Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
How to clearing my router key password
II RECEIVED INSTRUCTION BY EMAIL TO RESET MY ROUTER BUT I CANT CONNECT,,,WHAT CAN I DO TO RESOLVE MY PROBLEM,,,,I ONLY TRY TO PUT SECURITY ,,,,PLEASE HELP ME
  • 84 Answers
There should be a button at the back or below your router it is very small and you need to use something pointed for it. when resetting your router, you will need to press the reset button for at least 5 seconds. once its reset you will need to reconfigure it best way is by using the cd-rom that came with it.
Posted on Feb 09, 2008
I forgot my password and i cant let my friends use this line
If you forgot the password, resetting the router will allow you to access the router's configuration screen again. However, this will reset the settings to default, and you will have to reconfigure the router.
To reset the router to the factory defaults, press and hold the Reset button for more than five seconds. This clears the router's user settings, including User ID, Password, IP Address, and Subnet mask.
Here is the instruction manual for the WR850G Router (the above instructions are from page 1-8):
http://broadband.motorola.com/consumers/products/WR850g/downloads/WR850G_userguide.pdf
Apr 11, 2011 | Arris WR850G Router (DHWR850G)
Tip
'I've forgotten the router password,' is a common problem. But first, which...
'I've forgotten the router password,' is a common problem. But first, which password do you need?
  1. If you want to login to your router configuration screen - you need the router login password.
  2. If you want to connect (say) a new laptop to your wireless internet connection – you need the network key. This is the encryption key used to secure your wireless signal. Windows asks for this key when you try to connect.
Here’s a rough guide to what to do in each case. For detailed instructions, check your manual. If you can't find a manual, follow the tip How To Find A Router Manual.
1) Retrieving a lost network key - so you can connect (say) a new laptop to your wireless network
i) Login to your router. Do this by entering http://192.168.0.1 or whatever is correct for your model, into a web browser. Enter your router username and/or password at the prompt. If you don’t have these, see Step 2, ‘Retrieving a lost router password’.
ii) In the screen that you see, go to the section headed Wireless, Security, or similar. Every router is different, so you may have to hunt around. Key words to look for are Security, Wireless Settings, Encryption, WPA, (or WEP).
Your network key will be here. It might be labelled PSK, pre-shared key, WPA or WEP key, WPA-PSK etc – but that’s the one you need.
Tip: Write the network key down on a label or piece of paper, and stick it to your router.
2) Retrieving a lost router username/password - so you can login to your router interface
i) First, see if there is a label on the base of your router, showing the correct username and password.
ii) Otherwise, try the defaults and see if they work. Common default usernames are admin, or blank (ie type nothing, just leave blank).
Some common default passwords are password, admin, 1234, sky (for UK Sky users), or blank (no password). Check your manual for this, or try a Google search. It’s important that you find the correct default password for your router.
iii) Defaults don’t work? You will have to resort to a hard reset.
Beware. If you perform a hard reset, your router will be back at factory defaults. Your router login password will then be the default, BUT you will normally lose all your router settings. If you have a combined modem/router you will also lose your internet connection, until you have set up your router again.
If you are very concerned about this, ask the person who set up your router to help you.
Otherwise, you can do it yourself . Every router and ISP is different, but with your ISP login details and your manual (see How To Find a Router Manual ) you should be OK.
For further help, visit your ISP’s website. Your router manufacturer’s website may also offer easy install software, and setup tips, if you need them. Print off any online information you need before performing the reset.
iv) To reset - ensure you have a wired (ethernet) connection to your router, and that it is switched on. Find the router reset button, which may be an unmarked pinhole, often on the back of the router. Press and hold down the reset button as long as it takes to reset the router. This is typically 10 seconds or so (check the manual).
v) You can now use your default password to login to the router, and set up your details afresh.
I hope this tip helps you. Losing a password is a pain, and we've all done it. But - with a copy of your router manual - you can find those settings, and get back up and running fast.
All information is offered as is, without warranty. If you choose to use it, it is completely at your own risk. If you are in doubt, consult a local professional. Thanks to all Fixya contributors who helped with this tip.Updated Dec 09.
on Dec 05, 2009 | Sport & Outdoor - Others
Tip
Forgotten Router Password? Or the Network Key?
  1. If you want to login to your router, to view or change settings - you need the router login password.
Here’s a rough guide to what to do in each case. For detailed instructions, check your manual. If you can't find a manual, follow the tip How To Find A Router Manual. (NB: You don't have to read the whole manual - just check a few details, as described in the tip).
1) Retrieving a lost network key - so you can connect (say) a new laptop to your wireless network:
Your network key will be here. It might be labelled PSK, pre-shared key, WPA or WEP key, WPA-PSK etc – but that’s the one you need. Now you should be able to connect to your wireless network.
Tip: Write the network key on a label, and stick it to your router.
2) Retrieving a lost router username/password- so you can login to your router, to view or change settings:
Otherwise, you can do it yourself . Every router and ISP is different, but if you have your ISP login details and your manual (see How To Find a Router Manual ) - you should be OK.
Your ISP’s website may also have info which will help you - why not take a look. Similarly, your router manufacturer’s website may offer easy install software, and setup tips, if you need them. Print off any online information you need before performing the reset.
