspect the "u" shaped connection on the back of the carriage. There is an area of the belt which is noticeably thicker than the rest of the belt and this is what should be inserted in the "u". If the plastic is broken you will probably have to replace the carriage. Good luck.
I have included a link below from another site which gives you a pdf of the service manual for the C82
http://www.eserviceinfo.com/downloadsm/18686/Epson_Stylus%20Color%20C82.html
Posted on May 01, 2008
Ink cartridge in Z705 will not move to center of carriage for changing when top is lifted Even though the Belt is moving. Help !!!!!!!!!!!.. >:( :( :'(
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
I hope this helps.
Oct 24, 2011 | Lexmark PhotoJet Z705 InkJet Printer
Why will my ink cartridge not move to the center so i can tak e it out.
Sep 10, 2011 | Lexmark X2470 All-In-One InkJet Printer
Carriage for the ink cartridges is stuck, the carriage wont move to the middle so i can change the ink. i turned off the power & then turn it on , the carriage just move a little from the right and...
Aug 30, 2011 | Lexmark X2600 InkJet Printer
When opening my printer to get to the cartridges, they are stuck inside the printer and won't move. The on/off button is flashing.
Aug 26, 2011 | Lexmark Z2320 InkJet Printer
I cannot stop the ink cartridge holder to stop in the correct positioo to replace the cartridges on my epsom cx5500 printer
Hello jgw_cansdale,
Welcome to Fixya.com!
If the Ink light (fon3_66.gif) is flashing that means one or more of your ink cartridge is low on ink, and if it's steady it means one or more is out of ink. For Epson printers, there are lots of ways to identify whether your printer is out or low on ink. For today let's just stick with the printer itself.\
Remember: A flashing fon3_66.gif means LOW ON INK, and a steady fon3_66.gifmeans OUT OF INK.
1. Open the scanner bed by lifting it up just like opening a brief case. By doing this you should now be able to see the carrier area this is the area were the ink carrier or ink holder moves left and right,
2. Press the Ink button. Now remember flashing means LOW and steady means OUT of ink.
If the Ink light is flashing, and you pressed the Ink button the carrier or ink hold will move under a small arrow just right above the carrier to point to you which ink cartridge is low on ink. pressing it again will point to another if you have multiple cartridges that are running low, if not it moves directly to the ink cartridge replacement area were you can pop the carrier's lid open to access the inks.
If the Ink light is steady, and you pressed the Ink button the carrier or ink hold will move under a small arrow just right above the carrier to point to you which ink cartridge is out of ink. pressing it again will point to another if you have multiple cartridges that are out of ink, if not it moves directly to the ink cartridge replacement area were you can pop the carrier's lid open to access the inks.
Regards,
Deathschythe33
Aug 22, 2011 | Office Equipment & Supplies
Print cartridge would not move to loading position to allow installation of new cartridge
Aug 17, 2011 | Lexmark X2690 All-In-One InkJet Printer
How do I change the ink cartridges on a lexmark 5495
Please follow the steps below on how to replace ink cartridge on the Lexmark X5495 printer:
  1. Make sure the printer is on.
  2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier latch to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
Just need to know how to put in black ink in the z1300
Follow these steps on how to install the cartridge: 1. Make sure the printer is on. 2. Lift the access cover. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. 3. Press down on the left cartridge carrier lever to raise the cartridge carrier lid. 4. Remove the used print cartridge(if you are replacing). Insert the new black cartridge in the left carrier. 5. Snap the lid closed.
3. Remove the used cartridge.
4. Load the new black cartridge. Close the cover.
Apr 29, 2011 | Lexmark Z1300 InkJet Photo Printer
Do not know how to change ink cartridge x2650
Lift the scanner unit, and then press down on the cartridge carrier latch to raise the cartridge carrier lid. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Remove the used print cartridge. Insert your new cartridges.
Apr 28, 2011 | Lexmark C533DN InkJet Printer
Cartridge housing will not certre to change cartridge
Apr 10, 2011 | Lexmark Z2300 InkJet Printer
Epson Stylus C82 InkJet Printer Logo
158 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
