No internet connection
I have a Dell Dimension 4550, cleaned up a virus and then a bunch of old programs and after everything was working fast and normal again, I discoverd the internet connection was lost, I narrowed it down to the Broadcom ethernet connection, in the control panel, the icon is still there, but it says there's no device listed, or drivers and it's not in the Device manager either, I can't unplug this model because it's directly on the motherboard, what can I do to get this up and working again?
  • 38 Answers
If you have access to another printer with an internet connection, go to this site:
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Enter the service tag for the system and then download the broadcom network driver to a USB Drive or CD and then take it to the Dimension 4550 and reinstall the driver.
Posted on Feb 10, 2008
SATA on dell dimension 4550 with Debian
look in the devicemanager what does it say.
update thrue the deviemanager or search the internet
May 26, 2013 | Dell Dimension 4550 PC Desktop
I have an old Dell dimension 4550, I just got it from a friend, the enternet wont work. It says no wirelless or wired devices found and no drivers. I downloaded drivers onto a flash drive and tried to...
hi your problem is that you should set the connection to internet
Dell Dimension 4550 (Pentium 4 2.66GHz, 256MB RAM, 60GB HDD, XP Home)
first you need to go to:
control panel>system>device manager>check if appears the ethernet car if it does then.
go to control panel>network conection>properties>select tcp/ip go to properties check and make sure the option of automatic ip and the automatic dns select it and you are ready....
May 27, 2011 | Dell Dimension 4550 PC Desktop
My Dell Dimension 4550 starts up and after about 30 seconds shuts off. It does not matter if I boot in safe mode or normal and I have disconnected everything but the monitor, keyboard and mouse.
If the computer shuts off completely like someone pulled the plug from the electrical outlet, it is probably your power supply. I would first check all the main cable connection from the power supply to motherboard. If the problem persists, swap out the power supply. Thanks.
Mar 18, 2011 | Dell Dimension 4550 PC Desktop
My Dell 4550 has a cold start problem. It works great once its been running, it has to warm up for 15 to 30 minutes before it completely starts up. I have tried everything, started from scratch. I...
Did you change the power supply ?- it is critical to the operation of your machine. Often if something is wrong with it,k it is not common for the machine to not boot up at all. Could be that until it gets warm some voltage is not up to par and the machine just waits till it is for it to operate properly.
Just make sure that your Dell power supply is not one of the older ones that had the wiring reversed and was not compatible with regular motherboards. Newer Dells are now compatible but older units can only use a Dell supply lest you burn out the motherboard.
Mar 18, 2017 | Dell Dimension 4550 PC Desktop
My computer is filled virus. how do i remove everything
If you can't use the internet on it, Get Microsoft Security Essentials using a different computer then with a USB stick put it on the infected computer and install it. This should clear a lot of the major viruses out. Next get Malware bytes anti-malware. This program deep cleans the computer. These two programs should clear the computers viruses.
Jul 24, 2010 | Dell Dimension 3000 PC Desktop
I install new windows and ethernet controller is not working and I can't get on the internet? What can I do?
Purchase a USB memory-stick.
On another computer with Internet access, access: http://support.dell.com and select "Downloads and Drivers". Select "Dimension". Select "4550".
Select "Network Adapters". Download the device-driver, copying it to the memory-stick.
Move the memory-stick to your computer, and "install" the device-driver.
Feb 02, 2010 | Dell Dimension 4550 PC Desktop
Reformat done and now there is no internet connection. I need the ethernet controller and the sm bus controller. Everywhere I go...they want to download that program that tells me what drivers I need and...
No, you don't need to download the drivers you have to looked for the motherboard installer of your PC, then install the chipset of your motherboard in order for you to use the internet connection.
Jan 21, 2010 | Dell Dimension 4550 PC Desktop
Formatted pc and now its not detecting internet connection.. checked ipconfig but loks like my pc doesn't show no IP address.... everything else in d pc works fine except for the internet connection....
Did you reformat with the manufacturer's discs? If not, you are likely missing the LAN drivers for your NIC (Network INterface Card). Right-click on My Computer and select Manage. this will bring up the Device Manager screen, and if you see a yellow question mark next to the LAN driver then this is the reason.
Nov 09, 2009 | Dell Dimension 4550 PC Desktop
Dvds make grinding noises and skip a lot on my dell 4550
Sounds like the dvd rom is bad and needs to be replaced. I believe its not holding the disc in properly and the disc is spinning at a different angle and touching the sides or top
Mar 20, 2009 | Dell Dimension 4550 PC Desktop
Dimension 4550 10 100 Network Problem
chk in the device manager if the netwrk card is listed correctly.....also try disconnecting & reconnecting the cables
Jun 23, 2008 | Dell Dimension 4550 PC Desktop
Computers & Internet Logo
263 people viewed this question
David Payne
David Payne
