Question about Dell Inspiron 9300 Notebook
Computer fan is loud & computer running slow
Computer made a loud beep then went screen went blank. Turned on compuer and fan is on and really is loud. Computer is really moving slow.Fan won't turn off. Next day computer did same thing with loud beep then blank screen. Please help!
  • Anonymous Mar 13, 2008
    I have the same problem, same computer..
    After a short while the fan goes loud and the computer slows down... No stuff blocking the fan..
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 28 Answers
There are a number of reasons might be affecting, some are dangerous while others not that serious. Learn why and how you can speed it up easily from: http://www.whyismypcsoslow.net/ hope this helps take your stress out!
Posted on Sep 02, 2012
    Scholar:
  • 181 Answers
Check the exhaust port where the fan blows, as well as the intake port for the fan. Likely it's overheating because the heatsink is clogged with dust, hair, etc.
Get back to me if that doesn't work for you.
Good luck
Posted on Feb 09, 2008
  • 268 Answers
Good luck.
Posted on Sep 28, 2011
Try this:
http://www.asklaptopfreak.com/laptop-notebook-help/2007/11/26/fan-making-lot-of-noise/
I was just searching around. I don't know if you are still having the problem, but it just sounds like the computer is having problems monitoring the temp and then kicks the fans on. I don't understand the slow-down, though.
Posted on Aug 12, 2008
Cool air from home vents with central AC outdoor unit fan will not turn on. Inside home really loud when on!!
its look like blower problem , 1st check blower speed controller, check blower motor , check its ball bearing etc , its does not have any link to external unit .
Jun 15, 2014 | Goodman Heating & Cooling
HP Pavilion a 1245c won't boot black screen no beeps constant running fan
sound to me like a video problem. no beep codes, you hear the fan going so it must be posting. could you try with other monitor and or cable? is there power to monitor? reseat cable at both ends( monitor+ pc)
Nov 02, 2012 | HP Pavilion a1720n PC Desktop
Dell loud fan noise
Is the computer completing post? This is indicated normally by a single beep after the power button is turned on. On most computers the beep is proceeded by a post screen with the manufactures logo. If the computer is not getting this far, unplug everything but the memory and video. This should cause the computer to give a no hard drive or OS error. If not pull all the memory, this should cause the computer to give a series of beeps (because there is no memory installed). If this does not work either, you could have a bad mother board or power supply.
Hope this helps
Jan 26, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
Averatec 3200. left my computer on for a couple hours not really running anything except AIM and Windows Live when i came back the fan was running but the screen was blank. attempted to restart it, but it...
POST beeps are almost always indicative of RAM failures, so if you've already reseated it, the next step would be to try another memory module to see if the issue goes away. Keep in mind some notebooks have more than one RAM module as well (sometimes there's one under the keyboard and one on the underside of the unit)
Mar 27, 2011 | Averatec 3200 Notebook
Computer will not come on loud sound from pavillion repeats it self. The fans will spin and the blue light on pavillion comes on. moniter screen will not come on the power light is on
On some computers, when you turn it on, the fan starts to run at 100% of its speed, i.e., very noisily.
Then, when it is detected that the computer is functioning, and _not_ over-heating, the fan will slow down, and quiet down.
So, what is the nature of the "loud sound" ?
Continuous? Beeps, in some pattern?
Take the computer to a qualified technician, for better trouble-shooting.
Jun 09, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
Screen won't appear upon start up and I get 3 beeps but no screen
3 beeps POST code (power on self test) means RAM problem.
Reseat the RAM module/s and boot up your computer.
If you have two RAM modules, remove them both and insert one at a time to test them, to determine which module is faulty.
If it still doesn't work then replace the RAM module/s
Apr 02, 2009 | Everex StepNote NC1500 Notebook
Loud Fan, Three Beeps, Black Monitor and No Keyboard response
I have the same model after youlet it sit for a long enough period to cool down it will come back on and work normal, it is a cooling problem called gateway and they confirmed this theproblem I ran in to was what fan this computer has 3. temp fix I used was to remove the tower cover to allow better air flow try this till you can figure out what fan is messing up
Jun 02, 2008 | Gateway GT5404 PC Desktop
Blank screen on boot
hi firend
u havre to do this chk the ram remove & clean it reinstall it in your pc if problem occers then
u have heting problem ur prosser fan has been dust so remove your prosser fan clan it put it back agin
Apr 27, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Apr 12, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Inspiron 9300 Notebook Logo
3,664 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
