This is on my screen what does this mean. The power cable was pulled out and this is all that shows now.
It could be many things including, Hard drive issues, Corrupted Registry Entries, etc... But since you posted that the power cable was pulled, I would lean toward file/registry corruption.
You should try to boot into "Safe Mode" (by tapping the F8 key on boot until you get the boot option screen and see if you can't possibly repair or restore your configuration there?
If that doesn't help and you have a XP installation CD that's compatible with your version (such as Pro. or Home preferably SP2), that's if you are running XP? If so you could attempt a "Repair Installation" after booting to the CD (you may have to change your "Boot Order" in your BIOS first) that should leave your current data intact, or a lesser preferred alternative would be to recover your original configuration from a restore partition on your hard drive (if one exists?).
More detailed information on your issue would help us to help you too.
