Question about Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo
Keeps blowing fuses
When you replace fuse and plug in set in flashes and blows fuse.
  • 2,130 Answers
When a fuse keeps blowing, that is an indication that some component has failed and the circuit is drawing too much current. Most likely it is a problem in the power supply section or high voltage / flyback section.
Sorry to say, you will need to take it to be serviced.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Feb 09, 2008
88 toyota pick up v6 keeps blowing efi fuse
you may have a short of some kind, when a fuse blows repeatedly it is no good just replacing, you are being told that something is wrong with the equipment.
You will almost certainly have to visit a technician for a diagnosis. It is unlikely to be something that an inexperienced end user can sort out I am afraid.
Oct 26, 2015 | 1988 Toyota Pickup
1999 ford super duty relay coil keeps blowing fuse. truck wont start. why?
Some of those trucks had a heater coil in the fuel filter bowl. It would short out and blow the fuse . Try unplugging the wire just behind the bowl ,and replace the fuse again. that may fix the problem.
Feb 18, 2015 | Ford Cars & Trucks
It sounds like the A/C compressor clutch is shorted. You will need to have the clutch and / or the complete compressor replaced.
Mar 21, 2014 | Chevrolet Uplander Cars & Trucks
Samsung dlp 5065w keeps blowing fuse
samsung motherboards are bad for going out. they are 125 dollars online, if you have the technical skills to replace them.. basically just plug and play, with LOTS of screws to take off.
Oct 06, 2012 | Samsung HLN5065W 50" DLP TV
99 vw jettal 2.0 gas fuse 29 15amp fuse keeps blowing-no spark unpluged coil and fuse keeps blowing. help please
Thats the fuse for the ECU, engine control module, and is a 15amp for gas 2.0. i would locate the ECU which is under the center of the plenum in the engine compartment and disconnect the long plug. Check for green discoloration on the multipin connector. Sometimes moisture will get in there and short some of the pins together. Leave ECU unplugged and replace the fuse. If it still blows cause is between the fuse and the ECU.
Dec 27, 2010 | 1999 Volkswagen Jetta
Beko wm5120s fuse keeps blowing.There is flash in the drum when it blows.any ideas?can only do a rinse,any other programs blow fuse.
Your element will be faulty. Remove both wires off the element. tape them up. Select the program that blowa the fuse and run. If not blowing, replace element.
May 27, 2010 | Washing Machines
Samick sga 120 amp keeps blowing fuses. replaced all rectifier diodes and tranformer seems to be working fine. any suggestions?
Fuse blowing is due to excessive current drain and the the first clue is the blown fuse itself. If the fuse blows with a flash a bang and splatters copper across the inside of the glass you have a hard blow caused by a dead short on the power supply, check for power switch flashing over internaly. Short circuit main filter capacitors. Shorted turns in power transformer primary winding. If fuse just separates check for short on output transistors C to E. Try isolating fault by disconnecting LT pos/neg supplies to output stage. Also check for partial shorts on speakers and speaker wires using an analog ohm meter on low ohms setting.
Mar 27, 2010 | Audio Players & Recorders
05 altima blows fuse for left headlight
Go out at night, or dusk, with a flash lite, replace the fuse with a higher amp or any spare fuse, turn out the lights, turn on the car lights, look for a spark somewhere, have people standing around engine comp, if it doesn't blow, wiggle wires, if it shorts out, you should see a spark, fix with tape, you should be all set.
Dec 29, 2009 | 2003 Nissan Altima
It keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
Jul 16, 2009 | Cerwin Vega CLSC-12S Subwoofer
Radio fuse keeps blowing
make sure nothing in cig lighter socket..coins,etc..if nothing present,unplug cig lighter socket and replace fuse..if fuse doesn't blow,it's the socket causing fault..if it does,unplug radio,plug cig lighter back in and replace fuse..if fuse doesn't blow,radio is cause of fault..if it does,then ther is short in wiring
May 19, 2009 | 1992 Honda Accord
Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo Logo
313 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
