Question about GE 32GT740 32" TV
Sound going out
Today while watching tv. my ge tv sound stops working. after a while the sounds comes back. i aired out the case, but did not fix the problem. thanks for the help. and btw it is very dificult to find tube 32' tv's now...
  • MikeHawk Feb 09, 2008
    i may try it, had bad experience on xbox i soldered. thanks for the info...
  • 98 Answers
Do you know how to solder? if yes check the circuit board for loose parts and loose connections..
Posted on Feb 09, 2008
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
What would cause a flat screen tv to have sound but no picture
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from ...I have sound no picture it would take a few minutes waiting before it would come back on . ... and I think I may have causedthis because it's been in for 2 days straight ... ken you helpe samung lcd tv no sound screen is black sound works ...
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little ... up to the screen, you have to look carefully but if youcan make out the ...
Repair A TV With Sound But No Picture - YouTube
? 2:30
https://www.youtube.com/watch?v=MQj2t4nNVYc
Sep 18, 2012 - Uploaded by MonkeySee
Jan 11, 2016 | Televison & Video
Have flat panel hdtv monitor 1080i samsung no picture or sound
Tv has no picture or sound; will go out while watching. The picture will go into a line and sound and picture will go out; shortly after that tv will turn off. Did this last nite and I did not turn back on until this morning, it worked no problem. On for couple of hours and now it's out again. What could be problem and how do I fix myself
Feb 27, 2010 | Televison & Video
My Samsung HL-85679W DLP LCD TV has sound but no picture
Look to see if there is a little green light on the bottom of your case, this would indicate the bulb is working, if the light is red, you need to replace the bulb....good luck
Feb 07, 2010 | Televison & Video
GE 32GT740 32" TV Problem
try checking the flyback transformer. make sure everything is soldered. Be careful when handling the crt retains voltage. even if disconnected.
Nov 01, 2008 | GE 32GT740 32" TV
Power led blinks but no picture or sound
Had the same problem myself. Took some doing but I managed to find a service bulletin that I downloaded. The problem is with the siene module and all you need to do is unplug connector JP63A from the main board and your TV will work again.
Take the back off the TV (there are a lot of screws) and look on the left hand side of the main circuit board that is mounted in the center of the TV. You will see a small white connector that is labelled JP63A, simply unplug it. Plug the TV back in and let it reboot. That's it, should be able to watch immediately.
Aug 15, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
No sound on older samsung tv
techs call this a cold or a bad solder connection on the output transistor most likely, tap on it here and there when it happens on the bottom and side of tv, if sound comes in then stops again then it would be a loose connection due to heat over time, if your inclined u can be fixed it, if bad chip it would play first then shut off, or if u have a cable box or rca outputs on tv use them on an amp to get sound, that would bypass amp output and u will use the preamp section which is a different circuit, debgh@comcast.net
Jul 25, 2008 | RCA F19625 19" TV
Rca projection tv sound problem
You could try to get the set fixed but I would say the set is just worn out.
Time to buy a new TV I think (going by the picture above anyway)
Dec 28, 2007 | RCA G27647 27" TV
No picture when I turn the tv on only sound
TRY CALLING BEST BUY'S GEEK SQUAD TO COME FOR A IN-HOME REPAIR SERVICE CALL AND THEY WILL FIX YOUR PROBLEM!
Dec 14, 2006 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
GE 32GT740 32" TV Logo
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
