Question about Dryers
Electric dryer replaced two sensers in the dryer. Took the timer and buzzer in to be checked, they said ok. Problem is the dryer continues to run and not cut off?
  • wildb81 Jul 29, 2008
    Dryer won't shut off, the timer doesn't move. If you set it on "less dry", 4 hours later that is where it will still be and dryer continues to run until shut off manually.
  • BAHAMAS74 Oct 14, 2008
    I TURN MY DRYER ON FOR 30 MINUTES AND THE SWITCH IS THE SAME POSITION AND IT WILL NOT TURN OFF UNLESS I MANUALLY TURN IT OF CAUSING MY LIGHT BILL TO SKY ROCKET. CAN WHAT THE NAME OF THE PART INSIDE THE SWITCH.
  • 82 Answers
Its the switch in the timer
Posted on Feb 09, 2008
Dryer does not turn
Posted on Mar 13, 2009
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
I have a kenmore dryer model# 96580110, that only runs on one cycle. Every other cycle just buzzes continually like it's finished. And on that one cycle, the buzzer never goes off.
This is a sign of the timer going bad and it will need to be replaced. Here is a link to the new timer.
Here is a video to walk you thru the repair process. The model may be a little different but the process is the same.
Oct 15, 2012 | Dryers
Dryer won't stop at end of cycle , no buzzer or anything, just keeps running on all cycles, have changed timer
Unplug th dryer and check to see if the start switch is shorted. Remove switch and check for continuity between the two posts on the back of the switch. There should only be continuity when the switch is pushed in.
Feb 25, 2011 | Kenmore 60172 Electric Commercial Dryer
We have a 80 series elec. dryer, today when the end of cycle buzzer sounded, when door was closed again...buzzer continues to buzz. I can't find a part number, if the end of cycle buzzer needs replacing. ...
Push the timer to a definate off position. Close the door. If it buzzes then more than likely you are getting power from the timer which could mean short in the timer. If you have the model # the parts places can easily find your parts.
Dec 28, 2010 | Kenmore 800 6983 Electric Dryer
Matag performa dryer heats but won't tumble.
After checking the door switch and belt (both ok) I took the wires
from the thermal fuses-- straight wired them together and the dryer started working. I went to my local appliance center,
purchased the thermal fuse kit --replaced the old fuses--now it
runs great.
I hope this helps someone else with this problem.
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
GE Dryer doesn't give out heat.
OK, i would check the thermal fuse. is usually located on or around the blower housing. Check the vent duct if its not on the blower motor housing. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
If the fuse is OK, there is only one more problem spot and that will be the timer itself. replace the timer/control if the fuse is OK.
Jun 01, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Dryer has no heat to it, but runs
Running is good. That means lots of stuff is working. On the motor is a switch that turns the heat on once the motor gets up to speed. The other wires on the motor are start and power for run. Check your heater elements for continuity. Running usually means the door switch is ok, timer ok. Check around for fuses, burnt wires, loose wires. Check the heat sensors for continuity. They should conduct electricity untit they get hot.
Apr 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmoore 70 series Buzzer will not stop
buzzer is built -in the timer you all should replace it if you really want it solved they have done their work over the years. It's not something you can just go in and unplug or cut sorry. Good Luck. Post your make and model numbers next time please.
Dec 19, 2008 | Kenmore 60172 Electric Commercial Dryer
Maytag model
You really need a volt / ohm meter to check for Continuity & VoltsIts well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer,
If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity they have to be replaced
Oct 11, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer will not start properly, buzzer operating
more than likely your timer is faulty too much to replace most timers about same price to replace your dryer if not cheaper
Mar 16, 2007 | Candy CIV60 Electric Dryer
Dryers Logo
183 people viewed this question
Top Dryers Experts
Marvin
Marvin