I hope this tip helps you. Losing a password is a pain, and we've all done it. But - armed with your router manual - you will soon be up and running again.
All information is offered as is, without warranty. If you choose to use it, it is completely at your own risk. If you are in doubt, consult a local professional. Thanks to all Fixya contributors who helped with this tip. Updated Dec 09.
on Jan 03, 2009 | NetGear DG834G Router
Forgot PW 2WIRE101
forgot which password
A)the pw to access the router's settings
B)the key to connect to the router from wireless device
C)the pw to connect to the internet (anywhere past the router)
IF A) then when you are asked to enter your password if you forgot your password. click it, now it will display a hint, and also an option to click if you still can't remember... Just keep doing this until it asks you to reset the pw by 1st entering the network key located on the bottom of the router
If B)
on the bottom of the router there should be three rows of numbers
xxxxxxxxxxxxxx
> xxxxxxxxxxxxx <
xxxxxxxxxxxxxx
the middle row should be a ten digit number this is your access key.
if C)
the pw is the same as the pw for your at&t or sbc email address (which is the login) if you don't know what it is you wil need to call thier tech support to have the password reset. if this is the case BE VERY CLEAR THAT YOU CAN CONNECT TO THE ROUTER or they will ask you to do a bunch of **** to trouble shoot that connection before thier script leads them to this point.
Sep 07, 2010 | 2wire 2700HG-B Router (2700HGB)
I sent my lap top in for fixing so I got it back and I am trying to connect to internet and it states it needs a WEP or WPA Network Key address to type in can you help me with this? my other email is...
1. Your router is the issue. It is asking for the WEP password or Network Key.
This is set up in the Wireless router.
You either know the password or have it written down.
If you are the administrator of the the router and don't remember the password or user name you will have to reset the route to factory default settings and go through the setup wizard and choose and create and save a new user name and password / WEP/WAP key. Consult your router cd for the instruction set. It will walk you through.
Jul 07, 2010 | Belkin (F5D7230-4) Router (587009)
Cant use netbook cant find router network but can log on with main computer
- Go to router page - http://192.168.0.1 or http://www.routerlogin.com
- default username and password - "admin" and "password" - (case sensitive)
- Left side click Wireless settings under SETUP.
- then You have Name(SSID) / channel - 11/Mode - b&g/
- then you have Wireless access point
- you have to check the 1st and 2nd option shud be checked.
-- (Enable wireless access point and Enable SSID broadcast.)
- then Security Option - Select 3rd one WPA-Psk - "create password"
-- apply all the settings
--- and then try to connect it wireless.
-- if u can see ur network click on it and try to connect.
-- that will ask u for security key type ur security key there which u have created and then try to connect it.
-- I hope that will resolve ur issue.
If ur issue will resolve please rate this...
Regards
TecKC
Dec 03, 2009 | NetGear DG834G Router
How do i hook up my belkin wireless router to cable internet
First connect your router to computer with ethernet cable .
Then access it by following link
http://192.168.15.1
type user name as "admin" and password as "admin" or blank or "password"
if you not able to access router with that ip you need to reset your router.
Press reset button for 10 seconds it is in back side of router.
then follow the upper instruction.
then go to wireless settings enable wireless.
Then if you want dhcp then enable it.
Also if you want wi fi security configure your router as WEP
then add wep key it is your password to connect from computer to router.
Go to intenret settings and set as your isp provides.
then connect cable from yourt isp and check.
Jul 29, 2009 | Computers & Internet
My PS3 cant find IP address from Netgear router DG 834,what I have to do
make sure you are putting the network key correctly...if you dont know tha network key.. try the following.. . Connect a computer to the router using any one of the 4 available ports.
2. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the router usually by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
Click on wireless settings (under setup) from left menu.
Change the channel to 11
*-security option > select wep.. in KEY 1 put a ten digit number .... nothing under passphrase ..
Apply settings to save the changes.
*-then try to connect your PS 3
I hope the steps above will help resolve the issue. If you need any further help, please email us back so that we can continue to work on a solution.
I hope this information allows you to resolve this issue.
Jun 14, 2009 | NetGear DG834G Router
Lost codes
On the back of your router there is a reset button, hold it down for 3o seconds or so, this will reset the router back to factory settings, the default user name and password would be admin, note that sometimes with the belkin you only need the user name and not the password. Usually you need admin/admin though.
The default IP address to access the router when its reset is 192.168.2.1
Hope that helps
Aug 25, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Linksy router lem....!!!!
Try the following to reset it to the factory defaults.
Warning! This will reset all the settings in the router! Including any custom setup stuff, like WPA key, etc.
Turn the router on. Press and hold the reset button on it for 30 seconds. The reset button is usually a small recessed button on the back of the unit depending on which model you have.
Now you should be able to connect to it through your browser at http://192.168.1.1. Depending on your model, the username is blank and the password is "admin" (without the quotes) OR both username & password are "admin". Note that you will need to connect your computer to the router with a network cable to go through the setup process - you can't do it wirelessly.
Dec 13, 2007 | Zyxel P-334WT Router (91003155003)
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
