Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
DVD Connection and Surroundsound 7.1 Onkyo
I am trying to hook up my Philips DVD Player HDMI using a HDMI jack and get picture but no sound' I also am trying to hook up my Onkyo 7.1 surround sound system with HDMI jack and no luck. What am I doing wrong? DVD Player is DVP5960
    Problem Solver:
  • 7 Answers
Gotta use rca audio cables in addition to the hdmi on this tv
Posted on Apr 21, 2008
Onkyo TX-SR701 getting sound but not picture from Video 4
you should check the video mapping in the setup of the receiver. video 4 may be associated with hdmi or composite video instead of component.
Feb 21, 2014 | Onkyo Audio Players & Recorders
Onkyo tx-sr604 help
You said you tried hooking the HDMI up directly from the TV to each component, and that worked. How is it usually hooked up - through some kind of switch? I'm not completely understanding your setup here.
Aug 10, 2007 | Onkyo TX-SR604 Receiver
The HDM1 on the DVD player model DVP3962/37 has no signal. The player has been working for a year with no problem. We can only watch the DVD on component 1 which is not in color.
The HDMI should work hooked directly to tv through An HDMI input but if it doesn't, try either watching yourself or have someone watching while you twist and try to push all three(blue, green ,red) connectors into their in/out jacks. I feel composite gives you better picture anyway> the HDMI is just easier because it carries sound and audio. Anyway, one of your jacks is probably not in all the way>
Apr 04, 2011 | Philips DVP3980 1080P DVD PLAYER
How do u plug in a dvd player
the onkyo receiver should have hdmi jacks on it labeled cbl/sat,dvd, and so forth. plug the hdmi wire into the dvd and from the dvd to the hdmi jack on the onkyo that says dvd. then run another hdmi cable from the hdmi out jack on the onkyo receiver to the tv
Oct 21, 2009 | Onkyo HT-SR800 System
I have an Onkyo TX-SR606. With an HDMI connection from any dvd player connected to the HDMI/DVD in on the Onkyo I get perfect pic and sound initially then the picture starts to go bad, usually about 5 - 10...
Hook your HDMI directly ffrom the DVD to the TV, then connect digital coaxial or optical to your receiver for audio. Your receiver will not current HDMI video codecs. That is the only fix. Sorry. Hope this helps.
Sep 25, 2009 | Denon AVR-3806 Receiver
No Picture on HDMI using Philips DVP5992.
You can try out by connecting the CVBS (Yello) out from player to TV and connect HDMI out from Player to TV. Goto CVBS input on Sony TV. Select set up and you should get the HDMI Video options availble. Try to change the resulution and check for Video on HDMI source.
Which disc you were playing PAL or NTSC? PAL should work for Europe.
Feb 08, 2009 | Philips DVP5990 DVD Player
Onkyo HT-S6100 to OPPO Dv 980H to Sony Bravia KDL 40W4100
Make sure none of the Digital or Component Input Assignments are programmed, if you're not using them. Set them to "----". This may help. Some of the Component input assignments may over-ride your other input assignments (perhaps even the HDMI input assignments).
Jan 25, 2009 | Onkyo DV-S353 DVD Player
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Jan 04, 2009 | Onkyo TX-SR506 Receiver
HDMI out to Olevia 527 TV = Blue Screen
Hi beelzyboob.. try checking these.. since you are using the RCA (composite cables) and I assume you have them on the "DVD in" at the back, go to setup, go to input assignment and go to hdmi input. here, make sure dvd is set to" ----". Next, hit return and go down to component input and also check if dvd is set to "-----". With these settings, you should get video. This is because you are not using either an HDMI or component cable. hope this helps.. ^_^
Sep 09, 2008 | Onkyo TX-SR606 Receiver
Onkyo HTR500 no sound from the surround speakers or subwoofer
insted of running it thru the tv an to the reciver try doing it directly from the DVD player to the reciver just the audio jacks
Sep 08, 2008 | Onkyo HTR500 Receiver
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
110 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
