Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Convergence some how the convergence menu is gone, do you know how to find it again
  • deeznizzles Feb 13, 2008
    no, it hasn't been worked on at all. what i mean by it's gone is, it's no where to be found on any menu. we've searched all the menus up and down. when the tv was first bought it was there, but now it isn't. the screen looks like it's in 3d but we can't find the convergence to re-align everything.
    Genius:
  • 1,030 Answers
By the convergence menu i would assume you mean in the customer setup menu. although i have seen this at the shop on newer itc222 i guess it can happen with older sets...is the convergence gone...is it red green and blue.. if not it might be cut off in the service alignment menu...if that is true. how did it get cut off. has the set been worked on?
Posted on Feb 09, 2008
My rca d52w26 convergence is gone.
Look in the on screen menu for convergence and if it is not there you have a open ( bad ) protection part on the main board, a kit exists for most of these sets for this===buttons alone will not likely help here.
the convergence menu missing is a result of this and the part in question is often bad because of bad solder connections.
If you need more info let me know.
Aug 28, 2012 | RCA P52960 52" Rear Projection Television
The convergance menue is gone. I need to adjust the convergance badly but it is no longer in the menu
You need to resolder the flyback transformer and replace fuse FL221 off pin 11 of the flyback transformer. The convergence power supply is not coming on so system control thinks a convergence circuit is not installed.
Oct 16, 2009 | RCA D52W23 52" HDTV CRT TV
3d like picture, 3 colors bending across screen. convergence option gone from menu
There are bad solder connections on the flyback transformer and fuse #FL231 is open. Pretty hard to repair this yourself.
May 26, 2009 | RCA R56WH76 Projection Television
RCA 52 INCH CONVERGENCE PROBLEM HELP/already replaced the fl231 fuse
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence adjustment for red and blue
Press the MENU/SELECT button
on the remote control to show the
on-screen menu.
Press the CURSOR RING
RIGHT
to enter the PICTURE menu.
DOWN
repeatedly until CONVERGENCE
is selected.
RIGHT
to enter the CONVERGENCE
menu.
RIGHT
to enter CONVERGE RED
mode.
LEFT, RIGHT, UP, or DOWN
to
adjust the cross image until the color
outline around it is gone.
Press the STATUS/EXIT button
to exit the menu from the screen.
Aug 21, 2008 | Philips 60P8341 60" Rear Projection...
Auto convergence disappeared from the menu on my 52" RCA TV, Model #R52WH73. This TV is just 1 week out of warranty and the timing is impeccable.
Replace FL231 that will bring back your convergence option in the menu. If the Fuse blows again, you will need the Convergence power supply board. If you need more assistance please let me know
Aug 06, 2008 | Televison & Video
Auto convergence feature gone
Its the HV transformer, But if your symptom is auto convergence feature gone from the menu. Its not your flyback. Please respond to this same post with your model number and let me know if the auto convergence feature is missing, and I will assist you with the problem.
Jul 22, 2008 | Televison & Video
Convergence colors gone bad
im wondering if there is a degause (spell check) setting that can be used after all this work i know it works on comp screens it
degause is supposed to power screen with a surge of power to return it to normal stasis
Apr 23, 2008 | Apex Digital GB5108 51" Rear Projection...
Red convergence is out of alignment
If the mis-convergence is only noticable on the left center and the top and bottom left side of the screen is good, then it sounds more like a pincushion distortion problem rather than a convergence one. Otherwise, you could have a bad pair of convergence IC's or capacitors / solder connection problems. I would doubt that adjusting the service menu would correct this problem, and you could make it much worse by trying. Better have a technican work on it if the picture quality is still good otherwise.
Jan 14, 2007 | Panasonic PT-51HX43 51" Rear Projection...
Convergence setup menu gone
No rest on this model other than unplugging to let it return to factory default. If your a tech .. Check R19722 and R19703 for open. Both 750 K. these open make the convergence menu to be gone.
Jul 13, 2006 | RCA P52929 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
51 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
