Running NCR on canon IR 8500
Hello I am trying to run ncr paper on my 8500 image runner copier but it keeps jamming. Can you run the ncr or do you have ot use the specialized paper for the laser? Is there any major detriment to the machine to use regular ncr? If it doesn't cause major damage are there any tips to make it run without jamming by paper selection or something?
  • Visionsp Feb 11, 2008
    Thank you very much for the great informative information on the NCR printing with the canon. I couldn't have asked for a more concise explanation.
  • 287 Answers
Hello Visionsp, NCR paper is special in so many ways (uhg).First of all is is typically thinner than regular 20# bond paper. Second,each sheet is chemically "married" to the other as there are ink beads on the back of one sheet that are activated by the unique beads on the face of the second sheet so to some degree they are manufactured to be mated together. So unless your paper feed system is @100% then the sheets (2 or 3 sheet NCR) are more difficult to seperate and are inclined to feed two sheets at once. THE BIGGIE is this. Consider the fact that in order to produce the carbon copy image that is being transferred from the top sheet to the pages below it requires pressure from from the pen. Your IR 8500 (and all modern copiers) has a section of the copier called the fuser.It uses extreme heat and pressure to bond the powdered carbon based toner to the paper by passing your normal copies between two heated and tightly gripped rollers, kinda like using an iron with extreme force. When the NCR paper passes through the fuser the exteme heat and "pressure" break the chemical ink beads on the NCR paper and begin to leave a layer of the very same chemical ink on the rollers as they pass thru.But instead of only trace amounts of carbon copy image (as would be reproduced by a customers signature on to the next sheet ) the entire NCR sheet is being heated and mashed and a large amount of the chemical ink is being activated rightat the point of maximum heat and pressure. Not only is this sticky as *&%$ ,but it leaves a residue on the fuser rollers (since there is no paper to transfer the beads to) and the rollers build up with ......basically ink. So at some point the copies going through the fuser will rather wrap around the rollers or cause "accordion" jams because the telon coated rollers are no longer coated with non stick teflon but are coated with tacky gunk. The only workaround for this is to run small runs of the NCR paper at a time, then run regular white paper for a while which will remove the buildup and then another quick run of NCR and so on. I have worked on Canon,Toshiba,Ricoh,Savin and Kodak copiers.The results are the same.NCR paper is not designed for regular copiers as they all use the same type fuser system. A press or a RISOGRAGH are the only reliable systems to run NCR paper. I wish I had better news.NOTE: even the workaround I have provided,which can work, does not eliminate the possibility of ruining the fuser rollers beyond repair. good Luck...............SPINAL
Posted on Feb 09, 2008
I have cannon ir 3300 image runner it shows paper jammed in right side but there is no paper jammed in any side of the machine
Manoj, Try using compressed air to blow dust and debris out of printer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix paper jam Canon iR3300 printer
Home Canon Italia
https://www.usa.canon.com/internet/portal/us/home/support/details/copiers-mfps-fax-machines/support-multifunction/imagerunner-3300
Aug 20, 2016 | Canon Ir 3300 Black & White Copier
Paper jam err but paper not found
either sensor needs to be cleaned or small torn of paper has to be somewhere inside.
Mar 23, 2016 | Canon Ir 3300 B/w Copier image Runner...
I have a Riso RP3700 that we have been running NCR paper on. But the pass few months I have been getting jams after a few runs of the NCR it is always the pink copy that get jam on the drum. Can someone...
All you have to do is to ensure the image is pushed down the page. Either on your graphics software or on the RP3700 itself and by using the image offset function. Try 2mm at first.
If the image is too close to the margin the paper has trouble releasing from the drum as the ink makes it stick to drum. The little hook cant then get under the paper hence jam.
I am confident this will work.
Feb 21, 2011 | Riso Office Equipment & Supplies
Error E007 Canon Image runner 2020 Will not finish perinting a document with the above mentioned error
The error code E007 is a fixing film error code > it will have to be replaced to clear the code. That is if it a IR-2020, a IR-8500 does not have a fixing film.
Aug 20, 2010 | Canon imageRUNNER 8500 Copier
I required Canon Photocopier IR3300 driver
Hi, try this link for your driver:
http://www.givemefile.net/drivers/_xerox_and_ifis/canon/ir-3300.html
Aug 07, 2010 | Computers & Internet
Canon image runner COPIER
We finally found all the buttons-levers to push and to pull and were able to remove the paper that caused the paper jam. Thanks for your help Nellie
Dec 22, 2008 | Canon imageRUNNER 1310 Printer
2,210 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
