Question about Coffee Makers & Espresso Machines
B200 Doesn't heat up the water. Do you have a manual and have access to parts?
  • Javatyme Feb 09, 2008
    This is a Keurig coffee maker.
  • 82 Answers
What is the model # if you have ace hardware store or something similar they can usually order parts
http://www.keurig.com/CustServ.asp?mscsid=F27R1Q30BEV28J9KGDHM92FW5208BJT1
Posted on Feb 09, 2008
Canon mg5250 -error code B200
B200 usually means that the printhead has failed. It's a generic "overtemperature detected" error that indicates that the thermal sensors inside the printhead have detected heating to the point where the printhead has probably failed. In a well-intentioned attempt to prevent further damage, the printer has shut itself off; however, by the time this occurs, the printhead is usually destroyed. The following video shows a likely next step: http://www.youtube.com/watch?v=I9uBEOMCd44
Jun 05, 2013 | Microsoft Windows 7 Ultimate for PC
Keurig B200...multiple issues
Too many problems with the B200 and they stopped selling it.
Jan 04, 2013 | Keurig Coffee Makers & Espresso Machines
The reset button popped and now won't reset.
Circuitboard problem. Needs replacement.
Nov 02, 2012 | Keurig B200 Brewing System
I need a manual for a technics SL B200
The following site has them for sale...I've never used the site so can't guarantee quality etc...
http://www.stereomanuals.com/man/rep/technics/technics_manuals_sl-a_xx.htm (search on the page for SL-B200) total cost $9
Also this site has one listed for $15
http://www.audiovideo-parts.com/scripts/prodView.asp?idproduct=3808
Dec 03, 2011 | Audio Players & Recorders
Dishwasher not heating water already replaced in line heater element no change
Hello
Possible causes;
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon
Sep 07, 2011 | Westinghouse Dishwashers
B200 stuck. says "brewing" but
Hi.You may try this steps.
took the reservoir off,
siphon water from a hose, blow it off
Maybe that is what has happened in
all of these instances
cup of coffee.Hope this helps.
Jun 21, 2011 | Keurig B60 Coffee Maker
Coffee maker won't heat cofee
Don't open nothing inside you can fix you can cause it to overheat and melt.
Aug 07, 2009 | Coffee Makers & Espresso Machines
My keurig b200 is stuck in the mode saying that is "heating please wait" nothing seems to be happening i dont have the user maual. is there a way to reset the machine?
It is most likely the 12v air pump not working. It doesn't provide the air pressure to pump the water into the heating canister and, thus, the unit will try to heat the water indefinitely. See the following forum; it's about the B70 but much useful info, including sources for the air pump that you most likely need: http://www.singleservecoffeeforums.com/dissassembly-repair-guide-keurig-b70-platinum-t8124.html
FredF
May 06, 2009 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
372 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
