Question about RCA D52W19 52" Rear Projection Television
Rca d52w19 when i plug tv in the green light flashes 3 time then you have to wait 1 minute to try it again.then it does same thing over.i have been doing some reading on this site and see alot of people having trouble with the flytransformer but mine does not make any sound? when i followed the red line to the front of unit which is attached to splitter i think?that part looks shorted out.i mean smoked.if it is the splitter should i also change the fly? model # d52w19b , chassis# ITC222 thanks
  • 7 more comments
  • bubba Feb 09, 2008
    ok thanks that would be great.i will take spliter off today and see if i can find the number on it.one more thing how do the wires come come off? i have seen diferent post for different tv and some of them say you turn it and pull.is this the same way or you just pull it? thanks
    ok got it out here is a picture of it.I was wondering if all these things
    change color like this after awhile or just when they burnout?
    ok on the sticker 1st one is TCE 70234 05/may/2004 00.
    on the second one it says P/N 1606412a
    DID 15154180
    VDF Reg. N0. 7403 410
    and below the bar code the number is 70209419414625
    ok on top off splitter it says FR-PY-30
    1517923
    CAV 1 sub 3
  • bubba Feb 10, 2008
    one last thing. what is the real name for the splitter.i see it being called a block,a hv block& splitter. thanks for the help
  • Jeff Miller
    Jeff Miller Feb 11, 2008
    My light turns off three times and use to start now it does not start at all just keeps coming on the light that is and going off 3 times.D52W19 RCA troubles
  • bubba Feb 12, 2008
    here is the part i need.
  • Yeager68 Feb 12, 2008
    I have that issue also where the green light flashed 3 times then nothing. So I took the back off and checked out the boards after reading these articles and found the left front board fried. It has a burned spot on bottom about 3 inches in Diameter. The barcoded sticker has PSB-850. Where can I get this board.
  • bubba Mar 16, 2008
    hey Terryfic found this in another post and it fixed my problem! dont know how to past link to other post but here this is"Unplug the TV of course and remove the back lower panel.Blow the dust
    off so you can see the components clearly.Have a bright light and look
    at capacitor CP158 16V 2200uF Green in color with gold (NEG)stripe
    which is located on rear board to your left.This baby was hard to see
    because it sets/hides behind the metal heat sink fence.Mine was bulged
    at the top and had brown ozz coming out at top.None of the rest looked
    this way.You have to unplug several ribbon cables and power wires to
    remove board so you can flip it over and un-solder it to put in a new
    one.The board just slides out easyly.(Important)note which side gold
    negative band is on Capacitor new one has to go in same way or it will
    pop.When I removed the Cap. and put analog meter on it it swung ok but
    ESR was off the scale at 6.5 to 7.0 It should be .05 this was my fix
    and it is like new again.I already had this Cap. but this is 92 cent
    part you can get at Radio Shack Jameco etc...Make notes of where wires
    unhooked from but they are pretty self explan.Take your time and double
    check your work.Hope this helps.I really missed this TV but now back in
    action. Yoba439@windstream.net PS don't touch the big twin big fat
    brown caps on right board these will bite at 250 Volts.Good Luck" thanks
  • kuberkh Mar 24, 2008
    Hi, I have same problem, like when I plug in tv the green light flashes 3 times and goes, wait about 1 minutes and try again, same thing happen, flashes 3 times with little sound and goes. I checked the board and found the CP158 16V, but it looks good, it is not bulged at the top and no brown ozz coming.So, now what to do. Please advise. Thanks
    Genius:
  • 1,694 Answers
You can change the HV splitter first,then change the flyback
transformer, if necessary.......Do be careful with part number
of transformer....check the drawing number on it ......10756 =
259296.......10799 = 265409......as examples..........
I can check on that for you based on your info................T.
Posted on Feb 09, 2008
  • 3 more comments
  • Vista Electronics Feb 09, 2008
    Twist and pull at the same time..T.
    Splitter Drawing # probably is 1547864B = RCA part # 250771.
    Correction part # 250671..................................T.
  • Vista Electronics Feb 12, 2008
    Injmiller,
    Same solution as bubbatazz.......need numbers...............T.
  • Vista Electronics Mar 16, 2008
    Always good idea to perform thorough visual inspection.....T.
Changed capacitor P150 I think (2200 uF Electrolytic) It was bulged and worked for two years. Just last night went out again and now I see an arc on the corner of my flyback transformer. ****!
Posted on Jan 11, 2010
  • 21 Answers
I checked the capacitor and it had a slight bulge. My condition was that the tv became harder and harder to get to stay on. It would try 3 times to start up and one could hear the horizontal trying.
Changed the capacitor and it started up right away.
I have been fixing tv's for about 25 years actually having my own business for many years. I have learned that in a situation such as this, it is the heat from the heat sink that dries out the capacitor. So I mount it on the bottom side of the board. Just have to make sure that one mounts it properly and the leads or the cap don't short out! Hot glue it on.
Great site, thank you!
Peter
Posted on Oct 23, 2008
RCA d52w19 green LED flashing and speaker int/ext switch problem
The most probable cause are the Three capacitors CP150, CP114 and CP120 all located on the deflection board.
Dec 13, 2009 | RCA D52W19 52" Rear Projection Television
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
RCA D52W20 tv
3 capacitors On Deflection board cp150 2200uf 16v see if it is puffed up on top if so it is bad also replace 2 more caps in same circuit cp114 cp120 both are 220uf 35v they are green with gold writing.For Parts 1-800-223-3205. www.electronix.com
Dec 27, 2008 | RCA D52W19 52" Rear Projection Television
Problems powering up
These sets have alot of problems with poor solder connections resolder all pins on flyback transfomer, check 3 capacitors on power/deflection board cp(150) 2200uf 16v (cp120) 220uf 35v (cp114)220uf 35v they are green with gold writing.Also it is better to fix it Now because the longer you keep trying to play set it can cause more damage to it.
Dec 13, 2008 | RCA D52W19 52" Rear Projection Television
RCA = flyback?
I just posted a reply to you. Its most likely not the flyback causing that symptom.
Oct 05, 2008 | RCA D52W19 52" Rear Projection Television
TV will not turn on.
Bite the bullet, because it's time for Santa tech to work on this and find the reason for the power supply problem..accordianman
Dec 16, 2007 | RCA D52W19 52" Rear Projection Television
Tv will turn on
leadfoot,
i believe the problem is the flyback transformer. try cleaning by using a small aerosal can. this will either correct the problem or you might have to replace it.
flyback transformer stores energy so i would suggest hiring a professional technician.
Nov 20, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
974 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
