Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Location of reset button on model 44110
Thermostat has switched from fahrenheit to centigrade and it says to push the up button and the reset button -- we can't find the reset button???
I would to switch my themostat to manual, I have a Hunter 44110 programmable themostat, I would like to a maual for this themostat.
Posted on Feb 20, 2008
  • 168 Answers
There is a little reset button right under DAY/TIME. You will need a pencil/pen tip to press this little switch in to reset your unit.
Hope this helps.
Good luck.
Mac =)
Posted on Feb 09, 2008
22-7080419 WS. How do I change it from Centigrade to Fahrenheit, and to set the temperature?
I can not find that number on the Williams-Sonoma website . the only one that shows with dual temps has a button on the front to change the settings from centigrade to fahrenheit
Nov 26, 2015 | Williams-Sonoma OXO Digital Leave-In...
Oven control won't let me raise temp. above 287, is there a way to reset control panel
Yes, you are in Centigrade (Celsius) mode. Check your owner's manual for instructions on how to switch between Centigrade and Fahrenheit.
Sep 09, 2014 | Kitchen Ranges
Can't change temp reading from centigrade to Fahrenheit on Howard Miller 645 697 weather sentinel
On the indoor panel...hold down the alert button until you hear 2 beeps and see up/down arrows displayed on front (bottom). Use the up/down buttons on the front until you get F instead of C. Push the alert button again so the up/down arrows disappear on the front panel.
Dec 28, 2012 | Measuring Tools & Sensors
Trouble light comes on, can barely read the instruction around it(faded over time)It says to push a red button but not sure where the button is. Help!!
When trouble light comes on, it indicates that the hi-limit is tripped (this happens when oil temperature exceeds 450 Fahrenheit). The red button is located at the upper back panel of the unit, give it a push to reset but if nothing happens after resetting the button, the hi-limit needs to be replaced. Also try to check if the thermostat is working, stuck thermostat's mechanical contact will cause the hi-limit to trip.
May 05, 2011 | Wells F14 Deep Fryer
How to change outside temperature guage from F to C
You can switch the temperature mode
between Fahrenheit to Centigrade as follows:
While pressing the OFF button, press the
AUTO button for 3 seconds or more.
The display will change from Fahrenheit
to Centigrade, or from Centigrade to
Fahrenheit.
Feb 04, 2011 | 2011 Hyundai Elantra Touring
My oven won't heat above 255 degrees. just curious what the problem might be.
You do not state if this is in centigrade or fahrenheit.
If it is centigrade, then it will not reach more than this if it is a domestic oven, if fahrenheit, then it should get hotter, so I would suspect a faulty oven thermostat as being the cause of the problem
Jan 05, 2011 | Ovens
When i change the temperature to make it hotter, the screen blinks then goes back to being 30 degrees colder. Is my heater ignoring my request because it never reaches the temperature i want it to. it...
First you have to understand in thermostat there are Fahrenheit & Centigrade degree. If Centigrade between 16 to 30 and if it is Fahrenheit 60 to 86.
If you press the symbol ther> and > (or) ther- and ther+ at a time degree will change.
Now you set your temp +10 degree from your room temp and also keep "heat" mode.
Dec 14, 2010 | Heating & Cooling
Changing temp readout on Midea Air Con Controller from F to C
  1. Make sure the unit is NOT on lock mode
  2. Press reset button for 2 second or until the Flashinf "F" appear on the temperature display or panel.
  3. Press Add button to change from Fahrenheit"F" to celius "C".
  4. Then press confirm and then cancel button to finish.
Jul 09, 2010 | Heating & Cooling
I have a Robert Shaw thermostat and it converted to celsius degrees. How do I program it for farenheit???
The thermostat is preset to display the temperature in degrees
Fahrenheit (US models) or degrees Celsius (Canadian models). The
temperature display can be changed. Press and hold both the
?° and ?°Ÿbutton for three seconds. The display will read F or C.
Release buttons. Press the ?° or ?°Ÿbutton to switch the display.
Jun 16, 2010 | Shaw Robert RS-9420 Thermostat
I have a frigidaire sisde by side refrigerator model # FSC23F7TDW. My Temperature control is reading the the freezer & fresh food temp in centigrade. How do I get the Temp display to read in...
Same Guest as above posting this ... By the way, I have a FLSC238DS5 ... I spent 45 minutes on phone w/Frigidaire this afternoon (Phone#: 706-860-4110 Option 1 --> then Option 3). Didn't get anywhere. They say there are 3 solutions that should change it from C to F: 1) In between LED readouts for "Freezer Temp" and "Fresh Food Temp" there is a mode button that is hidden under the plate that you can press w/your finger OR 2) Hold "Fresh Food Temp" Up Arrow Key down, within 5 Seconds press "Freezer Temp" Up Arrow Key 3 times and it should change C to F or vice verse. Didn't work for me so she said 3rd option was to have a service tech come and diagnose. She said there would be a charge. I am not paying to have somebody come here to resolve this issue. That is when I asked her to escalate it to a supervisor which she did. Hopefully, I get a call back & a solution. Stay tuned ...
May 24, 2008 | Refrigerators
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
1,203 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
