Question about Fostex MR16HD/CD Digital Recorder
Display error When I power up the unit, the screen will illuminate, but I'm not getting a menu or any text in this screen.
  • kNeed_Help Feb 09, 2008
    Forgot to mention that my unit is a Fostex VF160EX. The screen will display but I'm not getting a menu.
  • ilikecoff Sep 23, 2008
    exact same issue-no display text showing up-just light. its really annoying. anybody know whats up?
    Brigadier General:
  • 6,966 Answers
Here is the link to your other post pls.
Posted on Feb 09, 2008
3 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Display
  • 3422 Answers
SOURCE: Display error
1. Is it a stand alone or have you get it hooked up to a PC?
2. If with a PC, Win Xp or Vista, Mac?
3. Is the unit new, refurbished, bought from ebay or from a dealer.
If the unit is more than 2 years old then the only solution is to get it repaired or buy a new one instead.There are instances where internal software gets corrupted or even in some models, memory battery has leaked or depleted.
Unfortunately there is no external reset for the unit. It has to be opened up and diagnosed with the use of a special diagnostic PC and software. The firmware may also need to be re-installed or updated.
Am afraid your only best bet would be to open the unit and check the inside. Easy enough would be memory battery (if ever present) since they look like a thick coin (Lithium 3Volts) but other than that, most repairs would need knowledge and familiarity with electronic component and circuitry, a service manual, a DVM, a soldering iron and even as earlier stated some specialized equipment.
Perhaps your best bet would be to seek the services of a qualified professional or the nearest authorized Service Center.
Goodluck,
Please don't forget to rate the solution as fixya..
Posted on Apr 07, 2008
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jul 17, 2012 | Televison & Video
Display error
Goodluck,
Apr 07, 2008 | Fostex MR16HD/CD Digital Recorder
Panasonic PT LC76U Multimedia Projector Lamp how do i reset the timer
press the MENU button to display the menu screen, and then press the UP and DOWN aero button to select the "OPTION" menu. press the ENTER button and then press the UP and DOWN aero button to select "LAMP RUNTIME". Press and hold the ENTER button for approximately 3 seconds.
The "LAMP RUNTIME" screen will be displayed.
(NOTE: press any button other then the POWER button to cancel the "LAMP RUNTIME" screen)
Press the POWER button to turn off the power.
The POWER button on the projector illuminates red.
This will reset the cumulative usage time for the lamp unit to "0"
Jan 12, 2011 | Panasonic PT LC76U Multimedia Projector
How do you change language from Spanish to English on this phone? I put it on spanish somehow and i cant get it back to english.
Hello
Using Settings
Settings contains many submenus that let you customize your phone.
Display/Info Features The Display/Info menu controls how the keypad and display appear: - changes the wallpaper that • Wallpaper appears on the idle screen. - sets the size of text on the display. • Text Size - changes the look of the display. • Theme - controls whether main menu • Home Icons icons appear on the idle screen. - controls backlight illumination. • Backlight133 Customizing Your Phone - controls whether the time and date • Clock appear on the idle screen; sets time and date format; sets year. - controls whether the items on • Menu View your main menu and Java applications menu appear as large icons or a list. - sets large digits to appear on • Large Dialing the idle screen when you enter a number. - sets the language that your phone • Language displays.
for more information Get the manual from here http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/i850/US-EN/_Documents/Static%20File/i850_UG.pdf
Hope this helps if so do rate the solution
Jan 05, 2011 | Motorola Mobility i850 Cellular Phone
My screen fails to illuminate, I can make out text just barely but there's no light - I think it's the inverter? If so I found one to buy but I'm looking to at least see it in my laptop first, is it...
  • Hi, hope this will help you with your problem. There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop,” click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Select, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. "Restart "Computer." *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click, "Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “Did this solution help?”
Feb 02, 2010 | Toshiba Satellite L25-S119 Notebook
Green power light comes on but screen does not power up
Have you tried changing the light through the menu screen?
Jul 05, 2009 | Nintendo DS Lite Console
Start Up red light error 37,004.40:35596
That is a Jet Heat error. Most likely a bad print head. Could be the electronics module.
Either the print head heater has failed, or the supply voltage to the print head heater.
Either one is very expensive to replace.
May 30, 2009 | Xerox Phaser 8400DX Thermal Printer
Lcd screen
Cannot get images deleted
Feb 23, 2008 | HP PhotoSmart M437 Digital Camera
Display
Feb 09, 2008 | Fostex MR16HD/CD Digital Recorder
Open Questions:
See all Fostex MR16HD/CD Digital Recorder Questions
Fostex MR16HD/CD Digital Recorder Logo
218 people viewed this question
Top Fostex Televison & Video Experts
Michael Galve
Michael Galve
pawnpower
Tom Chichester
Are you a Fostex Televison and Video Expert? Answer questions, earn points and help others
